pqTestingReaction.h
3  Program: ParaView
4  Module: pqTestingReaction.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqTestingReaction_h
33 #define pqTestingReaction_h
35 #include "pqMasterOnlyReaction.h"
36
41 class PQAPPLICATIONCOMPONENTS_EXPORT pqTestingReaction : public pqMasterOnlyReaction
42 {
43  Q_OBJECT
45
46 public:
47  enum Mode
48  {
52  LOCK_VIEW_SIZE_CUSTOM
53  };
54
55  pqTestingReaction(QAction* parentObject, Mode mode, Qt::ConnectionType type = Qt::AutoConnection);
56
60  static void recordTest(const QString& filename);
61  static void recordTest();
62
66  static void playTest(const QString& filename);
67  static void playTest();
68
72  static void lockViewSize(bool);
73
77  static void lockViewSizeCustom();
78
79 protected:
80  void onTriggered() override
81  {
82  switch (this->ReactionMode)
83  {
84  case RECORD:
86  break;
87  case PLAYBACK:
89  break;
90  case LOCK_VIEW_SIZE:
91  pqTestingReaction::lockViewSize(this->parentAction()->isChecked());
92  break;
93  case LOCK_VIEW_SIZE_CUSTOM:
95  break;
96  }
97  }
98
99 private:
100  Q_DISABLE_COPY(pqTestingReaction)
101  Mode ReactionMode;
102 };
103
104 #endif
Locks the view size with a custom resolution.
Called when the action is triggered.
This is a superclass just to make it easier to collect all such reactions.
Definition: pqReaction.h:53
QAction * parentAction() const
Provides access to the parent action.
Definition: pqReaction.h:68
Locks the view size for testing.
pqTestingReaction can be used to recording or playing back tests.
