| virtual int | GetConnectID () |
| virtual int | GetUseStereoRendering () |
| virtual char * | GetStereoType () |
| virtual int | GetReverseConnection () |
| virtual int | GetUseRenderingGroup () |
| virtual int * | GetTileDimensions () |
| virtual void | GetTileDimensions (int &, int &) |
| virtual void | GetTileDimensions (int [2]) |
| virtual int * | GetTileMullions () |
| virtual void | GetTileMullions (int &, int &) |
| virtual void | GetTileMullions (int [2]) |
| virtual bool | GetIsInTileDisplay () const |
| | Returns true if the tile display configuration is requested. More...
| virtual bool | GetIsInCave () const |
| | Returns true of CAVE configuration is requested. More...
| virtual int | GetEGLDeviceIndex () |
| | Returns the egl device index. More...
| virtual int | GetMultiClientMode () |
| | Is this server was started for collaboration meaning that it allow several clients to connect to the same server and share the same pipeline and visualization. More...
| virtual int | IsMultiClientModeDebug () |
| virtual char * | GetServerURL () |
| | Provides access to server-url if specified on the command line. More...
| virtual int | GetCatalystLivePort () |
| | Provides access to the Catalyst Live port if specified on the command line. More...
| virtual int | GetForceOffscreenRendering () |
| | When set to true, ParaView will create headless only render windows on the current process. More...
| virtual int | GetForceOnscreenRendering () |
| | When set to true, ParaView will create on-screen render windows. More...
| virtual char * | GetHostName () |
| | Convenience method to get the local process's host name. More...
| virtual char * | GetParaViewDataName () |
| | This is the argument specified by –data on the command line. More...
| virtual char * | GetServersFileName () |
| | Servers file to load on startup. More...
| virtual int | GetTimeout () |
| | Valid on PVSERVER and PVDATA_SERVER only. More...
| virtual void | SetConnectID (int) |
| | Clients need to set the ConnectID so they can handle server connections after the client has started. More...
| virtual void | SetLogFileName (const char *) |
| | Log filename. More...
| virtual char * | GetLogFileName () |
| virtual int | GetDisableFurtherConnections () |
| | Returns if this server does not allow connection after the first client. More...
| virtual int | GetMultiServerMode () |
| | Is this client allow multiple server connection in parallel. More...
| virtual int | GetSymmetricMPIMode () |
| | Indicates if the application is in symmetric mpi mode. More...
| virtual void | SetSymmetricMPIMode (int) |
| virtual int | GetTellVersion () |
| | Should this run print the version numbers and exit. More...
| virtual void | SetParaViewDataName (const char *) |
| | This is used when user want to open a file at startup. More...
| virtual void | SetEnableStreaming (int) |
| | Until streaming becomes mainstream, we enable streaming support by passing a command line argument to all processes. More...
| virtual int | GetEnableStreaming () |
| virtual void | SetSatelliteMessageIds (int) |
| | Include originating process id text into server to client messages. More...
| virtual int | GetSatelliteMessageIds () |
| virtual int | GetPrintMonitors () |
| | Should this process just print monitor information and exit? More...
| virtual char * | GetTestPlugins () |
| | Adding ability to test plugins by loading them at command line. More...
| virtual char * | GetTestPluginPaths () |
| virtual int | GetEnableStackTrace () |
| | Flag for controlling auto generation of stack trace on POSIX systems after crash. More...
| virtual void | SetEnableStackTrace (int) |
| virtual int | GetDisableRegistry () |
| | Flag for disabling loading of options and settings stored by the application. More...
| virtual int | GetDisableXDisplayTests () |
| | XDisplay test on server processes during initialization sometimes happens too early and may result in remote rendering prematurely disabled. More...
| virtual int | GetForceNoMPIInitOnClient () |
| | Get/Set the ForceNoMPIInitOnClient flag. More...
| virtual void | SetForceNoMPIInitOnClient (int) |
| virtual void | ForceNoMPIInitOnClientOn () |
| virtual void | ForceNoMPIInitOnClientOff () |
| virtual int | GetForceMPIInitOnClient () |
| | Get/Set the ForceMPIInitOnClient flag. More...
| virtual void | SetForceMPIInitOnClient (int) |
| virtual void | ForceMPIInitOnClientOn () |
| virtual void | ForceMPIInitOnClientOff () |
| virtual int | GetLogStdErrVerbosity () |
| | Returns the verbosity level for stderr output chosen. More...
| const std::string & | GetDisplay (int myrank=0, int num_ranks=1) |
| | Provides access to display selection. More...
Public Member Functions inherited from vtkCommandOptions |
| int | Parse (int argc, const char *const argv[]) |
| void | GetRemainingArguments (int *argc, char **argv[]) |
| const char * | GetHelp () |
| int | GetProcessType () |
| | Set/Get the type of the process for this set of options. More...
| void | SetProcessType (int p) |
| const char * | GetArgv0 () |
| | Get argv[0]. More...
| int | GetLastArgument () |
| | Get the index of the last argument parsed. More...
| virtual int | ParseExtraXMLTag (const char *, const char **) |
| | Pass in the name and the attributes for all tags that are not Options. More...
| virtual int | GetHelpSelected () |
| | Was help selected? More...
| virtual void | SetHelpSelected (int) |
| virtual char * | GetUnknownArgument () |
| | In case of unknown argument, set this variable with the unknown argument. More...
| virtual char * | GetErrorMessage () |
| | Get the error message if Parse returned 0. More...
| virtual char * | GetApplicationPath () |
| | Get full path of executable (based on Argv0) More...
| | vtkPVPythonOptions () |
| | ~vtkPVPythonOptions () override |
| int | WrongArgument (const char *argument) override |
| | This method is called when wrong argument is found. More...
| | vtkPVOptions () |
| | ~vtkPVOptions () override |
| | Destructor. More...
| void | Initialize () override |
| | Initialize arguments. More...
| int | PostProcess (int argc, const char *const *argv) override |
| | After parsing, process extra option dependencies. More...
| int | DeprecatedArgument (const char *argument) override |
| | This method is called when a deprecated argument is found. More...
| virtual void | SetServerURL (const char *) |
| virtual void | SetServersFileName (const char *) |
| virtual void | SetTestPlugins (const char *) |
| virtual void | SetTestPluginPaths (const char *) |
Protected Member Functions inherited from vtkCommandOptions |
| | vtkCommandOptions () |
| | ~vtkCommandOptions () override |
| | Destructor. More...
| void | AddCallback (const char *longarg, const char *shortarg, CallbackType callback, void *call_data, const char *help, int type=EVERYBODY) |
| int | LoadXMLConfigFile (const char *) |
| | This method loads the paraview config file. More...
| virtual void | SetUnknownArgument (const char *) |
| virtual void | SetErrorMessage (const char *) |
| virtual void | SetXMLConfigFile (const char *) |
| void | CleanArgcArgv () |
| virtual void | SetApplicationPath (const char *) |
| void | ComputeApplicationPath () |
| void | AddBooleanArgument (const char *longarg, const char *shortarg, int *var, const char *help, int type=EVERYBODY) |
| | Add a command line option. More...
| void | AddDeprecatedArgument (const char *longarg, const char *shortarg, const char *help, int type=EVERYBODY) |
| void | AddArgument (const char *longarg, const char *shortarg, int *var, const char *help, int type=EVERYBODY) |
| void | AddArgument (const char *longarg, const char *shortarg, char **var, const char *help, int type=EVERYBODY) |
| | vtkObject () |
| | vtkObjectBase () |
ParaView options storage.
An object of this class represents a storage for ParaView options
These options can be retrieved during run-time, set using configuration file or using Command Line Arguments.
Definition at line 30 of file vtkPVPythonOptions.h.
