23 #ifndef vtkPVRenderViewDataDeliveryManager_h 24 #define vtkPVRenderViewDataDeliveryManager_h 28 #include "vtkRemotingViewsModule.h" 70 bool gather_before_delivery,
bool low_res,
int port = 0);
84 void SetRedistributionModeToUniquelyAssignBoundaryCells(
92 void RedistributeDataForOrderedCompositing(
bool use_lod);
100 void ClearRedistributedData(
bool use_load);
106 void SetOrderedCompositingConfiguration(
137 void ClearStreamedPieces();
145 void DeliverStreamedPieces(
unsigned int size,
unsigned int* keys);
151 bool GetRepresentationsReadyToStreamPieces(std::vector<unsigned int>& keys);
158 vtkGetMacro(UseRedistributedDataAsDeliveredData,
bool);
159 vtkSetMacro(UseRedistributedDataAsDeliveredData,
bool);
171 const std::vector<vtkBoundingBox>&
GetCuts()
const {
return this->Cuts; }
186 const std::vector<vtkBoundingBox>&
GetRawCuts()
const {
return this->RawCuts; }
196 int GetViewDataDistributionMode(
bool low_res)
const;
199 std::vector<vtkBoundingBox>
Cuts;
206 bool UseRedistributedDataAsDeliveredData =
false;
manager for data-delivery.
const std::vector< vtkBoundingBox > & GetCuts() const
Provides access to the "cuts" built by this class when doing ordered compositing. ...
const std::vector< int > & GetRawCutsRankAssignments() const
When using an internally generated kd-tree for ordered compositing, this method provides access to th...
virtual int GetDeliveredDataKey(bool low_res) const
Views that support changing of which ranks do the rendering at runtime based on things like data size...
std::vector< vtkBoundingBox > Cuts
std::vector< int > RawCutsRankAssignments
vtkPVDataRepresentation adds some ParaView specific API to data representations.
vtkTimeStamp RedistributionTimeStamp
baseclass for all ParaView views.
const std::vector< vtkBoundingBox > & GetRawCuts() const
vtkPVRenderView specific subclass of vtkPVDataDeliveryManager.
vtkTimeStamp GetCutsMTime() const
virtual void MoveData(vtkPVDataRepresentation *repr, bool low_res, int port)=0
This method is called to request that the subclass do appropriate transfer for the indicated represen...
std::vector< vtkBoundingBox > RawCuts
std::string LastCutsGeneratorToken
