| void | SetTextProperty (vtkTextProperty *prop) |
| | Set the text property for the printed distance. More...
| void | SetAxisLineWidth (float width) |
| | Set the line width for the displayed axis in screen units. More...
| void | SetAxisColor (double red, double green, double blue) |
| | Set the color for the displayed axis. More...
| void | SetVisibility (bool) override |
| | Set the visibility. More...
| void | SetLabelFormat (char *labelFormat) |
| | Specify the format to use for labeling the distance. More...
| void | SetNumberOfRulerTicks (int numberOfRulerTicks) |
| | Specify the number of major ruler ticks. More...
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetDistanceRepresentation (vtkDistanceRepresentation2D *) |
| | Set the text widget. More...
| virtual vtkDistanceRepresentation2D * | GetDistanceRepresentation () |
| void | SetRulerMode (int choice) |
| | Enable or disable ruler mode. More...
| int | GetRulerMode () |
| void | SetRulerDistance (double distance) |
| | Specify the RulerDistance which indicates the spacing of the major ticks in the unit space obtained after the Scale is applied (see SetScale()). More...
| double | GetRulerDistance () |
| void | SetScale (double distance) |
| | Set scale factor to apply to the ruler graduation scale and the displayed distance. More...
| double | GetScale () |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkRulerSourceRepresentation () |
| | ~vtkRulerSourceRepresentation () override |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
