| void | Clear (const char *arrayname) |
| | Remove the array identified by the arrayname, if any. More...
| virtual void | SetPartitionType (int) |
| | Choose the type for a parition in the output vtkMultiBlockDataSet. More...
| virtual int | GetPartitionType () |
| virtual void | SetFieldAssociation (int) |
| | Indicate the field association to which the specified data arrays are added. More...
| virtual int | GetFieldAssociation () |
| void | SetTuple1Double (const char *arrayname, vtkIdType index, double val) |
| | Methods to add individual tuples to the data arrays. More...
| void | SetTuple1Int (const char *arrayname, vtkIdType index, int val) |
| void | SetTuple1IdType (const char *arrayname, vtkIdType index, vtkIdType val) |
| void | SetTuple2Double (const char *arrayname, vtkIdType index, double val0, double val1) |
| void | SetTuple2Int (const char *arrayname, vtkIdType index, int val0, int val1) |
| void | SetTuple2IdType (const char *arrayname, vtkIdType index, vtkIdType val0, vtkIdType val1) |
| void | SetTuple3Double (const char *arrayname, vtkIdType index, double val0, double val1, double val2) |
| void | SetTuple3Int (const char *arrayname, vtkIdType index, int val0, int val1, int val2) |
| void | SetTuple3IdType (const char *arrayname, vtkIdType index, vtkIdType val0, vtkIdType val1, vtkIdType val3) |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkSteeringDataGenerator () |
| | ~vtkSteeringDataGenerator () override |
| int | FillOutputPortInformation (int vtkNotUsed(port), vtkInformation *info) override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| int | RequestData (vtkInformation *vtkNotUsed(request), vtkInformationVector **vtkNotUsed(inputVector), vtkInformationVector *outputVector) override |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
source to generate dataset given field arrays
vtkSteeringDataGenerator is simply a dataset generator that generates a single partition vtkMultiBlockDataSet with the 1st partition being non-empty dataset of the type specified using vtkSteeringDataGenerator::SetPartitionType with arrays added to the field type chosen using vtkSteeringDataGenerator::SetFieldAssociation`.
If the PartitionType is a vtkPointSet subclass, then one can use coords as the field array name to add point coordinates when FieldAssociation is set to vtkDataObject::FIELD_ASSOCIATION_POINTS.
A sample proxy definition that uses this source is as follows:
<ServerManagerConfiguration>
<ProxyGroup name="sources">
<SourceProxy class="vtkSteeringDataGenerator" name="TestSteeringDataGeneratorSource">
<IntVectorProperty name="PartitionType"
command="SetPartitionType"
number_of_elements="1"
default_values="0"
panel_visibility="never">
</IntVectorProperty>
<IntVectorProperty name="FieldAssociation"
command="SetFieldAssociation"
default_values="0"
panel_visibility="never" />
<DoubleVectorProperty name="Center"
command="SetTuple3Double"
use_index="1"
clean_command="Clear"
initial_string="coords"
number_of_elements_per_command="3"
repeat_command="1" />
<IdTypeVectorProperty name="Id"
command="SetTuple2IdType"
use_index="1"
initial_string="Id"
number_of_elements_per_command="2"
<IntVectorProperty name="Type"
command="SetTuple1Int"
use_index="1"
initial_string="Type"
number_of_elements_per_command="1"
</SourceProxy>
</ProxyGroup>
</ServerManagerConfiguration>
Caveats
This filter should ideally generated vtkPartitionedDataSet. However, until vtkPartitionedDataSet is well supported, we are making it generate vtkMultiBlockDataSet.
Definition at line 94 of file vtkSteeringDataGenerator.h.
