pqTreeWidgetCheckHelper.h
3  Program: ParaView
4  Module: pqTreeWidgetCheckHelper.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32
33 #ifndef pqTreeWidgetCheckHelper_h
34 #define pqTreeWidgetCheckHelper_h
35
36 #include "pqWidgetsModule.h"
37 #include <QObject>
38
39 class QTreeWidget;
40 class QTreeWidgetItem;
41
50 class PQWIDGETS_EXPORT pqTreeWidgetCheckHelper : public QObject
51 {
52  Q_OBJECT
53 public:
54  // treeWidget :- the tree widget managed by this helper.
55  // checkableColumn :- column index for the checkable item.
56  // parent :- QObject parent.
57  pqTreeWidgetCheckHelper(QTreeWidget* treeWidget, int checkableColumn, QObject* parent);
58
59  enum CheckMode
60  {
61  CLICK_IN_COLUMN, // toggle check state when clicked in the column
62  // with the checkable item.
63  CLICK_IN_ROW, // toggle check state when clicked in the row
64  // with the checkable item (default).
65  };
66
67  // Check Mode controls whether the user must click in the column
68  // with the checkable item or any column in the same row.
69  void setCheckMode(CheckMode mode) { this->Mode = mode; }
70  CheckMode checkMode() const { return this->Mode; }
71
72 protected Q_SLOTS:
73  void onItemClicked(QTreeWidgetItem* item, int column);
74  void onItemPressed(QTreeWidgetItem* item, int column);
75
76 private:
77  Q_DISABLE_COPY(pqTreeWidgetCheckHelper)
78
79  QTreeWidget* Tree;
80  int CheckableColumn;
81  int PressState;
82  CheckMode Mode;
83 };
84
85 #endif
If a QTreeWidget has checkable elements in any column, one needs to explicitly click on the checkbox ...
