#include <libxml/xmlexports.h>
| #define | LIBXML_DOTTED_VERSION "2.6.27" |
| LIBXML_DOTTED_VERSION: More... | |
| #define | LIBXML_VERSION 20627 |
| LIBXML_VERSION: More... | |
| #define | LIBXML_VERSION_STRING "20627" |
| LIBXML_VERSION_STRING: More... | |
| #define | LIBXML_VERSION_EXTRA "" |
| LIBXML_VERSION_EXTRA: More... | |
| #define | LIBXML_TEST_VERSION xmlCheckVersion(20627); |
| LIBXML_TEST_VERSION: More... | |
| #define | WITHOUT_TRIO |
| WITHOUT_TRIO: More... | |
| #define | LIBXML_THREAD_ENABLED |
| LIBXML_THREAD_ENABLED: More... | |
| #define | LIBXML_THREAD_ALLOC_ENABLED |
| LIBXML_THREAD_ALLOC_ENABLED: More... | |
| #define | LIBXML_TREE_ENABLED |
| LIBXML_TREE_ENABLED: More... | |
| #define | LIBXML_OUTPUT_ENABLED |
| LIBXML_OUTPUT_ENABLED: More... | |
| #define | LIBXML_PUSH_ENABLED |
| LIBXML_PUSH_ENABLED: More... | |
| #define | LIBXML_READER_ENABLED |
| LIBXML_READER_ENABLED: More... | |
| #define | LIBXML_PATTERN_ENABLED |
| LIBXML_PATTERN_ENABLED: More... | |
| #define | LIBXML_WRITER_ENABLED |
| LIBXML_WRITER_ENABLED: More... | |
| #define | LIBXML_SAX1_ENABLED |
| LIBXML_SAX1_ENABLED: More... | |
| #define | LIBXML_VALID_ENABLED |
| LIBXML_FTP_ENABLED: More... | |
| #define | LIBXML_HTML_ENABLED |
| LIBXML_HTML_ENABLED: More... | |
| #define | LIBXML_C14N_ENABLED |
| LIBXML_LEGACY_ENABLED: More... | |
| #define | LIBXML_CATALOG_ENABLED |
| LIBXML_CATALOG_ENABLED: More... | |
| #define | LIBXML_DOCB_ENABLED |
| LIBXML_DOCB_ENABLED: More... | |
| #define | LIBXML_XPATH_ENABLED |
| LIBXML_XPATH_ENABLED: More... | |
| #define | LIBXML_XPTR_ENABLED |
| LIBXML_XPTR_ENABLED: More... | |
| #define | LIBXML_XINCLUDE_ENABLED |
| LIBXML_XINCLUDE_ENABLED: More... | |
| #define | LIBXML_ISO8859X_ENABLED |
| LIBXML_ICONV_ENABLED: More... | |
| #define | LIBXML_UNICODE_ENABLED |
| LIBXML_DEBUG_ENABLED: More... | |
| #define | LIBXML_REGEXP_ENABLED |
| LIBXML_REGEXP_ENABLED: More... | |
| #define | LIBXML_AUTOMATA_ENABLED |
| LIBXML_AUTOMATA_ENABLED: More... | |
| #define | LIBXML_SCHEMAS_ENABLED |
| LIBXML_EXPR_ENABLED: More... | |
| #define | LIBXML_SCHEMATRON_ENABLED |
| LIBXML_SCHEMATRON_ENABLED: More... | |
| #define | LIBXML_MODULES_ENABLED |
| LIBXML_MODULES_ENABLED: More... | |
| #define | LIBXML_MODULE_EXTENSION ".so" |
| LIBXML_MODULE_EXTENSION: More... | |
| #define | LIBXML_ZLIB_ENABLED |
| LIBXML_ZLIB_ENABLED: More... | |
| #define | ATTRIBUTE_UNUSED |
| LIBXML_LZMA_ENABLED: More... | |
| #define | LIBXML_ATTR_ALLOC_SIZE(x) |
| LIBXML_ATTR_ALLOC_SIZE: More... | |
| #define | LIBXML_ATTR_FORMAT(fmt, args) |
| LIBXML_ATTR_FORMAT: More... | |
| XMLPUBFUN void XMLCALL | xmlCheckVersion (int version) |
| #define LIBXML_DOTTED_VERSION "2.6.27" |
| #define LIBXML_VERSION 20627 |
LIBXML_VERSION:
the version number: 1.2.3 value is 10203
Definition at line 39 of file xmlversion.h.
| #define LIBXML_VERSION_STRING "20627" |
the version number string, 1.2.3 value is "10203"
Definition at line 46 of file xmlversion.h.
| #define LIBXML_VERSION_EXTRA "" |
extra version information, used to show a CVS compilation
Definition at line 53 of file xmlversion.h.
| #define LIBXML_TEST_VERSION xmlCheckVersion(20627); |
Macro to check that the libxml version in use is compatible with the version the software has been compiled against
Definition at line 61 of file xmlversion.h.
| #define WITHOUT_TRIO |
WITHOUT_TRIO:
defined if the trio support should not be configured in
Definition at line 77 of file xmlversion.h.
| #define LIBXML_THREAD_ENABLED |
Whether the thread support is configured in
Definition at line 94 of file xmlversion.h.
| #define LIBXML_THREAD_ALLOC_ENABLED |
Whether the allocation hooks are per-thread
Definition at line 103 of file xmlversion.h.
| #define LIBXML_TREE_ENABLED |
Whether the DOM like tree manipulation API support is configured in
Definition at line 112 of file xmlversion.h.
| #define LIBXML_OUTPUT_ENABLED |
Whether the serialization/saving support is configured in
Definition at line 121 of file xmlversion.h.
| #define LIBXML_PUSH_ENABLED |
Whether the push parsing interfaces are configured in
Definition at line 130 of file xmlversion.h.
| #define LIBXML_READER_ENABLED |
Whether the xmlReader parsing interface is configured in
Definition at line 139 of file xmlversion.h.
| #define LIBXML_PATTERN_ENABLED |
Whether the xmlPattern node selection interface is configured in
Definition at line 148 of file xmlversion.h.
| #define LIBXML_WRITER_ENABLED |
Whether the xmlWriter saving interface is configured in
Definition at line 157 of file xmlversion.h.
| #define LIBXML_SAX1_ENABLED |
Whether the older SAX1 interface is configured in
Definition at line 166 of file xmlversion.h.
| #define LIBXML_VALID_ENABLED |
LIBXML_FTP_ENABLED:
Whether the FTP support is configured in LIBXML_HTTP_ENABLED:
Whether the HTTP support is configured in LIBXML_VALID_ENABLED:
Whether the DTD validation support is configured in
Definition at line 193 of file xmlversion.h.
| #define LIBXML_HTML_ENABLED |
Whether the HTML support is configured in
Definition at line 202 of file xmlversion.h.
| #define LIBXML_C14N_ENABLED |
Whether the deprecated APIs are compiled in for compatibility LIBXML_C14N_ENABLED:
Whether the Canonicalization support is configured in
Definition at line 220 of file xmlversion.h.
| #define LIBXML_CATALOG_ENABLED |
Whether the Catalog support is configured in
Definition at line 229 of file xmlversion.h.
| #define LIBXML_DOCB_ENABLED |
Whether the SGML Docbook support is configured in
Definition at line 238 of file xmlversion.h.
| #define LIBXML_XPATH_ENABLED |
| #define LIBXML_XPTR_ENABLED |
| #define LIBXML_XINCLUDE_ENABLED |
Whether XInclude is configured in
Definition at line 265 of file xmlversion.h.
| #define LIBXML_ISO8859X_ENABLED |
Whether iconv support is available LIBXML_ICU_ENABLED:
Whether icu support is available LIBXML_ISO8859X_ENABLED:
Whether ISO-8859-* support is made available in case iconv is not
Definition at line 292 of file xmlversion.h.
| #define LIBXML_UNICODE_ENABLED |
Whether Debugging module is configured in DEBUG_MEMORY_LOCATION:
Whether the memory debugging is configured in LIBXML_DEBUG_RUNTIME:
Whether the runtime debugging is configured in LIBXML_UNICODE_ENABLED:
Whether the Unicode related interfaces are compiled in
Definition at line 328 of file xmlversion.h.
| #define LIBXML_REGEXP_ENABLED |
Whether the regular expressions interfaces are compiled in
Definition at line 337 of file xmlversion.h.
| #define LIBXML_AUTOMATA_ENABLED |
Whether the automata interfaces are compiled in
Definition at line 346 of file xmlversion.h.
| #define LIBXML_SCHEMAS_ENABLED |
Whether the formal expressions interfaces are compiled in
This code is unused and disabled unconditionally for now. LIBXML_SCHEMAS_ENABLED:
Whether the Schemas validation interfaces are compiled in
Definition at line 366 of file xmlversion.h.
| #define LIBXML_SCHEMATRON_ENABLED |
Whether the Schematron validation interfaces are compiled in
Definition at line 375 of file xmlversion.h.
| #define LIBXML_MODULES_ENABLED |
Whether the module interfaces are compiled in
Definition at line 384 of file xmlversion.h.
| #define LIBXML_MODULE_EXTENSION ".so" |
the string suffix used by dynamic modules (usually shared libraries)
Definition at line 390 of file xmlversion.h.
| #define LIBXML_ZLIB_ENABLED |
Whether the Zlib support is compiled in
Definition at line 399 of file xmlversion.h.
| #define ATTRIBUTE_UNUSED |
Whether the Lzma support is compiled in ATTRIBUTE_UNUSED:
Macro used to signal to GCC unused function parameters
Definition at line 465 of file xmlversion.h.
| #define LIBXML_ATTR_ALLOC_SIZE | ( | x | ) |
Macro used to indicate to GCC this is an allocator function
Definition at line 471 of file xmlversion.h.
| #define LIBXML_ATTR_FORMAT | ( | fmt, | |
| args | |||
LIBXML_ATTR_FORMAT:
Macro used to indicate to GCC the parameter are printf like
Definition at line 477 of file xmlversion.h.
| XMLPUBFUN void XMLCALL xmlCheckVersion | ( | int | version | ) |
