| virtual void | SetTolerance (double) |
| virtual double | GetTolerance () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkSliceAlongPolyPlane () |
| | ~vtkSliceAlongPolyPlane () override |
| int | RequestDataObject (vtkInformation *, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| virtual bool | Execute (vtkDataSet *inputDataset, vtkPolyData *lineDataSet, vtkPolyData *output) |
| | The actual algorithm for slice a dataset along a polyline. More...
| void | CleanPolyLine (vtkPolyData *input, vtkPolyData *output) |
| | Cleans up input polydata. More...
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
slice a dataset along a polyplane
vtkSliceAlongPolyPlane is a filter that slices its first input dataset along the surface defined by sliding the poly line in the second input dataset along a line parallel to the Z-axis.
- See also
- vtkCutter vtkPolyPlane
Definition at line 37 of file vtkSliceAlongPolyPlane.h.
