ParaView options for server executables. More...
#include <vtkPVServerOptions.h>
| typedef vtkPVOptions | Superclass |
Public Types inherited from vtkPVOptions | |
| enum | ProcessTypeEnum { PARAVIEW = 0x2, PVCLIENT = 0x4, PVSERVER = 0x8, PVRENDER_SERVER = 0x10, PVDATA_SERVER = 0x20, PVBATCH = 0x40, ALLPROCESS = PARAVIEW | PVCLIENT | PVSERVER | PVRENDER_SERVER | PVDATA_SERVER | PVBATCH } |
| typedef vtkCommandOptions | Superclass |
Public Types inherited from vtkCommandOptions | |
| enum | { EVERYBODY = 0, XMLONLY = 0x1 } |
| int | ParseExtraXMLTag (const char *name, const char **atts) override |
| Pass in the name and the attributes for all tags that are not Options. More... | |
| int | GetStereoType (unsigned int idx) const |
| char * | GetStereoType () override |
| bool | GetIsInCave () const override |
| Returns true of CAVE configuration is requested. More... | |
| virtual char * | GetClientHostName () |
| Name of the client-host. More... | |
| virtual int | GetServerPort () |
| The configuration port for this process. More... | |
| double | GetEyeSeparation () const |
| Get information about machines used in a data or render server. More... | |
| unsigned int | GetNumberOfMachines () const |
| const char * | GetMachineName (unsigned int idx) const |
| const char * | GetDisplayName (unsigned int idx) const |
| int * | GetGeometry (unsigned int idx) const |
| bool | GetFullScreen (unsigned int idx) const |
| bool | GetShowBorders (unsigned int idx) const |
| double * | GetLowerLeft (unsigned int idx) const |
| double * | GetLowerRight (unsigned int idx) const |
| double * | GetUpperRight (unsigned int idx) const |
| bool | GetCaveBoundsSet (unsigned int idx) const |
Public Member Functions inherited from vtkPVOptions | |
| virtual int | GetConnectID () |
| virtual int | GetUseStereoRendering () |
| virtual int | GetReverseConnection () |
| virtual int | GetUseRenderingGroup () |
| virtual int * | GetTileDimensions () |
| virtual void | GetTileDimensions (int &, int &) |
| virtual void | GetTileDimensions (int [2]) |
| virtual int * | GetTileMullions () |
| virtual void | GetTileMullions (int &, int &) |
| virtual void | GetTileMullions (int [2]) |
| virtual bool | GetIsInTileDisplay () const |
| Returns true if the tile display configuration is requested. More... | |
| virtual int | GetEGLDeviceIndex () |
| Returns the egl device index. More... | |
| virtual int | GetMultiClientMode () |
| Is this server was started for collaboration meaning that it allow several clients to connect to the same server and share the same pipeline and visualization. More... | |
| virtual int | IsMultiClientModeDebug () |
| virtual char * | GetServerURL () |
| Provides access to server-url if specified on the command line. More... | |
| virtual int | GetCatalystLivePort () |
| Provides access to the Catalyst Live port if specified on the command line. More... | |
| virtual int | GetForceOffscreenRendering () |
| When set to true, ParaView will create headless only render windows on the current process. More... | |
| virtual int | GetForceOnscreenRendering () |
| When set to true, ParaView will create on-screen render windows. More... | |
| virtual char * | GetHostName () |
| Convenience method to get the local process's host name. More... | |
| virtual char * | GetParaViewDataName () |
| This is the argument specified by –data on the command line. More... | |
| virtual char * | GetServersFileName () |
| Servers file to load on startup. More... | |
| virtual int | GetTimeout () |
| Valid on PVSERVER and PVDATA_SERVER only. More... | |
| virtual void | SetConnectID (int) |
| Clients need to set the ConnectID so they can handle server connections after the client has started. More... | |
| virtual void | SetLogFileName (const char *) |
| Log filename. More... | |
| virtual char * | GetLogFileName () |
| virtual int | GetDisableFurtherConnections () |
| Returns if this server does not allow connection after the first client. More... | |
| virtual int | GetMultiServerMode () |
| Is this client allow multiple server connection in parallel. More... | |
| virtual int | GetSymmetricMPIMode () |
| Indicates if the application is in symmetric mpi mode. More... | |
| virtual void | SetSymmetricMPIMode (int) |
| virtual int | GetTellVersion () |
| Should this run print the version numbers and exit. More... | |
| virtual void | SetParaViewDataName (const char *) |
| This is used when user want to open a file at startup. More... | |
| virtual void | SetEnableStreaming (int) |
| Until streaming becomes mainstream, we enable streaming support by passing a command line argument to all processes. More... | |
| virtual int | GetEnableStreaming () |
| virtual void | SetSatelliteMessageIds (int) |
| Include originating process id text into server to client messages. More... | |
| virtual int | GetSatelliteMessageIds () |
| virtual int | GetPrintMonitors () |
| Should this process just print monitor information and exit? More... | |
| virtual char * | GetTestPlugins () |
| Adding ability to test plugins by loading them at command line. More... | |
| virtual char * | GetTestPluginPaths () |
| virtual int | GetEnableStackTrace () |
| Flag for controlling auto generation of stack trace on POSIX systems after crash. More... | |
| virtual void | SetEnableStackTrace (int) |
| virtual int | GetDisableRegistry () |
| Flag for disabling loading of options and settings stored by the application. More... | |
| virtual int | GetDisableXDisplayTests () |
| XDisplay test on server processes during initialization sometimes happens too early and may result in remote rendering prematurely disabled. More... | |
| virtual int | GetForceNoMPIInitOnClient () |
| Get/Set the ForceNoMPIInitOnClient flag. More... | |
| virtual void | SetForceNoMPIInitOnClient (int) |
| virtual void | ForceNoMPIInitOnClientOn () |
| virtual void | ForceNoMPIInitOnClientOff () |
| virtual int | GetForceMPIInitOnClient () |
| Get/Set the ForceMPIInitOnClient flag. More... | |
| virtual void | SetForceMPIInitOnClient (int) |
| virtual void | ForceMPIInitOnClientOn () |
| virtual void | ForceMPIInitOnClientOff () |
| virtual int | GetLogStdErrVerbosity () |
| Returns the verbosity level for stderr output chosen. More... | |
| const std::string & | GetDisplay (int myrank=0, int num_ranks=1) |
| Provides access to display selection. More... | |
Public Member Functions inherited from vtkCommandOptions | |
| int | Parse (int argc, const char *const argv[]) |
| void | GetRemainingArguments (int *argc, char **argv[]) |
| const char * | GetHelp () |
| int | GetProcessType () |
| Set/Get the type of the process for this set of options. More... | |
| void | SetProcessType (int p) |
| const char * | GetArgv0 () |
| Get argv[0]. More... | |
| int | GetLastArgument () |
| Get the index of the last argument parsed. More... | |
| virtual int | GetHelpSelected () |
| Was help selected? More... | |
| virtual void | SetHelpSelected (int) |
| virtual char * | GetUnknownArgument () |
| In case of unknown argument, set this variable with the unknown argument. More... | |
| virtual char * | GetErrorMessage () |
| Get the error message if Parse returned 0. More... | |
| virtual char * | GetApplicationPath () |
| Get full path of executable (based on Argv0) More... | |
| static vtkPVServerOptions * | New () |
| static vtkPVServerOptions * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVOptions | |
| static vtkPVOptions * | New () |
| static vtkPVOptions * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkCommandOptions | |
| static vtkCommandOptions * | New () |
| static vtkCommandOptions * | SafeDownCast (vtkObject *o) |
| int | AddMachineInformation (const char **atts) |
| Add machine information from the xml tag <Machine .... More... | |
| int | AddEyeSeparationInformation (const char **atts) |
| Add eye separation information from the xml tag <EyeSeparation ...> More... | |
| vtkPVServerOptions () | |
| ~vtkPVServerOptions () override | |
| Destructor. More... | |
| void | Initialize () override |
| Initialize arguments. More... | |
| virtual void | SetClientHostName (const char *) |
Protected Member Functions inherited from vtkPVOptions | |
| vtkPVOptions () | |
| ~vtkPVOptions () override | |
| int | PostProcess (int argc, const char *const *argv) override |
| After parsing, process extra option dependencies. More... | |
| int | WrongArgument (const char *argument) override |
| This method is called when wrong argument is found. More... | |
| int | DeprecatedArgument (const char *argument) override |
| This method is called when a deprecated argument is found. More... | |
| virtual void | SetServerURL (const char *) |
| virtual void | SetServersFileName (const char *) |
| virtual void | SetTestPlugins (const char *) |
| virtual void | SetTestPluginPaths (const char *) |
Protected Member Functions inherited from vtkCommandOptions | |
| vtkCommandOptions () | |
| ~vtkCommandOptions () override | |
| void | AddCallback (const char *longarg, const char *shortarg, CallbackType callback, void *call_data, const char *help, int type=EVERYBODY) |
| int | LoadXMLConfigFile (const char *) |
| This method loads the paraview config file. More... | |
| virtual void | SetUnknownArgument (const char *) |
| virtual void | SetErrorMessage (const char *) |
| virtual void | SetXMLConfigFile (const char *) |
| void | CleanArgcArgv () |
| virtual void | SetApplicationPath (const char *) |
| void | ComputeApplicationPath () |
| void | AddBooleanArgument (const char *longarg, const char *shortarg, int *var, const char *help, int type=EVERYBODY) |
| Add a command line option. More... | |
| void | AddDeprecatedArgument (const char *longarg, const char *shortarg, const char *help, int type=EVERYBODY) |
| void | AddArgument (const char *longarg, const char *shortarg, int *var, const char *help, int type=EVERYBODY) |
| void | AddArgument (const char *longarg, const char *shortarg, char **var, const char *help, int type=EVERYBODY) |
Protected Attributes | |
| char * | ClientHostName |
| int | ServerPort |
Protected Attributes inherited from vtkPVOptions | |
| char * | ParaViewDataName |
| Subclasses may need to access these. More... | |
| char * | ServerURL |
| int | ServerMode |
| int | ClientMode |
| int | RenderServerMode |
| int | MultiClientMode |
| int | DisableFurtherConnections |
| int | MultiClientModeWithErrorMacro |
| int | MultiServerMode |
| int | SymmetricMPIMode |
| char * | ServersFileName |
| char * | TestPlugins |
| char * | TestPluginPaths |
| int | DisableXDisplayTests |
| int | CatalystLivePort |
Protected Attributes inherited from vtkCommandOptions | |
| vtkCommandOptionsXMLParser * | XMLParser |
Protected Types inherited from vtkCommandOptions | |
| typedef int(* | CallbackType) (const char *argument, const char *value, void *call_data) |
| Prototype for callbacks. More... | |
An object of this class represents a storage for command line options for various server executables.
These options can be retrieved during run-time, set using configuration file or using Command Line Arguments.
Definition at line 34 of file vtkPVServerOptions.h.
Definition at line 38 of file vtkPVServerOptions.h.
Default constructor.
Destructor.
Reimplemented from vtkPVOptions.
By default, the client are server are assumed to be on the same host.
The interpretation of the port number depends on the configuration and process type.
If it returns 1, then it is successful, and 0 if it failed.
Reimplemented from vtkCommandOptions.
| double vtkPVServerOptions::GetEyeSeparation | ( | ) | const |
| unsigned int vtkPVServerOptions::GetNumberOfMachines | ( | ) | const |
| bool vtkPVServerOptions::GetFullScreen | ( | unsigned int | idx | ) | const |
| bool vtkPVServerOptions::GetShowBorders | ( | unsigned int | idx | ) | const |
| bool vtkPVServerOptions::GetCaveBoundsSet | ( | unsigned int | idx | ) | const |
inlineoverridevirtual |
Definition at line 83 of file vtkPVServerOptions.h.
overrideprotectedvirtual |
protectedvirtual |
Definition at line 110 of file vtkPVServerOptions.h.
Definition at line 113 of file vtkPVServerOptions.h.
