pqSILModel.h
3  Program: ParaView
4  Module: pqSILModel.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqSILModel_h
33 #define pqSILModel_h
35 #include <QAbstractItemModel>
36 #include <QSet>
37 #include <QVector>
38 #include <set>
40 #include "pqComponentsModule.h"
41 #include "vtkObject.h"
42 #include "vtkSmartPointer.h"
43
44 class vtkGraph;
45 class vtkSMSILDomain;
46 class vtkSMSILModel;
61 class PQCOMPONENTS_EXPORT pqSILModel : public QAbstractItemModel
62 {
63  Q_OBJECT
64  typedef QAbstractItemModel Superclass;
65
66 public:
67  pqSILModel(QObject* parent = 0);
68  ~pqSILModel() override;
69
81  int rowCount(const QModelIndex& parent = QModelIndex()) const override;
82
90  int columnCount(const QModelIndex& parent = QModelIndex()) const override;
91
99  bool hasChildren(const QModelIndex& parent = QModelIndex()) const override;
100
110  QModelIndex index(int row, int column, const QModelIndex& parent = QModelIndex()) const override;
111
119  QModelIndex parent(const QModelIndex& index) const override;
120
129  QVariant data(const QModelIndex& index, int role = Qt::DisplayRole) const override;
130
141  Qt::ItemFlags flags(const QModelIndex& index) const override;
142
148  bool setData(const QModelIndex& index, const QVariant& value, int role = Qt::EditRole) override;
150
156  QModelIndex hierarchyIndex(const QString& hierarchyName) const;
157
158  QVariant headerData(int, Qt::Orientation, int role = Qt::DisplayRole) const override
159  {
160  if (role == Qt::DisplayRole)
161  {
162  return "Selections";
163  }
164  return QVariant();
165  }
166
170  QList<QVariant> status(const QString& hierarchyName) const;
171  void setStatus(const QString& hierarchyName, const QList<QVariant>& values);
172
173  void setSILDomain(vtkSMSILDomain* domain);
174
175  void domainModified();
176
180  QModelIndex makeIndex(vtkIdType vertexid) const;
181
186  vtkIdType findVertex(const char* name) const;
187
188 Q_SIGNALS:
189  void checkStatusChanged();
190
191 public Q_SLOTS:
195  void update();
196
197 protected:
202  void checkStateUpdated(vtkObject* caller, unsigned long eventid, void* calldata);
203
207  bool isLeaf(vtkIdType vertexid) const;
208
213  vtkIdType parent(vtkIdType vertexid) const;
214
218  int childrenCount(vtkIdType vertexid) const;
219
224  void collectLeaves(vtkIdType vertexid, std::set<vtkIdType>& list);
225
227
231  QMap<vtkIdType, QModelIndex>* ModelIndexCache;
232
233  QMap<QString, QModelIndex> Hierarchies;
234
239  QMap<QString, std::set<vtkIdType> > HierarchyVertexIds;
241  unsigned long SILDomainObserverId;
242
243 private:
244  Q_DISABLE_COPY(pqSILModel)
245 };
246
247 #endif
data
vtkSMSILModel * SILModel
Definition: pqSILModel.h:226
QMap< vtkIdType, QModelIndex > * ModelIndexCache
Cache used by makeIndex() to avoid iterating over the edges each time.
Definition: pqSILModel.h:231
is a specialization for vtkSMArraySelectionDomain with access to the SIL.
int vtkIdType
is a helper for to work with SILs.
Definition: vtkSMSILModel.h:55
name
QMap< QString, std::set< vtkIdType > > HierarchyVertexIds
This map keeps a list of vertex ids that refer to the leaves in the hierarchy.
Definition: pqSILModel.h:239
QAbstractItemModel for legacy SIL (vtkGraph-based SIL)
Definition: pqSILModel.h:61
value
index
QVariant headerData(int, Qt::Orientation, int role=Qt::DisplayRole) const override
Definition: pqSILModel.h:158
Definition: pqSILModel.h:241
QMap< QString, QModelIndex > Hierarchies
Definition: pqSILModel.h:233
vtkSmartPointer< vtkSMSILDomain > SILDomain
Definition: pqSILModel.h:240
