vtkObjectFactory.cmake
1 #[==[
2 @file vtkObjectFactory.cmake
3
4 In VTK, certain classes can have what are called "implementations". When the
5 base class is requested, it instead looks into a list of available
6 implementations. One of the implementations is then constructed and returned
7 instead.
9 For instance, there is a `vtkRenderWindow` class in VTK. When this is
10 constructed, it instead actually returns a window for the X window system,
11 Cocoa, or Win32 depending on what is available.
12
13 VTK's implementation utilizes the [autoinit](@ref module-autoinit) logic of the
14 module system. A module which contains an object factory must declare itself as
15 `IMPLEMENTABLE` and modules which contain an implementation of an object
16 factory must claim that they `IMPLEMENTS` modules containing those base object
17 factories (a module may contain the object factory and an implementation; it
18 then says that it `IMPLEMENTS` itself).
19 #]==]
20
21 set(_vtkObjectFactory_source_dir "${CMAKE_CURRENT_LIST_DIR}")
22
23 #[==[
24 @brief Declare a factory override
25
26 Declare that a class in this module (the implementation) is an `OVERRIDE` for a
27 base class.
28
29 ~~~
31  BASE <base>
32  OVERRIDE <implementation>)
33 ~~~
34 #]==]
36  cmake_parse_arguments(PARSE_ARGV 0 _vtk_object_factory_declare
37  ""
38  "BASE;OVERRIDE"
39  "")
40
41  if (_vtk_object_factory_declare_UNPARSED_ARGUMENTS)
42  message(FATAL_ERROR
43  "Unparsed arguments for vtk_object_factory_declare: "
44  "${_vtk_object_factory_declare_UNPARSED_ARGUMENTS}")
45  endif ()
46
47  if (NOT DEFINED _vtk_object_factory_declare_BASE)
48  message(FATAL_ERROR
49  "The `BASE` argument is required.")
50  endif ()
51
52  if (NOT DEFINED _vtk_object_factory_declare_OVERRIDE)
53  message(FATAL_ERROR
54  "The `OVERRIDE` argument is required.")
55  endif ()
56
57  set_property(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}" APPEND
58  PROPERTY
59  _vtk_object_factory_overrides "${_vtk_object_factory_declare_OVERRIDE}")
60  set_property(DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}" APPEND
61  PROPERTY
62  "_vtk_object_factory_override_${_vtk_object_factory_declare_OVERRIDE}" "${_vtk_object_factory_declare_BASE}")
63 endfunction ()
64
65 #[==[
66 @brief Generate source for overrides in a module
67
68 A module may only have a single declaration of all its object factory
69 implementations. This function generates the source for all of the overrides
70 declared using @ref vtk_object_factory_declare.
71
72 ~~~
73 vtk_object_factory_configure(
74  SOURCE_FILE <variable>
75  [HEADER_FILE <variable>]
76  [EXPORT_MACRO <macro>]
77  [INITIAL_CODE <code>]
78  [EXTRA_INCLUDES <include>...])
79 ~~~
80
81  - `SOURCE_FILE`: (Required) A variable to set to the path to generated source
82  file.
83  - `HEADER_FILE`: (Recommended) A variable to set to the path to generated
84  header file. This should not be treated as a public header.
85  - `EXPORT_MACRO`: (Recommended) The export macro to add to the generated
86  class.
87  - `INITIAL_CODE`: C++ code to run when the object factory is initialized.
88  - `EXTRA_INCLUDES`: A list of headers to include. The header names need to
89  include the `<>` or `""` quoting.
90 #]==]
91 function (vtk_object_factory_configure)
92  if (NOT DEFINED _vtk_build_module)
93  message(FATAL_ERROR
94  "The `vtk_object_factory_configure` function needs to be run within a module context.")
95  endif ()
96
97  cmake_parse_arguments(PARSE_ARGV 0 _vtk_object_factory_configure
98  ""
99  "SOURCE_FILE;HEADER_FILE;INITIAL_CODE;EXPORT_MACRO"
100  "EXTRA_INCLUDES")
101
102  if (_vtk_object_factory_configure_UNPARSED_ARGUMENTS)
103  message(FATAL_ERROR
104  "Unparsed arguments for vtk_object_factory_configure: "
105  "${_vtk_object_factory_configure_UNPARSED_ARGUMENTS}")
106  endif ()
107
108  get_property(_vtk_object_factory_done
109  GLOBAL
110  PROPERTY "_vtk_object_factory_${_vtk_build_module}"
111  SET)
112  if (_vtk_object_factory_done)
113  message(FATAL_ERROR
114  "An object factory has already been created for ${_vtk_build_module}.")
115  else ()
116  set_property(GLOBAL
117  PROPERTY
118  "_vtk_object_factory_${_vtk_build_module}" 1)
119  endif ()
120
121  get_property(_vtk_object_factory_overrides
122  DIRECTORY
123  PROPERTY _vtk_object_factory_overrides)
124
125  if (NOT _vtk_object_factory_overrides)
126  message(WARNING
127  "The ${_vtk_build_module} is generating an object factory, but does not have any declared overrides.")
128  endif ()
129
130  set(_vtk_object_factory_doc
131  "Override for ${_vtk_build_module} module")
132
133  set(_vtk_object_factory_includes "")
134  set(_vtk_object_factory_functions "")
135  set(_vtk_object_factory_calls "")
136
137  foreach (_vtk_object_factory_extra_include IN LISTS _vtk_object_factory_configure_EXTRA_INCLUDES)
138  string(APPEND _vtk_object_factory_includes
139  "#include ${_vtk_object_factory_extra_include}\n")
140  endforeach ()
141
142  foreach (_vtk_object_factory_override IN LISTS _vtk_object_factory_overrides)
143  get_property(_vtk_object_factory_base
144  DIRECTORY
145  PROPERTY "_vtk_object_factory_override_${_vtk_object_factory_override}")
146  string(APPEND _vtk_object_factory_includes
147  "#include \"${_vtk_object_factory_override}.h\"\n")
148  string(APPEND _vtk_object_factory_functions
149  "VTK_CREATE_CREATE_FUNCTION(${_vtk_object_factory_override})\n")
150  string(APPEND _vtk_object_factory_calls
151  "this->RegisterOverride(\"${_vtk_object_factory_base}\", \"${_vtk_object_factory_override}\", \"${_vtk_object_factory_doc}\", 1, vtkObjectFactoryCreate${_vtk_object_factory_override});\n")
152  endforeach ()
153
154  get_property(_vtk_object_factory_library_name GLOBAL
155  PROPERTY "_vtk_module_${_vtk_build_module}_library_name")
156
157  set(_vtk_object_factory_overrides_header
158  "${CMAKE_CURRENT_BINARY_DIR}/${_vtk_object_factory_library_name}ObjectFactory.h")
159  set(_vtk_object_factory_overrides_source
160  "${CMAKE_CURRENT_BINARY_DIR}/${_vtk_object_factory_library_name}ObjectFactory.cxx")
161
162  configure_file(
163  "${_vtkObjectFactory_source_dir}/vtkObjectFactory.h.in"
164  "${_vtk_object_factory_overrides_header}"
165  @ONLY)
166  configure_file(
167  "${_vtkObjectFactory_source_dir}/vtkObjectFactory.cxx.in"
168  "${_vtk_object_factory_overrides_source}"
169  @ONLY)
170
171  if (_vtk_object_factory_configure_HEADER_FILE)
172  set("${_vtk_object_factory_configure_HEADER_FILE}"
173  "${_vtk_object_factory_overrides_header}"
174  PARENT_SCOPE)
175  endif ()
176
177  set("${_vtk_object_factory_configure_SOURCE_FILE}"
178  "${_vtk_object_factory_overrides_source}"
179  PARENT_SCOPE)
180 endfunction ()
on
function vtk_object_factory_declare()
Declare a factory override.
function vtk_object_factory_configure()
Generate source for overrides in a module.
