| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| int | GetNumberOfAttributeArrays (int attributeType) |
| | Get number of arrays in an attribute (e.g., vtkDataObject::POINT, vtkDataObject::CELL, vtkDataObject::ROW, vtkDataObject::FIELD_DATA). More...
| const char * | GetAttributeArrayName (int attributeType, int arrayIndex) |
| | From the input data, get the name of attribute array at index for the given attribute type. More...
| void | SetAttributeArrayStatus (int attributeType, const char *name, int status) |
| | Set the array status for the input data object. More...
| int | GetAttributeArrayStatus (int attributeType, const char *name) |
| | Get the status indicating whether the array with the given name and attribute type in the input will be copied to the client. More...
| void | EnableAllAttributeArrays () |
| | Enable all arrays. More...
| void | DisableAllAttributeArrays () |
| | Disable all arrays. More...
| virtual vtkDataObject * | GetLocalInput () |
| | Gets local copy of the input. More...
| virtual vtkDataObject * | GetClientDataObject () |
| | Gets the client's copy of the input. More...
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| virtual void | SetVisibility (bool val) |
| | Get/Set the visibility for this representation. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPythonRepresentation () |
| | ~vtkPythonRepresentation () override |
| | Overridden to make input optional. More...
| | Overridden to copy data from the server to the client. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
