| 0011453 | ParaView | Bug | public | 2010-11-12 21:09 | 2012-05-22 22:39 | ||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | duplicate | ||||||
| Product Version | |||||||||
| Summary | 0011453: Exodus reader not reading individual files from multifile dataset correctly | ||||||||
| Description | ParaView trunk, Windows, local server File/ Open. Go to zpinch_1 directory. You will see that you can open the file set. But, we only want to open one file (for instance zpingh_1.8.2). It can't be done. This is a bug. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0023240) Ken Moreland (manager) 2010-11-13 08:42 edited on: 2010-11-13 08:45 |
You are supposed to be able to load a single file by modifying the file pattern. That no longer seems to be working. This probably broke when the Exodus reader was wrapped in the file series reader. This seems like an awfully low priority to me. 99.99% of the time you want the Exodus reader to group partitioned files. We also have very solid use cases for detecting groups of restarts (including restarts of partitioned files). Fixing this issue may interfere with this more important use cases. |
| Notes |
| Issue History | |||
| 2010-11-12 21:09 | Alan Scott | New Issue | |
| 2010-11-13 08:42 | Ken Moreland | Note Added: 0023240 | |
| 2010-11-13 08:45 | Ken Moreland | Note Edited: 0023240 | |
| 2010-11-22 14:05 | Robert Maynard | Assigned To | => Robert Maynard |
| 2010-11-22 14:05 | Robert Maynard | Status | backlog => tabled |
| 2010-11-22 14:09 | Robert Maynard | Assigned To | Robert Maynard => |
| 2012-05-22 19:19 | Alan Scott | Relationship added | has duplicate 0013179 |
| 2012-05-22 22:39 | Utkarsh Ayachit | Status | expired => closed |
| 2012-05-22 22:39 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2012-05-22 22:39 | Utkarsh Ayachit | Resolution | open => duplicate |
| Issue History |
