pqCameraReaction.h
3  Program: ParaView
4  Module: pqCameraReaction.h
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqCameraReaction_h
33 #define pqCameraReaction_h
35 #include "pqReaction.h"
36
42 class PQAPPLICATIONCOMPONENTS_EXPORT pqCameraReaction : public pqReaction
43 {
44  Q_OBJECT
45  typedef pqReaction Superclass;
46
47 public:
48  enum Mode
49  {
59  ROTATE_CAMERA_CCW
60  };
61
62  pqCameraReaction(QAction* parent, Mode mode);
63
64  static void resetCamera();
65  static void resetPositiveX();
66  static void resetPositiveY();
67  static void resetPositiveZ();
68  static void resetNegativeX();
69  static void resetNegativeY();
70  static void resetNegativeZ();
71  static void resetDirection(
72  double look_x, double look_y, double look_z, double up_x, double up_y, double up_z);
73  static void zoomToData();
74  static void rotateCamera(double angle);
75
76 public Q_SLOTS:
81  void updateEnableState() override;
82
83 protected:
87  void onTriggered() override;
88
89 private:
90  Q_DISABLE_COPY(pqCameraReaction)
91  Mode ReactionMode;
92 };
93
94 #endif
virtual void updateEnableState()
Definition: pqReaction.h:76
This is a superclass just to make it easier to collect all such reactions.
Definition: pqReaction.h:53
pqCameraReaction has the logic to handle common operations associated with the camera such as reset v...
virtual void onTriggered()
Called when the action is triggered.
Definition: pqReaction.h:74
