manages presets for color, opacity, and annotation presets. More...
#include <vtkSMTransferFunctionPresets.h>
| unsigned int | GetNumberOfPresets () |
| Returns the number of presets current available (including builtin and custom). More... | |
| std::string | GetPresetAsString (unsigned int index) |
| Gets the raw text for a preset given its index. More... | |
| bool | AddPreset (const char *name, const std::string &preset) |
| Add a new preset. More... | |
| bool | RemovePreset (unsigned int index) |
| Remove a preset. More... | |
| const Json::Value & | GetPreset (unsigned int index) |
| Returns a preset at a given index. More... | |
| std::string | GetPresetName (unsigned int index) |
| Returns the name for a preset at the given index. More... | |
| bool | HasPreset (const char *name) |
| Returns true if a present with given name exists. More... | |
| bool | GetPresetHasOpacities (const Json::Value &preset) |
| Returns true if the preset has opacities i.e. More... | |
| bool | GetPresetHasOpacities (unsigned int index) |
| bool | GetPresetHasIndexedColors (const Json::Value &preset) |
| Returns true is the preset has indexed colors. More... | |
| bool | GetPresetHasIndexedColors (unsigned int index) |
| bool | GetPresetHasAnnotations (const Json::Value &preset) |
| Returns true is the preset has annotations. More... | |
| bool | GetPresetHasAnnotations (unsigned int index) |
| bool | IsPresetDefault (const Json::Value &preset) |
| Returns the preset's JSON-defined default position (if any) or -1 if none. More... | |
| bool | IsPresetDefault (unsigned int index) |
| bool | SetPreset (const char *name, const Json::Value &preset) |
| Set the Json::Value object for preset 'name' if such a preset was found in the custom presets. More... | |
| bool | AddPreset (const char *name, const Json::Value &preset) |
| Add a preset give the Json::Value object. More... | |
| std::string | AddUniquePreset (const Json::Value &preset, const char *prefix=NULL) |
| Same as AddPreset() expect it create a unique name using the prefix provided. More... | |
| bool | IsPresetBuiltin (unsigned int index) |
| Returns true if the preset is a builtin preset. More... | |
| bool | RenamePreset (unsigned int index, const char *newname) |
| Rename a preset. More... | |
| void | ReloadPresets () |
| Reload the presets from the configuration file. More... | |
| const Json::Value & | GetFirstPresetWithName (const char *name, int &idx) |
| Returns a preset JSON given the name. More... | |
| const Json::Value & | GetFirstPresetWithName (const char *name) |
| bool | ImportPresets (const char *filename) |
| Load presets from a file. More... | |
| bool | ImportPresets (const Json::Value &presets) |
| vtkSMTransferFunctionPresets () | |
| ~vtkSMTransferFunctionPresets () override | |
| vtkSMObject () | |
vtkSMTransferFunctionPresets is a manager to manage all color, opacity, and annotation presets. It also uses vtkSMSettings to support persistent customizations besides hard-coded/builtin presets.
vtkSMTransferFunctionPresets is designed as a singleton, accessible through the GetInstance() static method. Public API ensure that presets are loaded, but a reload can be explictly asked (see ReloadPresets()).
Definition at line 40 of file vtkSMTransferFunctionPresets.h.
Definition at line 44 of file vtkSMTransferFunctionPresets.h.
Get singleton instance.
| unsigned int vtkSMTransferFunctionPresets::GetNumberOfPresets | ( | ) |
| std::string vtkSMTransferFunctionPresets::GetPresetAsString | ( | unsigned int | index | ) |
The preset is provided as a JSON string. Returns an empty string when not available.
| bool vtkSMTransferFunctionPresets::AddPreset | ( | const char * | name, |
| const std::string & | preset | ||
Add a new preset.
This will get saved across sessions using vtkSMSettings, as appropriate. If name provided already exists, this will override the existing preset (even for builtin presets). preset must be a valid JSON string. If not, this will return failure.
| bool vtkSMTransferFunctionPresets::RemovePreset | ( | unsigned int | index | ) |
Remove a preset.
This has no effect for builtin presets.
| const Json::Value& vtkSMTransferFunctionPresets::GetFirstPresetWithName | ( | const char * | name, |
| int & | idx | ||
Since multiple presets can have the same name, this returns the 'first' preset with the specified name. idx is set to the index of the found preset,-1 if none.
| std::string vtkSMTransferFunctionPresets::GetPresetName | ( | unsigned int | index | ) |
| bool vtkSMTransferFunctionPresets::HasPreset | ( | const char * | name | ) |
| bool vtkSMTransferFunctionPresets::GetPresetHasOpacities | ( | const Json::Value & | preset | ) |
values for a piecewise function.
Definition at line 106 of file vtkSMTransferFunctionPresets.h.
| bool vtkSMTransferFunctionPresets::GetPresetHasIndexedColors | ( | const Json::Value & | preset | ) |
Definition at line 115 of file vtkSMTransferFunctionPresets.h.
| bool vtkSMTransferFunctionPresets::GetPresetHasAnnotations | ( | const Json::Value & | preset | ) |
Definition at line 124 of file vtkSMTransferFunctionPresets.h.
| bool vtkSMTransferFunctionPresets::IsPresetDefault | ( | const Json::Value & | preset | ) |
Definition at line 134 of file vtkSMTransferFunctionPresets.h.
Return true if preset was correctly set, false otherwise.
| std::string vtkSMTransferFunctionPresets::AddUniquePreset | ( | const Json::Value & | preset, |
| const char * | prefix = NULL |
If no prefix is specified, "Preset" will be used as the prefix.
| bool vtkSMTransferFunctionPresets::IsPresetBuiltin | ( | unsigned int | index | ) |
The preset is identified by its index.
Rename a preset.
| bool vtkSMTransferFunctionPresets::ImportPresets | ( | const char * | filename | ) |
All presets are added to "custom" presets list and are considered as non-builtin. If the filename ends with a .xml, it's assumed to be a legacy color map XML and will be converted to the new format before processing.
| bool vtkSMTransferFunctionPresets::ImportPresets | ( | const Json::Value & | presets | ) |
| void vtkSMTransferFunctionPresets::ReloadPresets | ( | ) |
