vtkQuerySelectionSource Class Reference
a selection source that uses a "query" to generate the selection. More...
#include <vtkQuerySelectionSource.h>
Inheritance diagram for vtkQuerySelectionSource:
Collaboration diagram for vtkQuerySelectionSource:
typedef vtkSelectionAlgorithm Superclass
- Public Types inherited from vtkSelectionAlgorithm
enum  DesiredOutputPrecision
virtual void SetHierarchicalLevel (int)
virtual int GetHierarchicalLevel ()
virtual void SetHierarchicalIndex (int)
virtual int GetHierarchicalIndex ()
virtual void SetProcessID (int)
virtual int GetProcessID ()
virtual void SetFieldType (int)
virtual int GetFieldType ()
const char * GetUserFriendlyText ()
 This merely reconstructs the query as a user friendly text eg. More...
virtual void SetQueryString (const char *)
 Set/get the query expression string. More...
virtual char * GetQueryString ()
virtual void SetCompositeIndex (int)
virtual int GetCompositeIndex ()
virtual void SetInverse (int)
 Set/get the invert selection flag. More...
virtual int GetInverse ()
virtual void SetNumberOfLayers (int)
 Specify number of layers to extract connected to the selected elements. More...
virtual int GetNumberOfLayers ()
- Public Member Functions inherited from vtkSelectionAlgorithm
vtkSelectionAlgorithmNewInstance () const
vtkSelectionGetOutput ()
vtkSelectionGetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkQuerySelectionSourceNew ()
static vtkQuerySelectionSourceSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSelectionAlgorithm
static vtkSelectionAlgorithmNew ()
static vtkSelectionAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkQuerySelectionSource ()
 ~vtkQuerySelectionSource () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
- Protected Member Functions inherited from vtkSelectionAlgorithm
 vtkSelectionAlgorithm ()
 ~vtkSelectionAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
int FieldType
char * QueryString
int CompositeIndex
int HierarchicalIndex
int HierarchicalLevel
int ProcessID
int NumberOfLayers
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkQuerySelectionSource is a selection source that uses a "query" to generate the vtkSelection object. A query has the following form: "TERM OPERATOR VALUE(s)" eg. "GLOBALID is_in_range (0, 10)" here GLOBALID is the TERM, is_in_range is the operator and (0,10) are the values. A query can have additional qualifiers such as the process id, block id, amr level, amr block.
Definition at line 36 of file vtkQuerySelectionSource.h.
Definition at line 40 of file vtkQuerySelectionSource.h.
◆ vtkQuerySelectionSource()
vtkQuerySelectionSource::vtkQuerySelectionSource ( )
◆ ~vtkQuerySelectionSource()
vtkQuerySelectionSource::~vtkQuerySelectionSource ( )
static vtkQuerySelectionSource* vtkQuerySelectionSource::New ( )
virtual const char* vtkQuerySelectionSource::GetClassName ( )
static int vtkQuerySelectionSource::IsTypeOf ( const char *  type)
virtual int vtkQuerySelectionSource::IsA ( const char *  type)
Reimplemented from vtkSelectionAlgorithm.
static vtkQuerySelectionSource* vtkQuerySelectionSource::SafeDownCast ( vtkObject o)
void vtkQuerySelectionSource::PrintSelf ( ostream &  os,
◆ SetQueryString()
virtual void vtkQuerySelectionSource::SetQueryString ( const char *  )
◆ GetQueryString()
virtual char* vtkQuerySelectionSource::GetQueryString ( )
◆ SetCompositeIndex()
virtual void vtkQuerySelectionSource::SetCompositeIndex ( int  )
◆ GetCompositeIndex()
virtual int vtkQuerySelectionSource::GetCompositeIndex ( )
◆ SetHierarchicalLevel()
virtual void vtkQuerySelectionSource::SetHierarchicalLevel ( int  )
◆ GetHierarchicalLevel()
virtual int vtkQuerySelectionSource::GetHierarchicalLevel ( )
◆ SetHierarchicalIndex()
virtual void vtkQuerySelectionSource::SetHierarchicalIndex ( int  )
◆ GetHierarchicalIndex()
virtual int vtkQuerySelectionSource::GetHierarchicalIndex ( )
◆ SetProcessID()
virtual void vtkQuerySelectionSource::SetProcessID ( int  )
◆ GetProcessID()
virtual int vtkQuerySelectionSource::GetProcessID ( )
◆ SetFieldType()
virtual void vtkQuerySelectionSource::SetFieldType ( int  )
◆ GetFieldType()
virtual int vtkQuerySelectionSource::GetFieldType ( )
◆ GetUserFriendlyText()
const char* vtkQuerySelectionSource::GetUserFriendlyText ( )
"IDs >= 12". ( Makes you want to wonder if we should support parsing input query text as well ;) )
◆ SetInverse()
virtual void vtkQuerySelectionSource::SetInverse ( int  )
◆ GetInverse()
virtual int vtkQuerySelectionSource::GetInverse ( )
◆ SetNumberOfLayers()
virtual void vtkQuerySelectionSource::SetNumberOfLayers ( int  )
◆ GetNumberOfLayers()
virtual int vtkQuerySelectionSource::GetNumberOfLayers ( )
◆ RequestInformation()
int vtkQuerySelectionSource::RequestInformation ( vtkInformation request,
vtkInformationVector outputVector
overrideprotectedvirtual
◆ RequestData()
int vtkQuerySelectionSource::RequestData ( vtkInformation request,
◆ FieldType
int vtkQuerySelectionSource::FieldType
Definition at line 102 of file vtkQuerySelectionSource.h.
◆ QueryString
char* vtkQuerySelectionSource::QueryString
Definition at line 104 of file vtkQuerySelectionSource.h.
◆ CompositeIndex
int vtkQuerySelectionSource::CompositeIndex
Definition at line 106 of file vtkQuerySelectionSource.h.
◆ HierarchicalIndex
int vtkQuerySelectionSource::HierarchicalIndex
Definition at line 107 of file vtkQuerySelectionSource.h.
◆ HierarchicalLevel
int vtkQuerySelectionSource::HierarchicalLevel
Definition at line 108 of file vtkQuerySelectionSource.h.
◆ ProcessID
int vtkQuerySelectionSource::ProcessID
Definition at line 109 of file vtkQuerySelectionSource.h.
◆ NumberOfLayers
int vtkQuerySelectionSource::NumberOfLayers
Definition at line 110 of file vtkQuerySelectionSource.h.
