| function | vtk_module_graphviz () |
| Generate graphviz output for a module dependency graph. More... | |
| function | vtk_module_json () |
| JSON metadata representation of modules. More... | |
| function vtk_module_graphviz | ( | ) |
Information about the modules built and/or available may be dumped to a Graphviz .dot file.
MODULES: (Required) The modules to output information for.OUTPUT: (Required) A Graphviz file describing the modules built will be output to this path. Relative paths are rooted to CMAKE_BINARY_DIR.PRIVATE_DEPENDENCIES: (Default ON) Whether to draw private dependency edges or not..KIT_CLUSTERS: (Default OFF) Whether to draw modules as part of a kit as a cluster or not. Definition at line 132 of file vtkModuleGraphviz.cmake.
| function vtk_module_json | ( | ) |
Information about the modules built and/or available may be dumped to a JSON file.
MODULES: (Required) The modules to output information for.OUTPUT: (Required) A JSON file describing the modules built will be output to this path. Relative paths are rooted to CMAKE_BINARY_DIR.Example output:
Definition at line 103 of file vtkModuleJson.cmake.
