Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkPVSelectionSource Class Reference
selection source used to produce different types of vtkSelections. More...
#include <vtkPVSelectionSource.h>
Inheritance diagram for vtkPVSelectionSource:
Collaboration diagram for vtkPVSelectionSource:
typedef vtkSelectionAlgorithm Superclass
- Public Types inherited from vtkSelectionAlgorithm
enum  DesiredOutputPrecision
void AddFrustum (double vertices[32])
 Set a frustum to choose within. More...
void SetArrayName (const char *arrayName)
 For threshold and value selection, this controls the name of the scalar array that will be thresholded within. More...
void AddGlobalID (vtkIdType id)
 Add global IDs. More...
void RemoveAllGlobalIDs ()
void AddPedigreeID (const char *domain, vtkIdType id)
 Add integer pedigree IDs in a particular domain. More...
void RemoveAllPedigreeIDs ()
void AddPedigreeStringID (const char *domain, const char *id)
 Add string pedigree IDs in a particular domain. More...
void RemoveAllPedigreeStringIDs ()
void AddID (vtkIdType piece, vtkIdType id)
 Add a (piece, id) to the selection set. More...
void RemoveAllIDs ()
void AddValue (vtkIdType piece, vtkIdType value)
 Add a (piece, value) to the selection set. More...
void RemoveAllValues ()
void AddCompositeID (unsigned int composite_index, vtkIdType piece, vtkIdType id)
 Add IDs that will be added to the selection produced by the selection source. More...
void RemoveAllCompositeIDs ()
void AddHierarhicalID (unsigned int level, unsigned int dataset, vtkIdType id)
 The list of IDs that will be added to the selection produced by the selection source. More...
void RemoveAllHierarchicalIDs ()
void AddThreshold (double min, double max)
 Add a value range to threshold within. More...
void RemoveAllThresholds ()
void AddBlock (vtkIdType blockno)
 Add the flat-index/composite index for a block. More...
void RemoveAllBlocks ()
void AddLocation (double x, double y, double z)
 Add a point in world space to probe at. More...
void RemoveAllLocations ()
virtual void SetFieldType (int)
 Set the field type for the generated selection. More...
virtual int GetFieldType ()
virtual void SetContainingCells (int)
 When extracting by points, extract the cells that contain the passing points. More...
virtual int GetContainingCells ()
virtual void SetInverse (int)
virtual int GetInverse ()
virtual void SetQueryString (const char *)
 Set/get the query expression string. More...
virtual char * GetQueryString ()
virtual void SetNumberOfLayers (int)
 Specify number of layers to extract connected to the selected elements. More...
virtual int GetNumberOfLayers ()
- Public Member Functions inherited from vtkSelectionAlgorithm
vtkSelectionAlgorithmNewInstance () const
vtkSelectionGetOutput ()
vtkSelectionGetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVSelectionSourceNew ()
static vtkPVSelectionSourceSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSelectionAlgorithm
static vtkSelectionAlgorithmNew ()
static vtkSelectionAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
Protected Types
enum  Modes {
  FRUSTUM, GLOBALIDS, ID, COMPOSITEID,
  HIERARCHICALID, THRESHOLDS, LOCATIONS, BLOCKS,
  PEDIGREEIDS, QUERY, VALUES
 vtkPVSelectionSource ()
 ~vtkPVSelectionSource () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
- Protected Member Functions inherited from vtkSelectionAlgorithm
 vtkSelectionAlgorithm ()
 ~vtkSelectionAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
Modes Mode
int FieldType
int ContainingCells
int Inverse
double Frustum [32]
char * ArrayName
char * QueryString
int NumberOfLayers
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPVSelectionSource is used to create different types of selections. It provides different APIs for different types of selections to create. The output selection type depends on the API used most recently.
Definition at line 31 of file vtkPVSelectionSource.h.
Definition at line 35 of file vtkPVSelectionSource.h.
◆ Modes
Enumerator
FRUSTUM
GLOBALIDS
ID
COMPOSITEID
HIERARCHICALID
THRESHOLDS
LOCATIONS
BLOCKS
PEDIGREEIDS
QUERY
VALUES
Definition at line 186 of file vtkPVSelectionSource.h.
◆ vtkPVSelectionSource()
vtkPVSelectionSource::vtkPVSelectionSource ( )
◆ ~vtkPVSelectionSource()
vtkPVSelectionSource::~vtkPVSelectionSource ( )
static vtkPVSelectionSource* vtkPVSelectionSource::New ( )
virtual const char* vtkPVSelectionSource::GetClassName ( )
static int vtkPVSelectionSource::IsTypeOf ( const char *  type)
virtual int vtkPVSelectionSource::IsA ( const char *  type)
Reimplemented from vtkSelectionAlgorithm.
static vtkPVSelectionSource* vtkPVSelectionSource::SafeDownCast ( vtkObject o)
void vtkPVSelectionSource::PrintSelf ( ostream &  os,
◆ AddFrustum()
void vtkPVSelectionSource::AddFrustum ( double  vertices[32])
◆ AddGlobalID()
void vtkPVSelectionSource::AddGlobalID ( vtkIdType  id)
Add global IDs.
◆ RemoveAllGlobalIDs()
void vtkPVSelectionSource::RemoveAllGlobalIDs ( )
Add global IDs.
◆ AddPedigreeID()
void vtkPVSelectionSource::AddPedigreeID ( const char *  domain,
vtkIdType  id
◆ RemoveAllPedigreeIDs()
void vtkPVSelectionSource::RemoveAllPedigreeIDs ( )
◆ AddPedigreeStringID()
void vtkPVSelectionSource::AddPedigreeStringID ( const char *  domain,
const char *  id
◆ RemoveAllPedigreeStringIDs()
void vtkPVSelectionSource::RemoveAllPedigreeStringIDs ( )
◆ AddID()
void vtkPVSelectionSource::AddID ( vtkIdType  piece,
vtkIdType  id
The source will generate only the ids for which piece == UPDATE_PIECE_NUMBER. If piece == -1, the id applies to all pieces.
◆ RemoveAllIDs()
void vtkPVSelectionSource::RemoveAllIDs ( )
◆ AddValue()
void vtkPVSelectionSource::AddValue ( vtkIdType  piece,
vtkIdType  value
The source will generate only the values for which piece == UPDATE_PIECE_NUMBER. If piece == -1, the id applies to all pieces.
◆ RemoveAllValues()
void vtkPVSelectionSource::RemoveAllValues ( )
◆ AddCompositeID()
void vtkPVSelectionSource::AddCompositeID ( unsigned int  composite_index,
vtkIdType  piece,
vtkIdType  id
◆ RemoveAllCompositeIDs()
void vtkPVSelectionSource::RemoveAllCompositeIDs ( )
◆ AddHierarhicalID()
void vtkPVSelectionSource::AddHierarhicalID ( unsigned int  level,
vtkIdType  id
◆ RemoveAllHierarchicalIDs()
void vtkPVSelectionSource::RemoveAllHierarchicalIDs ( )
◆ AddThreshold()
void vtkPVSelectionSource::AddThreshold ( double  min,
double  max
◆ RemoveAllThresholds()
void vtkPVSelectionSource::RemoveAllThresholds ( )
◆ AddBlock()
void vtkPVSelectionSource::AddBlock ( vtkIdType  blockno)
◆ RemoveAllBlocks()
void vtkPVSelectionSource::RemoveAllBlocks ( )
◆ SetArrayName()
void vtkPVSelectionSource::SetArrayName ( const char *  arrayName)
◆ AddLocation()
void vtkPVSelectionSource::AddLocation ( double  x,
double  y,
double  z
◆ RemoveAllLocations()
void vtkPVSelectionSource::RemoveAllLocations ( )
◆ SetFieldType()
virtual void vtkPVSelectionSource::SetFieldType ( int  )
Possible values are as defined by vtkSelection::SelectionField.
◆ GetFieldType()
virtual int vtkPVSelectionSource::GetFieldType ( )
◆ SetContainingCells()
virtual void vtkPVSelectionSource::SetContainingCells ( int  )
◆ GetContainingCells()
virtual int vtkPVSelectionSource::GetContainingCells ( )
◆ SetInverse()
virtual void vtkPVSelectionSource::SetInverse ( int  )
◆ GetInverse()
virtual int vtkPVSelectionSource::GetInverse ( )
◆ SetQueryString()
virtual void vtkPVSelectionSource::SetQueryString ( const char *  )
◆ GetQueryString()
virtual char* vtkPVSelectionSource::GetQueryString ( )
◆ SetNumberOfLayers()
virtual void vtkPVSelectionSource::SetNumberOfLayers ( int  )
◆ GetNumberOfLayers()
virtual int vtkPVSelectionSource::GetNumberOfLayers ( )
◆ RequestInformation()
int vtkPVSelectionSource::RequestInformation ( vtkInformation request,
vtkInformationVector outputVector
overrideprotectedvirtual
◆ RequestData()
int vtkPVSelectionSource::RequestData ( vtkInformation request,
◆ Mode
Modes vtkPVSelectionSource::Mode
Definition at line 201 of file vtkPVSelectionSource.h.
◆ FieldType
int vtkPVSelectionSource::FieldType
Definition at line 202 of file vtkPVSelectionSource.h.
◆ ContainingCells
int vtkPVSelectionSource::ContainingCells
Definition at line 203 of file vtkPVSelectionSource.h.
◆ Inverse
int vtkPVSelectionSource::Inverse
Definition at line 204 of file vtkPVSelectionSource.h.
◆ Frustum
double vtkPVSelectionSource::Frustum[32]
Definition at line 205 of file vtkPVSelectionSource.h.
◆ ArrayName
char* vtkPVSelectionSource::ArrayName
Definition at line 206 of file vtkPVSelectionSource.h.
◆ QueryString
char* vtkPVSelectionSource::QueryString
Definition at line 207 of file vtkPVSelectionSource.h.
◆ NumberOfLayers
int vtkPVSelectionSource::NumberOfLayers
Definition at line 208 of file vtkPVSelectionSource.h.
