#include <vtkfreetype/include/ft2build.h>#include <FT_CONFIG_OPTIONS_H>#include <FT_CONFIG_STANDARD_LIBRARY_H>#include "vtk_kwiml.h"
| #define | HAVE_UNISTD_H 1 |
| #define | HAVE_FCNTL_H 1 |
| #define | FT_CHAR_BIT CHAR_BIT |
| #define | FT_SIZEOF_INT KWIML_ABI_SIZEOF_INT |
| #define | FT_SIZEOF_LONG KWIML_ABI_SIZEOF_LONG |
| #define | FT_UNUSED(arg) ( (arg) = (arg) ) |
| #define | FT_UINT_TO_POINTER(x) (void*)(unsigned long)(x) |
| #define | FT_BEGIN_STMNT do { |
| #define | FT_END_STMNT } while ( 0 ) |
| #define | FT_DUMMY_STMNT FT_BEGIN_STMNT FT_END_STMNT |
| #define | FT_TYPEOF(type) /* empty */ |
| #define | FT_LOCAL(x) extern x |
| #define | FT_LOCAL_DEF(x) x |
| #define | FT_LOCAL_ARRAY(x) extern const x |
| #define | FT_LOCAL_ARRAY_DEF(x) const x |
| #define | FT_BASE(x) extern x |
| #define | FT_BASE_DEF(x) x |
| #define | FT_EXPORT(x) extern x |
| #define | FT_EXPORT_DEF(x) extern x |
| #define | FT_EXPORT_VAR(x) extern x |
| #define | FT_CALLBACK_DEF(x) static x |
| #define | FT_BASE_CALLBACK(x) extern x |
| #define | FT_BASE_CALLBACK_DEF(x) x |
| #define | FT_CALLBACK_TABLE extern |
| #define | FT_CALLBACK_TABLE_DEF /* nothing */ |
Typedefs | |
| typedef signed short | FT_Int16 |
| typedef unsigned short | FT_UInt16 |
| #define HAVE_UNISTD_H 1 |
Definition at line 58 of file ftconfig.h.
| #define HAVE_FCNTL_H 1 |
Definition at line 59 of file ftconfig.h.
| #define FT_CHAR_BIT CHAR_BIT |
Definition at line 70 of file ftconfig.h.
| #define FT_SIZEOF_INT KWIML_ABI_SIZEOF_INT |
Definition at line 77 of file ftconfig.h.
| #define FT_SIZEOF_LONG KWIML_ABI_SIZEOF_LONG |
Definition at line 78 of file ftconfig.h.
| #define FT_UNUSED | ( | arg | ) | ( (arg) = (arg) ) |
Definition at line 123 of file ftconfig.h.
| #define FT_UINT_TO_POINTER | ( | x | ) | (void*)(unsigned long)(x) |
Definition at line 381 of file ftconfig.h.
| #define FT_BEGIN_STMNT do { |
Definition at line 392 of file ftconfig.h.
| #define FT_END_STMNT } while ( 0 ) |
Definition at line 393 of file ftconfig.h.
| #define FT_DUMMY_STMNT FT_BEGIN_STMNT FT_END_STMNT |
Definition at line 394 of file ftconfig.h.
| #define FT_TYPEOF | ( | type | ) | /* empty */ |
Definition at line 404 of file ftconfig.h.
| #define FT_LOCAL | ( | x | ) | extern x |
Definition at line 427 of file ftconfig.h.
| #define FT_LOCAL_DEF | ( | x | ) | x |
Definition at line 428 of file ftconfig.h.
| #define FT_LOCAL_ARRAY | ( | x | ) | extern const x |
Definition at line 433 of file ftconfig.h.
| #define FT_LOCAL_ARRAY_DEF | ( | x | ) | const x |
Definition at line 434 of file ftconfig.h.
| #define FT_BASE | ( | x | ) | extern x |
Definition at line 448 of file ftconfig.h.
| #define FT_BASE_DEF | ( | x | ) | x |
Definition at line 459 of file ftconfig.h.
| #define FT_EXPORT | ( | x | ) | extern x |
Definition at line 522 of file ftconfig.h.
| #define FT_EXPORT_DEF | ( | x | ) | extern x |
Definition at line 535 of file ftconfig.h.
| #define FT_EXPORT_VAR | ( | x | ) | extern x |
Definition at line 546 of file ftconfig.h.
| #define FT_CALLBACK_DEF | ( | x | ) | static x |
Definition at line 585 of file ftconfig.h.
| #define FT_BASE_CALLBACK | ( | x | ) | extern x |
Definition at line 594 of file ftconfig.h.
| #define FT_BASE_CALLBACK_DEF | ( | x | ) | x |
Definition at line 595 of file ftconfig.h.
| #define FT_CALLBACK_TABLE extern |
Definition at line 604 of file ftconfig.h.
| #define FT_CALLBACK_TABLE_DEF /* nothing */ |
Definition at line 605 of file ftconfig.h.
| typedef signed short FT_Int16 |
Definition at line 200 of file ftconfig.h.
| typedef unsigned short FT_UInt16 |
Definition at line 211 of file ftconfig.h.
