2 @brief Detect library
type of a library
4 Sometimes it needs to be known whether a library is shared or
static on a
5 system in
order to change the usage requirements of an imported
target 6 representing that library. This commonly occurs between
static and shared
7 builds that share a
set of installed headers. This
function returns one of
8 `SHARED`, `STATIC`, or `UNKNOWN` into the variable passed as the first
17 cmake_parse_arguments(PARSE_ARGV 1 vdlt
22 if (NOT DEFINED vdlt_PATH)
24 "The `PATH` argument is required.")
27 if (DEFINED vdlt_UNPARSED_ARGUMENTS)
30 "${vdlt_UNPARSED_ARGUMENTS}
") 35 "The `PATH` argument is empty.
") 38 set(vdlt_type UNKNOWN) 39 # Windows libraries all end with `.lib`. We need to detect the type based on 40 # the contents of the library. However, MinGW does use different extensions. 41 if (WIN32 AND NOT MINGW) 42 find_program(DUMPBIN_EXECUTABLE 44 DOC "Path to the dumpbin executable
") 45 mark_as_advanced(DUMPBIN_EXECUTABLE) 47 COMMAND "${DUMPBIN_EXECUTABLE}
" 50 OUTPUT_VARIABLE vdlt_out 51 ERROR_VARIABLE vdlt_err 52 RESULT_VARIABLE vdlt_res) 55 "Failed to run `dumpbin`
on ${vdlt_PATH}. Cannot determine
" 56 "shared/
static library
type: ${vdlt_err}
") 58 if (vdlt_out MATCHES "DLL
name :
") 65 string(LENGTH "${vdlt_PATH}
" vdlt_path_len) 67 string(LENGTH "${CMAKE_SHARED_LIBRARY_SUFFIX}
" vdlt_shared_suffix_len) 68 math(EXPR vdlt_shared_idx "${vdlt_path_len} - ${vdlt_shared_suffix_len}
") 69 string(SUBSTRING "${vdlt_PATH}
" "${vdlt_shared_idx}
" -1 vdlt_shared_check) 71 string(LENGTH "${CMAKE_STATIC_LIBRARY_SUFFIX}
" vdlt_static_suffix_len) 72 math(EXPR vdlt_static_idx "${vdlt_path_len} - ${vdlt_static_suffix_len}
") 73 string(SUBSTRING "${vdlt_PATH}
" "${vdlt_static_idx}
" -1 vdlt_static_check) 75 if (vdlt_shared_check STREQUAL CMAKE_SHARED_LIBRARY_SUFFIX) 77 elseif (vdlt_static_check STREQUAL CMAKE_STATIC_LIBRARY_SUFFIX) 81 # when import suffix != static suffix, we can disambiguate static and import 82 if (WIN32 AND NOT CMAKE_IMPORT_LIBRARY_SUFFIX STREQUAL CMAKE_STATIC_LIBRARY_SUFFIX) 83 string(LENGTH "${CMAKE_IMPORT_LIBRARY_SUFFIX}
" vdlt_import_suffix_len) 84 math(EXPR vdlt_import_idx "${vdlt_path_len} - ${vdlt_import_suffix_len}
") 85 string(SUBSTRING "${vdlt_PATH}
" "${vdlt_import_idx}
" -1 vdlt_import_check) 86 if (vdlt_import_check STREQUAL CMAKE_IMPORT_LIBRARY_SUFFIX) 98 @brief Detect whether an imported target is shared or not 100 This is intended for use with modules using 101 @ref vtk_module_third_party_external to detect whether that module is shared or 102 not. Generally, this should be replaced with the `Find` module providing this 103 information and modifying the usage requirements as necessary instead, but it 104 is not always possible. 107 vtk_detect_library_shared(<name> <target>) 110 Sets `<name>_is_shared` in the caller's scope if `<target>` is a shared 111 library. If it is an `UNKNOWN_LIBRARY`, a cache variable is exposed to allow 112 the user to provide the information if it ends up breaking something. 114 function (vtk_detect_library_shared name target) 115 if (VTK_MODULE_USE_EXTERNAL_${name}) 116 get_property(library_type 119 if (library_type STREQUAL "SHARED_LIBRARY
") 121 elseif (library_type STREQUAL "UNKNOWN_LIBRARY
") 122 option("VTK_MODULE_${
name}_IS_SHARED
" "Whether the ${
name} in use is shared or not
" ON) 123 mark_as_advanced("VTK_MODULE_${
name}_IS_SHARED
") 124 set(is_shared "${VTK_MODULE_${
name}_IS_SHARED}
") 132 set("${
name}_is_shared
function vtk_detect_library_type(output)
Detect library type of a library.
#define BUILD_SHARED_LIBS
