pqCompositeDataInformationTreeModel.h
3  Program: ParaView
4  Module: pqCompositeDataInformationTreeModel.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqCompositeDataInformationTreeModel_h
33 #define pqCompositeDataInformationTreeModel_h
35 #include "pqComponentsModule.h" // for exports.
36 #include <QAbstractItemModel>
37 #include <QPair> // for QPair.
38 #include <QScopedPointer> // for ivar.
41
43 {
44 class CNode;
45 }
46
150 class PQCOMPONENTS_EXPORT pqCompositeDataInformationTreeModel : public QAbstractItemModel
151 {
152  Q_OBJECT
153  Q_PROPERTY(bool userCheckable READ userCheckable WRITE setUserCheckable);
154  Q_PROPERTY(bool expandMultiPiece READ expandMultiPiece WRITE setExpandMultiPiece);
155  Q_PROPERTY(bool exclusivity READ exclusivity WRITE setExclusivity);
156  Q_PROPERTY(bool defaultCheckState READ defaultCheckState WRITE setDefaultCheckState);
157
158  typedef QAbstractItemModel Superclass;
159
160 public:
161  pqCompositeDataInformationTreeModel(QObject* parent = 0);
163
165
168  int columnCount(const QModelIndex& parent = QModelIndex()) const override;
169  int rowCount(const QModelIndex& parent = QModelIndex()) const override;
170  QModelIndex index(int row, int column, const QModelIndex& parent = QModelIndex()) const override;
171  QModelIndex parent(const QModelIndex& index = QModelIndex()) const override;
172  QVariant data(const QModelIndex& index, int role) const override;
173  Qt::ItemFlags flags(const QModelIndex& index) const override;
174  bool setData(const QModelIndex& index, const QVariant& value, int role) override;
175  QVariant headerData(
176  int section, Qt::Orientation orientation, int role = Qt::DisplayRole) const override;
177  bool setHeaderData(int section, Qt::Orientation orientation, const QVariant& value,
178  int role = Qt::DisplayRole) override;
180
182
186  void setUserCheckable(bool val) { this->UserCheckable = val; }
187  bool userCheckable() const { return this->UserCheckable; }
189
191
196  void setOnlyLeavesAreUserCheckable(bool val) { this->OnlyLeavesAreUserCheckable = val; }
197  bool onlyLeavesAreUserCheckable() const { return this->OnlyLeavesAreUserCheckable; }
199
201
205  void setDefaultCheckState(bool checked) { this->DefaultCheckState = checked; }
206  bool defaultCheckState() const { return this->DefaultCheckState; }
207
209
213  void setExpandMultiPiece(bool val) { this->ExpandMultiPiece = val; }
214  bool expandMultiPiece() const { return this->ExpandMultiPiece; }
216
218
222  void setExclusivity(bool val) { this->Exclusivity = val; }
223  bool exclusivity() const { return this->Exclusivity; }
225
232  QList<unsigned int> checkedNodes() const;
233
238  QList<unsigned int> checkedLeaves() const;
239
245  void setChecked(const QList<unsigned int>& indices);
246
250  QList<QPair<unsigned int, bool> > checkStates() const;
251
255  void setCheckStates(const QList<QPair<unsigned int, bool> >& states);
256
258
263  QList<unsigned int> checkedLevels() const;
264  void setCheckedLevels(const QList<unsigned int>& indices);
266
268
272  QList<QPair<unsigned int, unsigned int> > checkedLevelDatasets() const;
273  void setCheckedLevelDatasets(const QList<QPair<unsigned int, unsigned int> >& indices);
275
280  unsigned int compositeIndex(const QModelIndex& idx) const;
281
286  QModelIndex find(unsigned int compositeIndex) const;
287
291  const QModelIndex rootIndex() const;
292
297  int addColumn(const QString& propertyName);
298
303  int columnIndex(const QString& propertyName);
304
310  void clearColumns();
311
313
322  void setColumnStates(
323  const QString& propertyName, const QList<QPair<unsigned int, QVariant> >& values);
324  QList<QPair<unsigned int, QVariant> > columnStates(const QString& propertyName) const;
326
330  enum
331  {
337  ValueInheritedRole = Qt::UserRole,
338
346
350  CompositeIndexRole
351  };
352
353 public Q_SLOTS:
362  bool reset(vtkPVDataInformation* info = nullptr);
363
364 private:
365  Q_DISABLE_COPY(pqCompositeDataInformationTreeModel);
366
367  class pqInternals;
368  QScopedPointer<pqInternals> Internals;
369  QString HeaderLabel;
370  bool UserCheckable;
371  bool OnlyLeavesAreUserCheckable;
372  bool ExpandMultiPiece;
373  bool Exclusivity;
374  bool DefaultCheckState;
375
376  friend class pqCompositeDataInformationTreeModelNS::CNode;
377 };
378
379 #endif
data
Light object for holding data information.
When UserCheckable is true, this limits use-checkability to leaf nodes only.
When set to true for a userCheckable model, if the user checks a node, the all other nodes that are n...
Toggle whether the model allows user to change check state.
Get/Set the default check state for nodes.
For a leaf node (i.e node with any children) return it&#39;s position in a ordered list of simply all lea...
Toggle whether multipiece datasets are expanded (default false).
Tree model that use vtkPVDataInformation to model composite data tree.
index
