| virtual vtkTypeUInt32 | GetCapabilities () |
| | Returns a 32-bit unsigned integer which represents the capabilities. More...
| bool | Supports (vtkTypeUInt32 capability) |
| | Convenience method to check is any of the requested capabilities are supported. More...
| void | CopyFromObject (vtkObject *) override |
| | Transfer information about a single object into this object. More...
| void | AddInformation (vtkPVInformation *) override |
| | Merge another information object. More...
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
provides information about rendering capabilities.
Definition at line 31 of file vtkPVRenderingCapabilitiesInformation.h.
This creates an off-screen render window based on capabilities of the local process.
This is useful to query additional OpenGL information, for example.
This may create a non-mapped onscreen render window, if ParaView was built with onscreen GL support) or headless off-screen render window, if ParaView was built with headless GL support (e.g. EGL or OSMesa). Headless is preferred, if available.
Note the returned window hasn't been created yet, i.e. one may need to call vtkRenderWindow::Render() on it before querying OpenGL information, for example.
