2 @file vtkEncodeString.cmake
5 turn a file into a C
string. This is primarily used within a program so that
6 the
content does not need to be retrieved from the filesystem at runtime, but
7 can still be developed as a standalone file.
10 set(_vtkEncodeString_script_file
"${CMAKE_CURRENT_LIST_FILE}")
13 @brief Encode a file as a C
string at build time
15 Adds a rule to turn a file into a C
string. Note that any Unicode characters
16 will not be replaced with escaping, so it is recommended to avoid their usage
23 [EXPORT_SYMBOL <symbol>]
24 [EXPORT_HEADER <header>]
25 [HEADER_OUTPUT <variable>]
26 [SOURCE_OUTPUT <variable>]
27 [BINARY] [NUL_TERMINATE])
30 The only required variable is `INPUT`, however, it is likely that at least one
31 of `HEADER_OUTPUT` or `SOURCE_OUTPUT` will be required to add them to a
34 * `INPUT`: (Required) The path to the file to be embedded. If a relative path
35 is given, it will be interpreted as being relative to
36 `CMAKE_CURRENT_SOURCE_DIR`.
37 * `NAME`: This is the base name of the files that will be generated as well
38 as the variable name
for the C
string. It defaults to the basename of the
39 input without extensions.
40 * `EXPORT_SYMBOL`: The symbol to use
for exporting the variable. By
default,
41 it will not be exported. If
set, `EXPORT_HEADER` must also be
set.
42 * `EXPORT_HEADER`: The header to include
for providing the given export
43 symbol. If
set, `EXPORT_SYMBOL` should also be
set.
44 * `HEADER_OUTPUT`: The variable to store the generated header path.
45 * `SOURCE_OUTPUT`: The variable to store the generated source path.
46 * `BINARY`: If given, the data will be written as an array of `
unsigned char`
48 * `NUL_TERMINATE`: If given, the binary data will be `NUL`-terminated. Only
49 makes sense with the `BINARY` flag. This is intended to be used
if 50 embedding a file as a C
string exceeds compiler limits on
string literals
54 cmake_parse_arguments(PARSE_ARGV 0 _vtk_encode_string
55 "BINARY;NUL_TERMINATE" 56 "INPUT;NAME;EXPORT_SYMBOL;EXPORT_HEADER;HEADER_OUTPUT;SOURCE_OUTPUT" 59 if (_vtk_encode_string_UNPARSED_ARGUMENTS)
61 "Unrecognized arguments to vtk_encode_string: " 62 "${_vtk_encode_string_UNPARSED_ARGUMENTS}")
65 if (NOT DEFINED _vtk_encode_string_INPUT)
70 if (NOT DEFINED _vtk_encode_string_NAME)
71 get_filename_component(_vtk_encode_string_NAME
72 "${_vtk_encode_string_INPUT}
" NAME_WE) 75 if (DEFINED _vtk_encode_string_EXPORT_SYMBOL AND 76 NOT DEFINED _vtk_encode_string_EXPORT_HEADER) 78 "Missing `EXPORT_HEADER` when
using `EXPORT_SYMBOL`.
") 81 if (DEFINED _vtk_encode_string_EXPORT_HEADER AND 82 NOT DEFINED _vtk_encode_string_EXPORT_SYMBOL) 84 "Missing `EXPORT_SYMBOL` when
using `EXPORT_HEADER`.
") 87 if (NOT _vtk_encode_string_BINARY AND _vtk_encode_string_NUL_TERMINATE) 89 "The `NUL_TERMINATE` flag only makes sense with the `BINARY` flag.
") 92 set(_vtk_encode_string_header 93 "${CMAKE_CURRENT_BINARY_DIR}/${_vtk_encode_string_NAME}.h
") 94 set(_vtk_encode_string_source 95 "${CMAKE_CURRENT_BINARY_DIR}/${_vtk_encode_string_NAME}.cxx
") 97 if (IS_ABSOLUTE "${_vtk_encode_string_INPUT}
") 98 set(_vtk_encode_string_input 99 "${_vtk_encode_string_INPUT}
") 101 set(_vtk_encode_string_input 102 "${CMAKE_CURRENT_SOURCE_DIR}/${_vtk_encode_string_INPUT}
") 106 OUTPUT ${_vtk_encode_string_header} 107 ${_vtk_encode_string_source} 108 DEPENDS "${_vtkEncodeString_script_file}
" 109 "${_vtk_encode_string_input}
" 110 COMMAND "${CMAKE_COMMAND}
" 111 "-Dsource_dir=${CMAKE_CURRENT_SOURCE_DIR}
" 112 "-Dbinary_dir=${CMAKE_CURRENT_BINARY_DIR}
" 113 "-Dsource_file=${_vtk_encode_string_input}
" 114 "-Doutput_name=${_vtk_encode_string_NAME}
" 115 "-Dexport_symbol=${_vtk_encode_string_EXPORT_SYMBOL}
" 116 "-Dexport_header=${_vtk_encode_string_EXPORT_HEADER}
" 117 "-Dbinary=${_vtk_encode_string_BINARY}
" 118 "-Dnul_terminate=${_vtk_encode_string_NUL_TERMINATE}
" 119 "-D_vtk_encode_string_run=ON
" 120 -P "${_vtkEncodeString_script_file}
") 122 if (DEFINED _vtk_encode_string_SOURCE_OUTPUT) 123 set("${_vtk_encode_string_SOURCE_OUTPUT}
" 124 "${_vtk_encode_string_source}
" 128 if (DEFINED _vtk_encode_string_HEADER_OUTPUT) 129 set("${_vtk_encode_string_HEADER_OUTPUT}
" 130 "${_vtk_encode_string_header}
" 135 if (_vtk_encode_string_run AND CMAKE_SCRIPT_MODE_FILE) 136 set(output_header "${binary_dir}/${output_name}.h
") 137 set(output_source "${binary_dir}/${output_name}.cxx
") 139 file(WRITE "${output_header}
" "") 140 file(WRITE "${output_source}
" "") 142 file(APPEND "${output_header}
" 143 "#ifndef ${output_name}_h\n#define ${output_name}_h\n\n
") 145 file(APPEND "${output_header}
" 146 "#include \
"${export_header}\"\n\n${export_symbol} ")
149 if (IS_ABSOLUTE
"${source_file}")
150 set(source_file_full
"${source_file}")
152 set(source_file_full
"${source_dir}/${source_file}")
158 file(READ
"${source_file_full}" original_content ${hex_arg})
162 string(APPEND original_content
"00")
164 string(LENGTH
"${original_content}" output_size)
165 math(EXPR output_size
"${output_size} / 2")
166 file(APPEND
"${output_header}" 167 "extern const unsigned char ${output_name}[${output_size}];\n\n#endif\n")
169 file(APPEND
"${output_source}" 170 "#include \"${output_name}.h\"\n\nconst unsigned char ${output_name}[${output_size}] = {\n")
171 string(REGEX REPLACE
"\([0-9a-f][0-9a-f]\)" ",0x\\1" escaped_content
"${original_content}")
172 # Hard line wrap the file. 173 string(REGEX REPLACE
"\(..........................................................................,\)" "\\1\n" escaped_content
"${escaped_content}")
174 # Remove the leading comma. 175 string(REGEX REPLACE
"^," "" escaped_content
176 file(APPEND
"${output_source}" 177 "${escaped_content}\n")
178 file(APPEND
"${output_source}" 181 file(APPEND
"${output_header}" 182 "extern const char *${output_name};\n\n#endif\n")
184 # Escape literal backslashes. 185 string(REPLACE
"\\" "\\\\" escaped_content
186 # Escape literal double quotes. 187 string(REPLACE
"\"" "\\\"" escaped_content
188 # Turn newlines into newlines in the C string. 189 string(REPLACE
"\n" "\\n\"\n\"" escaped_content
191 file(APPEND
"${output_source}" 192 "#include \"${output_name}.h\"\n\nconst char *${output_name} =\n")
193 file(APPEND
"${output_source}" 194 "\"${escaped_content}\";\n")
function vtk_encode_string()
Encode a file as a C string at build time.
