vtkIceTSynchronizedRenderers.h
3  Program: ParaView
4  Module: vtkIceTSynchronizedRenderers.h
5
6  Copyright (c) Kitware, Inc.
7  All rights reserved.
8  See Copyright.txt or http://www.paraview.org/HTML/Copyright.html for details.
9
10  This software is distributed WITHOUT ANY WARRANTY; without even
11  the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
12  PURPOSE. See the above copyright notice for more information.
13
14 =========================================================================*/
30 #ifndef vtkIceTSynchronizedRenderers_h
31 #define vtkIceTSynchronizedRenderers_h
32
33 #include "vtkIceTCompositePass.h" // needed for inline methods.
34 #include "vtkRemotingViewsModule.h" //needed for exports
36
37 class vtkCameraPass;
40
41 class VTKREMOTINGVIEWS_EXPORT vtkIceTSynchronizedRenderers : public vtkSynchronizedRenderers
42 {
43 public:
46  void PrintSelf(ostream& os, vtkIndent indent) override;
47
54  virtual void SetRenderer(vtkRenderer*) override;
55
60  void SetTileDimensions(int x, int y) { this->IceTCompositePass->SetTileDimensions(x, y); }
61
66  void SetTileMullions(int x, int y) { this->IceTCompositePass->SetTileMullions(x, y); }
67
74  {
75  this->IceTCompositePass->SetDataReplicatedOnAllProcesses(val);
76  }
77
83  {
84  this->IceTCompositePass->SetOrderedCompositingHelper(helper);
85  }
86
93  void SetUseOrderedCompositing(bool uoc)
94  {
95  this->IceTCompositePass->SetUseOrderedCompositing(uoc);
96  }
97
101  virtual void SetImageReductionFactor(int val) override;
102  virtual int GetImageReductionFactor() override
103  {
104  return this->IceTCompositePass->GetImageReductionFactor();
105  }
106
108
113  {
114  this->Superclass::SetParallelController(cont);
115  this->IceTCompositePass->SetController(cont);
116  }
118
120
123  void SetImageProcessingPass(vtkImageProcessingPass*);
124  vtkGetObjectMacro(ImageProcessingPass, vtkImageProcessingPass);
126
130  void SetUseDepthBuffer(bool);
131
137  void SetRenderEmptyImages(bool);
138
140
147  void SetRenderPass(vtkRenderPass*);
148  vtkGetObjectMacro(RenderPass, vtkRenderPass);
150
152
156  vtkGetObjectMacro(IceTCompositePass, vtkIceTCompositePass);
158
159 protected:
162
166  vtkRawImage& CaptureRenderedImage() override;
167
168  // We use vtkIceTCompositePass internally.
171
172  // User specified custom passes
175
176 private:
178  void operator=(const vtkIceTSynchronizedRenderers&) = delete;
179 };
180
181 #endif
vtkSynchronizedRenderers subclass that uses IceT for parallel rendering and compositing.
virtual void SetParallelController(vtkMultiProcessController *cont) override
Set the parallel message communicator.
virtual void SetImageReductionFactor(int)
Set this to true, if compositing must be done in a specific order.
void PrintSelf(ostream &os, vtkIndent indent)
Set the tile dimensions.
void SetDataReplicatedOnAllProcesses(bool val)
Set to true if data is replicated on all processes.
Set the tile mullions.
vtkImageProcessingPass * ImageProcessingPass
void SetOrderedCompositingHelper(vtkOrderedCompositingHelper *helper)
partition ordering that gives processes ordering.
static vtkSynchronizedRenderers * New()
virtual void SetRenderer(vtkRenderer *)
virtual vtkRawImage & CaptureRenderedImage()
IceT enabled render pass for distributed rendering.
helper to assist in determine process order when rendering
