View Issue Details [ Jump to Notes ] [ Print ]
0010556ParaViewBugpublic2010-04-15 12:292016-08-12 09:58
ReporterMitch Nelson
Assigned ToKitware Robot
PrioritynormalSeverityblockReproducibilityalways
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version3.6.2
Summary0010556: WriteImage in pvbatch pvpython
Description
WriteImage( "foo.png", "vtkxxxWriter" ) generates a segmentation fault when run from pvbatch or pvpython. xxx here is PNG or JPEG, and the same problem may be present for others as well. This is a show-stopper.
The original report for this bug was submitted 11 days ago. it is still not assigned, so it is being submitted again.
Other relevant information
version: paraview.i686 3.6.2-1.fc12
output from glxinfo is attached as a text file.
TagsNo tags attached.
Project
Topic Name
Type
Attached Filestxt file icon glxinfo.txt [^] (9,960 bytes) 2010-04-15 12:29 [Show Content]
 Relationships
  Notes
(0020324)
Pat Marion (reporter)
2010-04-20 22:26
This bug existed in cvshead for a couple weeks and is now fixed as of 4/14/2010
http://public.kitware.com/cgi-bin/viewcvs.cgi/Servers/ServerManager/vtkSMUtilities.cxx?root=ParaView3&r1=1.4&r2=1.5 [^]
(0020326)
2010-04-20 22:41
Now I see this was submitted for version 3.6.2, so it is not related to the bug I fixed on 4/14/2010. Reopening this issue.
Mitch, can you try adding this line before the call to WriteImage:
GetActiveView().UseOffscreenRenderingForScreenshots = 0
(0027892)
Orion Poplawski (reporter)
2011-12-30 17:48
I've gotten a couple bug reports on this in Fedora. Using the command above does appear to fix the issue for me. Can this get properly fixed?
(0037809)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
 Issue History
2010-04-15 12:29 Mitch Nelson New Issue
2010-04-15 12:29 Mitch Nelson File Added: glxinfo.txt
2010-04-20 22:24 Pat Marion Status backlog => tabled
2010-04-20 22:24 Pat Marion Assigned To => Pat Marion
2010-04-20 22:26 Pat Marion Note Added: 0020324
2010-04-20 22:26 Pat Marion Status tabled => @80@
2010-04-20 22:26 Pat Marion Resolution open => fixed
2010-04-20 22:41 Pat Marion Assigned To Pat Marion =>
2010-04-20 22:41 Pat Marion Note Added: 0020326
2010-04-20 22:41 Pat Marion Status @80@ => @20@
2010-04-20 22:41 Pat Marion Resolution fixed => reopened
2011-12-30 17:48 Orion Poplawski Note Added: 0027892
2016-08-12 09:58 Kitware Robot Note Added: 0037809
2016-08-12 09:58 Kitware Robot Status expired => closed
2016-08-12 09:58 Kitware Robot Resolution reopened => moved
2016-08-12 09:58 Kitware Robot Assigned To => Kitware Robot
