Representation for showing point data as sprites, including gaussian splats, spheres, or some custom shaded representation.
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetLookupTable (vtkScalarsToColors *lut) |
| | Use to set the color map for the data in this representation. More...
| void | SetVisibility (bool val) override |
| | Use to set whether the data in this representation is visible or not. More...
| virtual void | SetEmissive (bool val) |
| | Use to set whether the splat emits light. More...
| virtual void | SetMapScalars (int val) |
| | Use to make sure scalars will be mapped through lookup table, and not inadvertently used as colors by themselves. More...
| virtual void | SetOrientation (double, double, double) |
| virtual void | SetOrigin (double, double, double) |
| virtual void | SetPickable (int val) |
| virtual void | SetPosition (double, double, double) |
| virtual void | SetScale (double, double, double) |
| virtual void | SetAmbientColor (double r, double g, double b) |
| virtual void | SetDiffuseColor (double r, double g, double b) |
| virtual void | SetEdgeColor (double r, double g, double b) |
| virtual void | SetInterpolation (int val) |
| virtual void | SetLineWidth (double val) |
| virtual void | SetOpacity (double val) |
| virtual void | SetPointSize (double val) |
| virtual void | SetSpecularColor (double r, double g, double b) |
| virtual void | SetSpecularPower (double val) |
| virtual void | SetSplatSize (double radius) |
| | Sets the radius of the gaussian splats if there is no scale array or if the scale array is disabled. More...
| void | SelectShaderPreset (int preset) |
| | Allows to select one of several preset options for shading the points. More...
| void | SetCustomShader (const char *shaderString) |
| | Sets the snippet of fragment shader code used to color the sprites. More...
| void | SetCustomTriangleScale (double scale) |
| | Sets the scale of the triangle geometry drawn for the custom shader. More...
| void | SelectScaleArray (int, int, int, int, const char *name) |
| | Sets the point array to scale the guassians by. More...
| void | SelectScaleArrayComponent (int component) |
| | Sets the point array component to scale the gaussians by. More...
| void | SetUseScaleFunction (bool enable) |
| | Use scale transfer function. More...
| void | SetScaleTransferFunction (vtkPiecewiseFunction *pwf) |
| | Sets a vtkPiecewiseFunction to use in mapping array values to sprite sizes. More...
| void | SetOpacityTransferFunction (vtkPiecewiseFunction *pwf) |
| | Sets a vtkPiecewiseFunction to use in mapping array values to sprite opacities. More...
| void | SelectOpacityArray (int, int, int, int, const char *name) |
| | Sets the point array to use in calculating point sprite opacities. More...
| void | SelectOpacityArrayComponent (int component) |
| | Sets the point array component to opacify the gaussians with. More...
| void | SetOpacityByArray (bool newVal) |
| | Enables or disables setting opacity by an array. More...
| virtual bool | GetOpacityByArray () |
| virtual void | OpacityByArrayOn () |
| virtual void | OpacityByArrayOff () |
| void | SetScaleByArray (bool newVal) |
| | Enables or disables scaling by a data array vs. More...
| virtual bool | GetScaleByArray () |
| virtual void | ScaleByArrayOn () |
| virtual void | ScaleByArrayOff () |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPointGaussianRepresentation () |
| | ~vtkPointGaussianRepresentation () override |
| void | UpdateColoringParameters () |
| virtual void | SetLastScaleArray (const char *) |
| virtual void | SetLastOpacityArray (const char *) |
| void | InitializeShaderPresets () |
| void | UpdateMapperScaleFunction () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
