| void | Convert (vtkSelection *input, vtkSelection *output, int global_ids) |
| | Convert input selection and store it in output. More...
converts one selection type to another
vtkSelectionConverter can be used to convert from one selection type to another. Currently, it only supports conversion from a 'surface' geometry selection to a 'volume' selection. It does this by looking for a pedigree array called vtkOriginalCellIds that says what 3D cell produced each selected 2D surface cell. The input selection must have SOURCE_ID() and ORIGINAL_SOURCE_ID() properties set. The SOURCE_ID() corresponds to the geometry filter whereas the ORIGINAL_SOURCE_ID() corresponds to the input of the geometry filter. The output selection will have SOURCE_ID() corresponding to the input of the geometry filter (what was ORIGINAL_SOURCE_ID()).
- See also
- vtkSelection
Definition at line 44 of file vtkSelectionConverter.h.
