| virtual void | GoToFirstItem ()=0 |
| | Move the iterator to the beginning. More...
| virtual void | InitTraversal () |
| | Reset the iterator and move it to the head. More...
| virtual void | GoToNextItem ()=0 |
| | Move the iterator to the next item. More...
| virtual void | GoToNextGroup ()=0 |
| | Move the iterator to the next group. More...
| virtual bool | IsDoneWithTraversal ()=0 |
| | Test whether the iterator is currently pointing to a valid item. More...
| virtual void | AddTraversalGroupName (const char *groupName)=0 |
| virtual const char * | GetGroupName ()=0 |
| | Return the current group name or NULL if Next() was never called. More...
| virtual const char * | GetProxyName ()=0 |
| | Return the current proxy name or NULL if Next() was never called. More...
| virtual bool | IsCustom () |
| | Return true if the current definition has been defined in the Custom scope. More...
| virtual vtkPVXMLElement * | GetProxyDefinition ()=0 |
| | Return the current XML proxy definition. More...
| virtual vtkPVXMLElement * | GetProxyHints ()=0 |
| | Return the current XML proxy hints. More...
iterates over all proxy definitions from which the vtkSMProxyManager can use to create new proxy.
It can also iterate over registered compound proxy definitions.
vtkPVProxyDefinitionIterator iterates over all proxy definitions known to the proxy manager. The iterator allow to filter the iteration on a subset of group and/or on the global or custom proxies. Custom and Compound proxy are exactly the same thing. We should stick with only one name.
- See also
- vtkSMProxyManager
Definition at line 38 of file vtkPVProxyDefinitionIterator.h.
