Header file for verdict library that calculates metrics for finite elements. Also see: Main Page. More...
#include "verdict_mangle.h"
| struct | HexMetricVals |
| A struct to hold values computed by v_hex_quality. More... | |
| struct | EdgeMetricVals |
| A struct to hold values computed by v_edge_quality. More... | |
| struct | KnifeMetricVals |
| A struct to hold values computed by v_knife_quality. More... | |
| struct | QuadMetricVals |
| A struct to hold values computed by v_quad_quality. More... | |
| struct | PyramidMetricVals |
| A struct to hold values computed by v_pyramid_quality. More... | |
| struct | WedgeMetricVals |
| A struct to hold values computed by v_wedge_quality. More... | |
| struct | TetMetricVals |
| A struct to hold values computed by v_tet_quality. More... | |
| struct | TriMetricVals |
| A struct to hold values computed by v_tri_quality. More... | |
| #define | VERDICT_VERSION 120 |
| #define | BUILD_SHARED_LIBS |
| #define | VERDICT_SHARED_LIB |
| #define | VERDICT_MANGLE |
| #define | VERDICT_DBL_MIN 1.0E-30 |
| #define | VERDICT_DBL_MAX 1.0E+30 |
| #define | VERDICT_PI 3.1415926535897932384626 |
| #define | VERDICT_ABI_IMPORT |
| #define | VERDICT_ABI_EXPORT |
| #define | C_FUNC_DEF VERDICT_EXTERN_C VERDICT_ABI_IMPORT |
Atomic hex quality flags | |
| #define | V_HEX_MAX_EDGE_RATIO |
| Request that the maximum edge ratio be computed. More... | |
| #define | V_HEX_SKEW |
| Request that skew be computed. More... | |
| #define | V_HEX_TAPER |
| Request that taper be computed. More... | |
| #define | V_HEX_VOLUME |
| Request that volume be computed. More... | |
| #define | V_HEX_STRETCH |
| Request that stretch be computed. More... | |
| #define | V_HEX_DIAGONAL |
| Request that the diagonal be computed. More... | |
| #define | V_HEX_DIMENSION |
| Request that the dimension be computed. More... | |
| #define | V_HEX_ODDY |
| Request that the Oddy quality be computed. More... | |
| #define | V_HEX_MAX_ASPECT_FROBENIUS |
| Request that maximum Frobenius aspect be computed. More... | |
| #define | V_HEX_CONDITION |
| Request that the condition be computed. More... | |
| #define | V_HEX_JACOBIAN |
| Request that the Jacobian be computed. More... | |
| #define | V_HEX_SCALED_JACOBIAN |
| Request that the scaled Jacobian be computed. More... | |
| #define | V_HEX_SHEAR |
| Request that shear be computed. More... | |
| #define | V_HEX_SHAPE |
| Request that shape be computed. More... | |
| #define | V_HEX_RELATIVE_SIZE_SQUARED |
| Request that the square of the relative size be computed. More... | |
| #define | V_HEX_SHAPE_AND_SIZE |
| Request that the product of shape and size be computed. More... | |
| #define | V_HEX_SHEAR_AND_SIZE |
| Request that the product of shear and size be computed. More... | |
| #define | V_HEX_DISTORTION |
| Request that distortion be computed. More... | |
| #define | V_HEX_EDGE_RATIO |
| Request that the edge ratio be computed. More... | |
| #define | V_HEX_MED_ASPECT_FROBENIUS |
| Request that average Frobenius aspect be computed. More... | |
Composite hex quality flags | |
These flags are bitwise combinations of the atomic flags above. | |
| #define | V_HEX_ALL |
| Request that all hex metrics be computed. More... | |
| #define | V_HEX_TRADITIONAL |
| Request the traditional hex qualities be computed. More... | |
| #define | V_HEX_DIAGNOSTIC |
| Request hex qualities used to diagnose mesh or solver problems. More... | |
| #define | V_HEX_ALGEBRAIC |
| Request hex qualities that have an algebraic expression be computed. More... | |
| #define | V_HEX_ROBINSON |
| Request hex qualities for Mr. Robinson. More... | |
Atomic tetrahedral quality flags | |
| #define | V_TET_RADIUS_RATIO |
| Request that the radius ratio be computed. More... | |
| #define | V_TET_ASPECT_BETA |
| Request that the aspect ratio beta be computed. More... | |
| #define | V_TET_ASPECT_GAMMA |
| Request that the aspect ratio gamma be computed. More... | |
| #define | V_TET_VOLUME |
| Request that the volume be computed. More... | |
| #define | V_TET_CONDITION |
| #define | V_TET_JACOBIAN |
| #define | V_TET_SCALED_JACOBIAN |
| #define | V_TET_SHAPE |
| Request that the shape be computed. More... | |
| #define | V_TET_RELATIVE_SIZE_SQUARED |
| #define | V_TET_SHAPE_AND_SIZE |
| #define | V_TET_DISTORTION |
| Request that the distortion be computed. More... | |
| #define | V_TET_EDGE_RATIO |
| Request that the ratio of edge lengths be computed. More... | |
| #define | V_TET_ASPECT_RATIO |
| Request that the aspect ratio be computed. More... | |
| #define | V_TET_ASPECT_FROBENIUS |
| Request that the Frobenius aspect be computed. More... | |
| #define | V_TET_MINIMUM_ANGLE |
| Request that the minimum dihedral angle be computed. More... | |
| #define | V_TET_COLLAPSE_RATIO |
| Request that the collapse ratio be computed. More... | |
| #define | V_TET_EQUIVOLUME_SKEW |
| Request that the equivolume skew as defined by Fluent be computed. More... | |
| #define | V_TET_SQUISH_INDEX |
| Request that the squish index as defined by Fluent be computed. More... | |
| #define | V_TET_ALL |
| Composite tetrahedral quality flags These flags are bitwise combinations of the atomic flags above. More... | |
| #define | V_TET_TRADITIONAL |
| Request that the tradtional tetrahedral qualities be computed. More... | |
| #define | V_TET_DIAGNOSTIC |
| #define | V_TET_ALGEBRAIC |
Pyramid bit fields | |
| #define | V_PYRAMID_VOLUME |
| #define | V_PYRAMID_ALL |
Wedge bit fields | |
| #define | V_WEDGE_VOLUME |
| #define | V_WEDGE_EDGE_RATIO 2 |
| #define | V_WEDGE_MAX_ASPECT_FROBENIUS 4 |
| #define | V_WEDGE_MEAN_ASPECT_FROBENIUS 8 |
| #define | V_WEDGE_JACOBIAN 16 |
| #define | V_WEDGE_SCALED_JACOBIAN 32 |
| #define | V_WEDGE_DISTORTION 64 |
| #define | V_WEDGE_MAX_STRETCH 128 |
| #define | V_WEDGE_SHAPE 256 |
| #define | V_WEDGE_CONDITION 512 |
| #define | V_WEDGE_ALL |
Knife bit fields | |
| #define | V_KNIFE_VOLUME |
| #define | V_KNIFE_ALL |
Quad bit fields | |
| #define | V_QUAD_MAX_EDGE_RATIO |
| #define | V_QUAD_SKEW |
| #define | V_QUAD_TAPER |
| #define | V_QUAD_WARPAGE |
| #define | V_QUAD_AREA |
| #define | V_QUAD_STRETCH |
| #define | V_QUAD_MINIMUM_ANGLE |
| #define | V_QUAD_MAXIMUM_ANGLE |
| #define | V_QUAD_ODDY |
| #define | V_QUAD_CONDITION |
| #define | V_QUAD_JACOBIAN |
| #define | V_QUAD_SCALED_JACOBIAN |
| #define | V_QUAD_SHEAR |
| #define | V_QUAD_SHAPE |
| #define | V_QUAD_RELATIVE_SIZE_SQUARED |
| #define | V_QUAD_SHAPE_AND_SIZE |
| #define | V_QUAD_SHEAR_AND_SIZE |
| #define | V_QUAD_DISTORTION |
| #define | V_QUAD_EDGE_RATIO |
| #define | V_QUAD_ASPECT_RATIO |
| #define | V_QUAD_RADIUS_RATIO |
| #define | V_QUAD_MED_ASPECT_FROBENIUS |
| #define | V_QUAD_MAX_ASPECT_FROBENIUS |
| #define | V_QUAD_ALL |
| #define | V_QUAD_TRADITIONAL |
| #define | V_QUAD_DIAGNOSTIC |
| #define | V_QUAD_ALGEBRAIC |
| #define | V_QUAD_ROBINSON |
Tri bit fields | |
| #define | V_TRI_ASPECT_FROBENIUS |
| #define | V_TRI_AREA |
| #define | V_TRI_MINIMUM_ANGLE |
| #define | V_TRI_MAXIMUM_ANGLE |
| #define | V_TRI_CONDITION |
| #define | V_TRI_SCALED_JACOBIAN |
| #define | V_TRI_SHAPE |
| #define | V_TRI_RELATIVE_SIZE_SQUARED |
| #define | V_TRI_SHAPE_AND_SIZE |
| #define | V_TRI_DISTORTION |
| #define | V_TRI_RADIUS_RATIO |
| #define | V_TRI_EDGE_RATIO |
| #define | V_TRI_ALL |
| #define | V_TRI_TRADITIONAL |
| #define | V_TRI_DIAGNOSTIC |
| #define | V_TRI_ALGEBRAIC |
| #define | V_EDGE_LENGTH |
| #define | V_EDGE_ALL |
Typedefs | |
| typedef double(* | VerdictFunction) (int, double[][3]) |
| typedef int(* | ComputeNormal) (double point[3], double normal[3]) |
| C_FUNC_DEF void | v_hex_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct HexMetricVals *metric_vals) |
| Calculates quality metrics for hexahedral elements. More... | |
| C_FUNC_DEF void | v_tet_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct TetMetricVals *metric_vals) |
| Calculates quality metrics for tetrahedral elements. More... | |
| C_FUNC_DEF void | v_pyramid_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct PyramidMetricVals *metric_vals) |
| Calculates quality metrics for pyramid elements. More... | |
| C_FUNC_DEF void | v_wedge_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct WedgeMetricVals *metric_vals) |
| Calculates quality metrics for wedge elements. More... | |
| C_FUNC_DEF void | v_knife_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct KnifeMetricVals *metric_vals) |
| Calculates quality metrics for knife elements. More... | |
| C_FUNC_DEF void | v_quad_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct QuadMetricVals *metric_vals) |
| Calculates quality metrics for quadralateral elements. More... | |
| C_FUNC_DEF void | v_tri_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct TriMetricVals *metric_vals) |
| Calculates quality metrics for triangle elements. More... | |
| C_FUNC_DEF void | v_edge_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, struct EdgeMetricVals *metric_vals) |
| Calculates quality metrics for edge elements. More... | |
| C_FUNC_DEF void | v_set_hex_size (double size) |
| Sets average size (volume) of hex, needed for v_hex_relative_size(...) More... | |
| C_FUNC_DEF double | v_hex_edge_ratio (int num_nodes, double coordinates[][3]) |
| Calculates hex edge ratio metric. More... | |
| C_FUNC_DEF double | v_hex_max_edge_ratio (int num_nodes, double coordinates[][3]) |
| Calculates hex maximum of edge ratio. More... | |
| C_FUNC_DEF double | v_hex_skew (int num_nodes, double coordinates[][3]) |
| Calculates hex skew metric. More... | |
| C_FUNC_DEF double | v_hex_taper (int num_nodes, double coordinates[][3]) |
| Calculates hex taper metric. More... | |
| C_FUNC_DEF double | v_hex_volume (int num_nodes, double coordinates[][3]) |
| Calculates hex volume. More... | |
| C_FUNC_DEF double | v_hex_stretch (int num_nodes, double coordinates[][3]) |
| Calculates hex stretch metric. More... | |
| C_FUNC_DEF double | v_hex_diagonal (int num_nodes, double coordinates[][3]) |
| Calculates hex diagonal metric. More... | |
| C_FUNC_DEF double | v_hex_dimension (int num_nodes, double coordinates[][3]) |
| Calculates hex dimension metric. More... | |
| C_FUNC_DEF double | v_hex_oddy (int num_nodes, double coordinates[][3]) |
| Calculates hex oddy metric. More... | |
| C_FUNC_DEF double | v_hex_med_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| Calculates hex condition metric. More... | |
| C_FUNC_DEF double | v_hex_max_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_hex_condition (int num_nodes, double coordinates[][3]) |
| Calculates hex condition metric. This is a synonym for v_hex_max_aspect_frobenius. More... | |
| C_FUNC_DEF double | v_hex_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates hex jacobian metric. More... | |
| C_FUNC_DEF double | v_hex_scaled_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates hex scaled jacobian metric. More... | |
| C_FUNC_DEF double | v_hex_shear (int num_nodes, double coordinates[][3]) |
| Calculates hex shear metric. More... | |
| C_FUNC_DEF double | v_hex_shape (int num_nodes, double coordinates[][3]) |
| Calculates hex shape metric. More... | |
| C_FUNC_DEF double | v_hex_relative_size_squared (int num_nodes, double coordinates[][3]) |
| Calculates hex relative size metric. More... | |
| C_FUNC_DEF double | v_hex_shape_and_size (int num_nodes, double coordinates[][3]) |
| Calculates hex shape-size metric. More... | |
| C_FUNC_DEF double | v_hex_shear_and_size (int num_nodes, double coordinates[][3]) |
| Calculates hex shear-size metric. More... | |
| C_FUNC_DEF double | v_hex_distortion (int num_nodes, double coordinates[][3]) |
| Calculates hex distortion metric. More... | |
| C_FUNC_DEF void | v_set_tet_size (double size) |
| Sets average size (volume) of tet, needed for v_tet_relative_size(...) More... | |
| C_FUNC_DEF double | v_tet_edge_ratio (int num_nodes, double coordinates[][3]) |
| Calculates tet edge ratio metric. More... | |
| C_FUNC_DEF double | v_tet_radius_ratio (int num_nodes, double coordinates[][3]) |
| Calculates tet radius ratio metric. More... | |
| C_FUNC_DEF double | v_tet_aspect_beta (int num_nodes, double coordinates[][3]) |
| Calculates the radius ratio metric of a positively oriented tet. More... | |
| C_FUNC_DEF double | v_tet_aspect_ratio (int num_nodes, double coordinates[][3]) |
| Calculates tet aspect ratio metric. More... | |
| C_FUNC_DEF double | v_tet_aspect_gamma (int num_nodes, double coordinates[][3]) |
| Calculates tet aspect gamma metric. More... | |
| C_FUNC_DEF double | v_tet_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| Calculates tet aspect frobenius metric. More... | |
| C_FUNC_DEF double | v_tet_minimum_angle (int num_nodes, double coordinates[][3]) |
| Calculates tet minimum dihedral angle. More... | |
| C_FUNC_DEF double | v_tet_collapse_ratio (int num_nodes, double coordinates[][3]) |
| Calculates tet collapse ratio metric. More... | |
| C_FUNC_DEF double | v_tet_volume (int num_nodes, double coordinates[][3]) |
| Calculates tet volume. More... | |
| C_FUNC_DEF double | v_tet_condition (int num_nodes, double coordinates[][3]) |
| Calculates tet condition metric. More... | |
| C_FUNC_DEF double | v_tet_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates tet jacobian. More... | |
| C_FUNC_DEF double | v_tet_scaled_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates tet scaled jacobian. More... | |
| C_FUNC_DEF double | v_tet_shape (int num_nodes, double coordinates[][3]) |
| Calculates tet shape metric. More... | |
| C_FUNC_DEF double | v_tet_relative_size_squared (int num_nodes, double coordinates[][3]) |
| Calculates tet relative size metric. More... | |
| C_FUNC_DEF double | v_tet_shape_and_size (int num_nodes, double coordinates[][3]) |
| Calculates tet shape-size metric. More... | |
| C_FUNC_DEF double | v_tet_distortion (int num_nodes, double coordinates[][3]) |
| Calculates tet distortion metric. More... | |
| C_FUNC_DEF double | v_pyramid_volume (int num_nodes, double coordinates[][3]) |
| Calculates pyramid volume. More... | |
| C_FUNC_DEF double | v_wedge_volume (int num_nodes, double coordinates[][3]) |
| Calculates wedge volume. More... | |
| C_FUNC_DEF double | v_wedge_edge_ratio (int num_nodes, double coordinates[][3]) |
| Calculates wedge edge ratio metric. More... | |
| C_FUNC_DEF double | v_wedge_max_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| Calculates wedge max aspect forbenius. More... | |
| C_FUNC_DEF double | v_wedge_mean_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| Calculates wedge mean aspect forbenius. More... | |
| C_FUNC_DEF double | v_wedge_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates wedge jacobian metric. More... | |
| C_FUNC_DEF double | v_wedge_distortion (int num_nodes, double coordinates[][3]) |
| Calculates wedge distortion metric. More... | |
| C_FUNC_DEF double | v_wedge_max_stretch (int num_nodes, double coordinates[][3]) |
| Calculates the wedge stretch. More... | |
| C_FUNC_DEF double | v_wedge_scaled_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates wedge scaled jacobian metric. More... | |
| C_FUNC_DEF double | v_wedge_shape (int num_nodes, double coordinates[][3]) |
| Calculates the wedge shape metric. More... | |
| C_FUNC_DEF double | v_wedge_condition (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_knife_volume (int num_nodes, double coordinates[][3]) |
| Calculates knife volume. More... | |
| C_FUNC_DEF double | v_edge_length (int num_nodes, double coordinates[][3]) |
| Calculates edge length. More... | |
| C_FUNC_DEF void | v_set_quad_size (double size) |
| Sets average size (area) of quad, needed for v_quad_relative_size(...) More... | |
| C_FUNC_DEF double | v_quad_edge_ratio (int num_nodes, double coordinates[][3]) |
| Calculates quad edge ratio. More... | |
| C_FUNC_DEF double | v_quad_max_edge_ratio (int num_nodes, double coordinates[][3]) |
| Calculates quad maximum of edge ratio. More... | |
| C_FUNC_DEF double | v_quad_aspect_ratio (int num_nodes, double coordinates[][3]) |
| Calculates quad aspect ratio. More... | |
| C_FUNC_DEF double | v_quad_radius_ratio (int num_nodes, double coordinates[][3]) |
| Calculates quad radius ratio. More... | |
| C_FUNC_DEF double | v_quad_med_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| Calculates quad average Frobenius aspect. More... | |
| C_FUNC_DEF double | v_quad_max_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| Calculates quad maximum Frobenius aspect. More... | |
| C_FUNC_DEF double | v_quad_skew (int num_nodes, double coordinates[][3]) |
| Calculates quad skew metric. More... | |
| C_FUNC_DEF double | v_quad_taper (int num_nodes, double coordinates[][3]) |
| Calculates quad taper metric. More... | |
| C_FUNC_DEF double | v_quad_warpage (int num_nodes, double coordinates[][3]) |
| Calculates quad warpage metric. More... | |
| C_FUNC_DEF double | v_quad_area (int num_nodes, double coordinates[][3]) |
| Calculates quad area. More... | |
| C_FUNC_DEF double | v_quad_stretch (int num_nodes, double coordinates[][3]) |
| Calculates quad strech metric. More... | |
| C_FUNC_DEF double | v_quad_minimum_angle (int num_nodes, double coordinates[][3]) |
| Calculates quad's smallest angle. More... | |
| C_FUNC_DEF double | v_quad_maximum_angle (int num_nodes, double coordinates[][3]) |
| Calculates quad's largest angle. More... | |
| C_FUNC_DEF double | v_quad_oddy (int num_nodes, double coordinates[][3]) |
| Calculates quad oddy metric. More... | |
| C_FUNC_DEF double | v_quad_condition (int num_nodes, double coordinates[][3]) |
| Calculates quad condition number metric. More... | |
| C_FUNC_DEF double | v_quad_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates quad jacobian. More... | |
| C_FUNC_DEF double | v_quad_scaled_jacobian (int num_nodes, double coordinates[][3]) |
| Calculates quad scaled jacobian. More... | |
| C_FUNC_DEF double | v_quad_shear (int num_nodes, double coordinates[][3]) |
| Calculates quad shear metric. More... | |
| C_FUNC_DEF double | v_quad_shape (int num_nodes, double coordinates[][3]) |
| Calculates quad shape metric. More... | |
| C_FUNC_DEF double | v_quad_relative_size_squared (int num_nodes, double coordinates[][3]) |
| Calculates quad relative size metric. More... | |
| C_FUNC_DEF double | v_quad_shape_and_size (int num_nodes, double coordinates[][3]) |
| Calculates quad shape-size metric. More... | |
| C_FUNC_DEF double | v_quad_shear_and_size (int num_nodes, double coordinates[][3]) |
| Calculates quad shear-size metric. More... | |
| C_FUNC_DEF double | v_quad_distortion (int num_nodes, double coordinates[][3]) |
| Calculates quad distortion metric. More... | |
| C_FUNC_DEF void | v_set_tri_size (double size) |
| Sets average size (area) of tri, needed for v_tri_relative_size(...) More... | |
| C_FUNC_DEF void | v_set_tri_normal_func (ComputeNormal func) |
| Sets function pointer to calculate triangle normal wrt surface. More... | |
| C_FUNC_DEF double | v_tri_edge_ratio (int num_nodes, double coordinates[][3]) |
| Calculates triangle metric. More... | |
| C_FUNC_DEF double | v_tri_aspect_ratio (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_radius_ratio (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_aspect_frobenius (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_area (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_minimum_angle (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_maximum_angle (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_condition (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_scaled_jacobian (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_shear (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_relative_size_squared (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_shape (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_shape_and_size (int num_nodes, double coordinates[][3]) |
| C_FUNC_DEF double | v_tri_distortion (int num_nodes, double coordinates[][3]) |
verdict.h is the header file for applications/libraries to include to compute quality metrics.
This file is part of VERDICT
Definition in file verdict.h.
| #define C_FUNC_DEF VERDICT_EXTERN_C VERDICT_ABI_IMPORT |
| #define V_HEX_MAX_EDGE_RATIO |
| #define V_HEX_SKEW |
| #define V_HEX_TAPER |
| #define V_HEX_VOLUME |
| #define V_HEX_STRETCH |
| #define V_HEX_DIAGONAL |
| #define V_HEX_DIMENSION |
| #define V_HEX_ODDY |
| #define V_HEX_MAX_ASPECT_FROBENIUS |
| #define V_HEX_CONDITION |
| #define V_HEX_JACOBIAN |
| #define V_HEX_SCALED_JACOBIAN |
| #define V_HEX_SHEAR |
| #define V_HEX_SHAPE |
| #define V_HEX_RELATIVE_SIZE_SQUARED |
| #define V_HEX_SHAPE_AND_SIZE |
| #define V_HEX_SHEAR_AND_SIZE |
| #define V_HEX_DISTORTION |
| #define V_HEX_EDGE_RATIO |
| #define V_HEX_MED_ASPECT_FROBENIUS |
| #define V_HEX_ALL |
| #define V_HEX_TRADITIONAL |
This includes V_HEX_MAX_EDGE_RATIO, V_HEX_SKEW, V_HEX_TAPER V_HEX_STRETCH, V_HEX_DIAGONAL, V_HEX_ODDY, V_HEX_CONDITION, V_HEX_JACOBIAN, V_HEX_SCALED_JACOBIAN, and V_HEX_DIMENSION.
| #define V_HEX_DIAGNOSTIC |
This is currently a synonym for V_HEX_VOLUME but may include more qualities in the future.
| #define V_HEX_ALGEBRAIC |
This includes V_HEX_SHAPE, V_HEX_SHEAR, V_HEX_RELATIVE_SIZE_SQUARED, V_HEX_SHAPE_AND_SIZE, and V_HEX_SHEAR_AND_SIZE.
| #define V_HEX_ROBINSON |
| #define V_TET_RADIUS_RATIO |
| #define V_TET_ASPECT_BETA |
| #define V_TET_ASPECT_GAMMA |
| #define V_TET_VOLUME |
| #define V_TET_CONDITION |
| #define V_TET_JACOBIAN |
| #define V_TET_SCALED_JACOBIAN |
| #define V_TET_SHAPE |
| #define V_TET_RELATIVE_SIZE_SQUARED |
| #define V_TET_SHAPE_AND_SIZE |
| #define V_TET_DISTORTION |
| #define V_TET_EDGE_RATIO |
| #define V_TET_ASPECT_RATIO |
| #define V_TET_ASPECT_FROBENIUS |
| #define V_TET_MINIMUM_ANGLE |
| #define V_TET_COLLAPSE_RATIO |
| #define V_TET_EQUIVOLUME_SKEW |
| #define V_TET_SQUISH_INDEX |
| #define V_TET_ALL |
| #define V_TET_TRADITIONAL |
This includes V_TET_ASPECT_BETA, V_TET_ASPECT_GAMMA, V_TET_CONDITION, V_TET_JACOBIAN, and V_TET_SCALED_JACOBIAN.
| #define V_TET_DIAGNOSTIC |
This is currently a synonym for V_TET_VOLUME but may include more qualities in the future.
| #define V_TET_ALGEBRAIC |
This includes V_TET_SHAPE, V_TET_RELATIVE_SIZE_SQUARED, and V_TET_SHAPE_AND_SIZE.
| C_FUNC_DEF void v_hex_quality | ( | int | num_nodes, |
| double | coordinates[][3], | ||
| unsigned int | metrics_request_flag, | ||
| struct HexMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_tet_quality | ( | int | num_nodes, |
| struct TetMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_pyramid_quality | ( | int | num_nodes, |
| struct PyramidMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_wedge_quality | ( | int | num_nodes, |
| struct WedgeMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_knife_quality | ( | int | num_nodes, |
| struct KnifeMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_quad_quality | ( | int | num_nodes, |
| struct QuadMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_tri_quality | ( | int | num_nodes, |
| struct TriMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_edge_quality | ( | int | num_nodes, |
| struct EdgeMetricVals * | metric_vals | ||
| C_FUNC_DEF void v_set_hex_size | ( | double | size | ) |
| C_FUNC_DEF double v_hex_edge_ratio | ( | int | num_nodes, |
| double | coordinates[][3] | ||
Hmax / Hmin where Hmax and Hmin are respectively the maximum and the minimum edge lengths
| C_FUNC_DEF double v_hex_max_edge_ratio | ( | int | num_nodes, |
Maximum edge length ratio at hex center. Reference — L.M. Taylor, and D.P. Flanagan, Pronto3D - A Three Dimensional Transient Solid Dynamics Program, SAND87-1912, Sandia National Laboratories, 1989.
| C_FUNC_DEF double v_hex_skew | ( | int | num_nodes, |
Maximum |cos A| where A is the angle between edges at hex center. Reference — L.M. Taylor, and D.P. Flanagan, Pronto3D - A Three Dimensional Transient Solid Dynamics Program, SAND87-1912, Sandia National Laboratories, 1989.
| C_FUNC_DEF double v_hex_taper | ( | int | num_nodes, |
Maximum ratio of lengths derived from opposite edges. Reference — L.M. Taylor, and D.P. Flanagan, Pronto3D - A Three Dimensional Transient Solid Dynamics Program, SAND87-1912, Sandia National Laboratories, 1989.
| C_FUNC_DEF double v_hex_volume | ( | int | num_nodes, |
Jacobian at hex center. Reference — L.M. Taylor, and D.P. Flanagan, Pronto3D - A Three Dimensional Transient Solid Dynamics Program, SAND87-1912, Sandia National Laboratories, 1989.
| C_FUNC_DEF double v_hex_stretch | ( | int | num_nodes, |
Sqrt(3) * minimum edge length / maximum diagonal length. Reference — FIMESH code
| C_FUNC_DEF double v_hex_diagonal | ( | int | num_nodes, |
Minimum diagonal length / maximum diagonal length. Reference — Unknown
| C_FUNC_DEF double v_hex_dimension | ( | int | num_nodes, |
Pronto-specific characteristic length for stable time step calculation. Char_length = Volume / 2 grad Volume. Reference — L.M. Taylor, and D.P. Flanagan, Pronto3D - A Three Dimensional Transient Solid Dynamics Program, SAND87-1912, Sandia National Laboratories, 1989.
| C_FUNC_DEF double v_hex_oddy | ( | int | num_nodes, |
| C_FUNC_DEF double v_hex_med_aspect_frobenius | ( | int | num_nodes, |
Average Frobenius condition number of the Jacobian matrix at 8 corners.
| C_FUNC_DEF double v_hex_max_aspect_frobenius | ( | int | num_nodes, |
Maximum Frobenius condition number of the Jacobian matrix at 8 corners. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_hex_condition | ( | int | num_nodes, |
| C_FUNC_DEF double v_hex_jacobian | ( | int | num_nodes, |
Minimum pointwise volume of local map at 8 corners & center of hex. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_hex_scaled_jacobian | ( | int | num_nodes, |
Minimum Jacobian divided by the lengths of the 3 edge vectors. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_hex_shear | ( | int | num_nodes, |
3/Mean Ratio of Jacobian Skew matrix. Reference — P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
| C_FUNC_DEF double v_hex_shape | ( | int | num_nodes, |
3/Mean Ratio of weighted Jacobian matrix. Reference — P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
| C_FUNC_DEF double v_hex_relative_size_squared | ( | int | num_nodes, |
| C_FUNC_DEF double v_hex_shape_and_size | ( | int | num_nodes, |
Product of Shape and Relative Size. Reference — P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
| C_FUNC_DEF double v_hex_shear_and_size | ( | int | num_nodes, |
Product of Shear and Relative Size. Reference — P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
| C_FUNC_DEF double v_hex_distortion | ( | int | num_nodes, |
{min(|J|)/actual volume}*parent volume, parent volume = 8 for hex. Reference — SDRC/IDEAS Simulation: Finite Element Modeling–User's Guide
| C_FUNC_DEF void v_set_tet_size | ( | double | size | ) |
| C_FUNC_DEF double v_tet_edge_ratio | ( | int | num_nodes, |
| C_FUNC_DEF double v_tet_radius_ratio | ( | int | num_nodes, |
CR / (3.0 * IR) where CR = circumsphere radius, IR = inscribed sphere radius. Reference — V. N. Parthasarathy et al, A comparison of tetrahedron quality measures, Finite Elem. Anal. Des., Vol 15(1993), 255-261.
| C_FUNC_DEF double v_tet_aspect_beta | ( | int | num_nodes, |
CR / (3.0 * IR) where CR = circumsphere radius, IR = inscribed sphere radius if the element is positively-oriented. Reference — V. N. Parthasarathy et al, A comparison of tetrahedron quality measures, Finite Elem. Anal. Des., Vol 15(1993), 255-261.
| C_FUNC_DEF double v_tet_aspect_ratio | ( | int | num_nodes, |
Hmax / (2 sqrt(6) r) where Hmax and r respectively denote the greatest edge length and the inradius of the tetrahedron Reference — P. Frey and P.-L. George, Meshing, Hermes (2000).
| C_FUNC_DEF double v_tet_aspect_gamma | ( | int | num_nodes, |
Srms**3 / (8.479670*V) where Srms = sqrt(Sum(Si**2)/6), Si = edge length. Reference — V. N. Parthasarathy et al, A comparison of tetrahedron quality measures, Finite Elem. Anal. Des., Vol 15(1993), 255-261.
| C_FUNC_DEF double v_tet_aspect_frobenius | ( | int | num_nodes, |
Frobenius condition number when the reference element is regular Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_tet_minimum_angle | ( | int | num_nodes, |
Minimum (nonoriented) dihedral angle of a tetrahedron, expressed in degrees.
| C_FUNC_DEF double v_tet_collapse_ratio | ( | int | num_nodes, |
Collapse ratio
| C_FUNC_DEF double v_tet_volume | ( | int | num_nodes, |
(1/6) * Jacobian at corner node. Reference — V. N. Parthasarathy et al, A comparison of tetrahedron quality measures, Finite Elem. Anal. Des., Vol 15(1993), 255-261.
| C_FUNC_DEF double v_tet_condition | ( | int | num_nodes, |
Condition number of the Jacobian matrix at any corner. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_tet_jacobian | ( | int | num_nodes, |
Minimum pointwise volume at any corner. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_tet_scaled_jacobian | ( | int | num_nodes, |
Minimum Jacobian divided by the lengths of 3 edge vectors Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_tet_shape | ( | int | num_nodes, |
| C_FUNC_DEF double v_tet_relative_size_squared | ( | int | num_nodes, |
Min( J, 1/J ), where J is determinant of weighted Jacobian matrix. Reference — P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
| C_FUNC_DEF double v_tet_shape_and_size | ( | int | num_nodes, |
| C_FUNC_DEF double v_tet_distortion | ( | int | num_nodes, |
{min(|J|)/actual volume}*parent volume, parent volume = 1/6 for tet. Reference — SDRC/IDEAS Simulation: Finite Element Modeling–User's Guide
| C_FUNC_DEF double v_pyramid_volume | ( | int | num_nodes, |
| C_FUNC_DEF double v_wedge_volume | ( | int | num_nodes, |
| C_FUNC_DEF double v_wedge_edge_ratio | ( | int | num_nodes, |
| C_FUNC_DEF double v_wedge_max_aspect_frobenius | ( | int | num_nodes, |
max(F_0123, F_1204, F_2015, F_3540, F_4351, F_5432) Reference — Adaptation of hex max aspect frobenius
| C_FUNC_DEF double v_wedge_mean_aspect_frobenius | ( | int | num_nodes, |
1/6 * (F_0123 + F_1204 + F+2015 + F_3540 + F_4351 + F_5432) Reference — Adaptation of hex mean aspect frobenius
| C_FUNC_DEF double v_wedge_jacobian | ( | int | num_nodes, |
min{((L_2 X L_0) * L_3)_k} Reference — Adaptation of Tet jacobian metric.
| C_FUNC_DEF double v_wedge_distortion | ( | int | num_nodes, |
{min(|J|)/actual volume}*parent volume. Reference — Adaptation of Hex distortion metric.
| C_FUNC_DEF double v_wedge_max_stretch | ( | int | num_nodes, |
Minimum of the stretch of each quadrilateral face. Reference – See quadrilateral stretch
| C_FUNC_DEF double v_wedge_scaled_jacobian | ( | int | num_nodes, |
Reference — Adaptation of Hex and Tet scaled jacobian metric.
| C_FUNC_DEF double v_wedge_shape | ( | int | num_nodes, |
3 divided by the minimum mean ratio of the Jacobian matrix at each element corner. Reference – Adaptaation of Hex shape metric.
| C_FUNC_DEF double v_wedge_condition | ( | int | num_nodes, |
| C_FUNC_DEF double v_knife_volume | ( | int | num_nodes, |
| C_FUNC_DEF double v_edge_length | ( | int | num_nodes, |
| C_FUNC_DEF void v_set_quad_size | ( | double | size | ) |
| C_FUNC_DEF double v_quad_edge_ratio | ( | int | num_nodes, |
edge ratio Reference — P. P. Pebay, Planar Quadrangle Quality Measures, Eng. Comp., 2004, 20(2):157-173
| C_FUNC_DEF double v_quad_max_edge_ratio | ( | int | num_nodes, |
Maximum edge length ratio at quad center. Reference — J. Robinson, CRE Method of element testing and the Jacobian shape parameters, Eng. Comput., Vol 4, 1987.
| C_FUNC_DEF double v_quad_aspect_ratio | ( | int | num_nodes, |
aspect ratio Reference — P. P. Pebay, Planar Quadrangle Quality Measures, Eng. Comp., 2004, 20(2):157-173
| C_FUNC_DEF double v_quad_radius_ratio | ( | int | num_nodes, |
radius ratio Reference — P. P. Pebay, Planar Quadrangle Quality Measures, Eng. Comp., 2004, 20(2):157-173
| C_FUNC_DEF double v_quad_med_aspect_frobenius | ( | int | num_nodes, |
average Frobenius aspect Reference — P. P. Pebay, Planar Quadrangle Quality Measures, Eng. Comp., 2004, 20(2):157-173
| C_FUNC_DEF double v_quad_max_aspect_frobenius | ( | int | num_nodes, |
| C_FUNC_DEF double v_quad_skew | ( | int | num_nodes, |
Maximum |cos A| where A is the angle between edges at quad center. Reference — J. Robinson, CRE Method of element testing and the Jacobian shape parameters, Eng. Comput., Vol 4, 1987.
| C_FUNC_DEF double v_quad_taper | ( | int | num_nodes, |
Maximum ratio of lengths derived from opposite edges. Reference — J. Robinson, CRE Method of element testing and the Jacobian shape parameters, Eng. Comput., Vol 4, 1987.
| C_FUNC_DEF double v_quad_warpage | ( | int | num_nodes, |
Cosine of Minimum Dihedral Angle formed by Planes Intersecting in Diagonals. Reference — J. Robinson, CRE Method of element testing and the Jacobian shape parameters, Eng. Comput., Vol 4, 1987.
| C_FUNC_DEF double v_quad_area | ( | int | num_nodes, |
Jacobian at quad center. Reference — J. Robinson, CRE Method of element testing and the Jacobian shape parameters, Eng. Comput., Vol 4, 1987.
| C_FUNC_DEF double v_quad_stretch | ( | int | num_nodes, |
Sqrt(2) * minimum edge length / maximum diagonal length. Reference — FIMESH code.
| C_FUNC_DEF double v_quad_minimum_angle | ( | int | num_nodes, |
Smallest included quad angle (degrees). Reference — Unknown.
| C_FUNC_DEF double v_quad_maximum_angle | ( | int | num_nodes, |
Largest included quad angle (degrees). Reference — Unknown.
| C_FUNC_DEF double v_quad_oddy | ( | int | num_nodes, |
| C_FUNC_DEF double v_quad_condition | ( | int | num_nodes, |
Maximum condition number of the Jacobian matrix at 4 corners. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_quad_jacobian | ( | int | num_nodes, |
Minimum pointwise volume of local map at 4 corners & center of quad. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_quad_scaled_jacobian | ( | int | num_nodes, |
Minimum Jacobian divided by the lengths of the 2 edge vectors. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_quad_shear | ( | int | num_nodes, |
2/Condition number of Jacobian Skew matrix. Reference — P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
| C_FUNC_DEF double v_quad_shape | ( | int | num_nodes, |
2/Condition number of weighted Jacobian matrix. Reference — P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
| C_FUNC_DEF double v_quad_relative_size_squared | ( | int | num_nodes, |
| C_FUNC_DEF double v_quad_shape_and_size | ( | int | num_nodes, |
| C_FUNC_DEF double v_quad_shear_and_size | ( | int | num_nodes, |
| C_FUNC_DEF double v_quad_distortion | ( | int | num_nodes, |
{min(|J|)/actual area}*parent area, parent area = 4 for quad. Reference — SDRC/IDEAS Simulation: Finite Element Modeling–User's Guide
| C_FUNC_DEF void v_set_tri_size | ( | double | size | ) |
| C_FUNC_DEF void v_set_tri_normal_func | ( | ComputeNormal | func | ) |
| C_FUNC_DEF double v_tri_edge_ratio | ( | int | num_nodes, |
edge ratio Reference — P. P. Pebay & T. J. Baker, Analysis of Triangle Quality Measures, AMS Math. Comp., 2003, 72(244):1817-1839
| C_FUNC_DEF double v_tri_aspect_ratio | ( | int | num_nodes, |
aspect ratio Reference — P. P. Pebay & T. J. Baker, Analysis of Triangle Quality Measures, AMS Math. Comp., 2003, 72(244):1817-1839
| C_FUNC_DEF double v_tri_radius_ratio | ( | int | num_nodes, |
radius ratio Reference — P. P. Pebay & T. J. Baker, Analysis of Triangle Quality Measures, AMS Math. Comp., 2003, 72(244):1817-1839
| C_FUNC_DEF double v_tri_aspect_frobenius | ( | int | num_nodes, |
Frobenius aspect
| C_FUNC_DEF double v_tri_area | ( | int | num_nodes, |
Maximum included angle in triangle
| C_FUNC_DEF double v_tri_minimum_angle | ( | int | num_nodes, |
Minimum included angle in triangle
| C_FUNC_DEF double v_tri_maximum_angle | ( | int | num_nodes, |
| C_FUNC_DEF double v_tri_condition | ( | int | num_nodes, |
Condition number of the Jacobian matrix. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_tri_scaled_jacobian | ( | int | num_nodes, |
Minimum Jacobian divided by the lengths of 2 edge vectors. Reference — P. Knupp, Achieving Finite Element Mesh Quality via Optimization of the Jacobian Matrix Norm and Associated Quantities, Intl. J. Numer. Meth. Engng. 2000, 48:1165-1185.
| C_FUNC_DEF double v_tri_shear | ( | int | num_nodes, |
| C_FUNC_DEF double v_tri_relative_size_squared | ( | int | num_nodes, |
| C_FUNC_DEF double v_tri_shape | ( | int | num_nodes, |
| C_FUNC_DEF double v_tri_shape_and_size | ( | int | num_nodes, |
| C_FUNC_DEF double v_tri_distortion | ( | int | num_nodes, |
{min(|J|)/actual area}*parent area, parent area = 1/2 for triangular element. Reference — SDRC/IDEAS Simulation: Finite Element Modeling–User's Guide
