pqPythonMacroSupervisor.h
3  Program: ParaView
4  Module: pqPythonMacroSupervisor.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32 #ifndef _pqPythonMacroSupervisor_h
33 #define _pqPythonMacroSupervisor_h
35 #include "pqPythonModule.h"
36 #include <QList>
37 #include <QMap>
38 #include <QObject>
39 #include <QPointer>
40 #include <QString>
41
42 class QAction;
43
44 class PQPYTHON_EXPORT pqPythonMacroSupervisor : public QObject
45 {
46  Q_OBJECT
47 public:
48  pqPythonMacroSupervisor(QObject* p = 0);
49  ~pqPythonMacroSupervisor() override;
50
51  // Description:
52  // Add a widget to be given macro actions. QActions representing script macros
53  // will be added to the widget. This could be a QToolBar, QMenu, or other type
54  // of widget.
55  void addWidgetForRunMacros(QWidget* widget);
56
57  // Description:
58  // Add a widget to be given macro actions. QActions representing script macros
59  // will be added to the widget. This could be a QToolBar, QMenu, or other type
60  // of widget.
61  void addWidgetForEditMacros(QWidget* widget);
62
63  // Description:
64  // Add a widget to be given macro actions. QActions representing script macros
65  // will be added to the widget. This could be a QToolBar, QMenu, or other type
66  // of widget.
67  void addWidgetForDeleteMacros(QWidget* widget);
68
69  // Description:
70  // Lookup and return a macro action by filename.
71  // If it does not exist, return null.
72  QAction* getMacro(const QString& fileName);
73
74  // Description:
75  // Looks in pqSettings to get the stored macros. In the returned map,
76  // the keys are filenames and values are macro names.
77  static QMap<QString, QString> getStoredMacros();
78
79  // Description:
80  // Removes a macro with the given filename from pqSettings, if it exists.
81  static void removeStoredMacro(const QString& filename);
82
83  // Description:
84  // Get a macro name from the fileName
85  static QString macroNameFromFileName(const QString& filename);
86
87  static QStringList getMacrosFilePaths();
88
89 Q_SIGNALS:
90
91  // Description:
92  // Emitted when a macro has been triggered.
93  void executeScriptRequested(const QString& filename);
94
95  // Description:
96  // Emitted when a macro has to be edited
97  void onEditMacro(const QString& filename);
98
99 public Q_SLOTS:
100
101  // Description:
102  // Add an action with the given name and filename. If there is already
103  // a macro with the given filename it's macroname will be updated to the
104  // one given. Macro names do not have to be unique. Note, this does not
105  // store the macro in pqSettings, you must still call storeMacro yourself.
106  void addMacro(const QString& macroName, const QString& filename);
107  void addMacro(const QString& filename);
108
109  // Description:
110  // Remove an action with the given filename. Note, this does not remove
111  // the macro from pqSettings, you must call removeStoredMacro yourself.
112  void removeMacro(const QString& filename);
113
114  // Description:
115  // Update Macro list widgets and actions...
116  void updateMacroList();
117
118 protected Q_SLOTS:
119
120  // Description:
121  // If the sender is a QAction managed by this class, the filename will be
122  // looked up and the signal requestExecuteScript will be emitted.
123  void onMacroTriggered();
124
125  // Description:
126  // If the sender is a QAction managed by this class, the filename will be
127  // moved (deleted), and the macro will be removed
128  void onDeleteMacroTriggered();
129
130  // Description:
131  // If the sender is a QAction managed by this class, the macro file will be
132  // open in a python edit
133  void onEditMacroTriggered();
134
135 protected:
136  // Description:
137  // Add a widget to be given macro actions. QActions representing script macros
138  // will be added to the widget. This could be a QToolBar, QMenu, or other type
139  // of widget.
140  void addWidgetForMacros(QWidget* widget, int actionType); // 0:run, 1:edit, 2:delete
141
142  // Description:
143  // Removes all actions and re-adds actions for each macro stored.
144  void resetActions();
145
146 private:
147  class pqInternal;
148  pqInternal* Internal;
149 };
150
151 #endif // ifndef _pqPythonMacroSupervisor_h
