| vtkDataObject * | GetCompositeInputData (int port, int index, vtkInformationVector **inInfoVec) |
| | Returns the data object stored with the DATA_OBJECT() in the input port. More...
| vtkInformation * | GetPostArrayToProcessInformation (int idx) |
| void | SetPostArrayToProcessInformation (int idx, vtkInformation *inInfo) |
| vtkCompositeDataPipeline * | NewInstance () const |
| vtkDataObject * | GetCompositeOutputData (int port) |
Public Member Functions inherited from vtkStreamingDemandDrivenPipeline |
| vtkStreamingDemandDrivenPipeline * | NewInstance () const |
| int | PropagateUpdateExtent (int outputPort) |
| virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) |
| virtual int | Update () |
| virtual int | Update (int port) |
| virtual int | UpdateWholeExtent () |
| int | PropagateTime (int outputPort) |
| int | UpdateTimeDependentInformation (int outputPort) |
| int | SetRequestExactExtent (int port, int flag) |
| int | GetRequestExactExtent (int port) |
| int | SetUpdateExtent (int port, int extent[6]) |
| int | SetUpdateExtent (int port, int x0, int x1, int y0, int y1, int z0, int z1) |
| int | SetUpdateExtent (int port, int piece, int numPieces, int ghostLevel) |
| int | SetUpdateTimeStep (int port, double time) |
Public Member Functions inherited from vtkDemandDrivenPipeline |
| vtkDemandDrivenPipeline * | NewInstance () const |
| virtual int | SetReleaseDataFlag (int port, int n) |
| virtual int | GetReleaseDataFlag (int port) |
| virtual int | UpdatePipelineMTime () |
| virtual int | UpdateDataObject () |
| virtual int | UpdateInformation () |
| virtual int | UpdateData (int outputPort) |
| virtual vtkMTimeType | GetPipelineMTime () |
| vtkExecutive * | NewInstance () const |
| vtkAlgorithm * | GetAlgorithm () |
| virtual vtkInformation * | GetOutputInformation (int port) |
| vtkInformationVector * | GetOutputInformation () |
| vtkInformation * | GetInputInformation (int port, int connection) |
| vtkInformationVector * | GetInputInformation (int port) |
| vtkInformationVector ** | GetInputInformation () |
| vtkExecutive * | GetInputExecutive (int port, int connection) |
| virtual vtkDataObject * | GetOutputData (int port) |
| virtual void | SetOutputData (int port, vtkDataObject *, vtkInformation *info) |
| virtual void | SetOutputData (int port, vtkDataObject *) |
| virtual vtkDataObject * | GetInputData (int port, int connection) |
| virtual vtkDataObject * | GetInputData (int port, int connection, vtkInformationVector **inInfoVec) |
| void | SetSharedInputInformation (vtkInformationVector **inInfoVec) |
| void | SetSharedOutputInformation (vtkInformationVector *outInfoVec) |
| virtual int | CallAlgorithm (vtkInformation *request, int direction, vtkInformationVector **inInfo, vtkInformationVector *outInfo) |
| static vtkPVPostFilterExecutive * | New () |
| static vtkPVPostFilterExecutive * | SafeDownCast (vtkObject *o) |
| static vtkInformationInformationVectorKey * | POST_ARRAYS_TO_PROCESS () |
| static vtkInformationStringVectorKey * | POST_ARRAY_COMPONENT_KEY () |
| static vtkPVCompositeDataPipeline * | New () |
| static vtkPVCompositeDataPipeline * | SafeDownCast (vtkObject *o) |
| static vtkCompositeDataPipeline * | New () |
| static vtkCompositeDataPipeline * | SafeDownCast (vtkObjectBase *o) |
| static vtkInformationIntegerKey * | LOAD_REQUESTED_BLOCKS () |
| static vtkInformationObjectBaseKey * | COMPOSITE_DATA_META_DATA () |
| static vtkInformationIntegerVectorKey * | UPDATE_COMPOSITE_INDICES () |
| static vtkInformationDoubleKey * | BLOCK_AMOUNT_OF_DETAIL () |
Static Public Member Functions inherited from vtkStreamingDemandDrivenPipeline |
| static vtkStreamingDemandDrivenPipeline * | New () |
| static vtkStreamingDemandDrivenPipeline * | SafeDownCast (vtkObjectBase *o) |
| static vtkInformationRequestKey * | REQUEST_UPDATE_EXTENT () |
| static vtkInformationRequestKey * | REQUEST_UPDATE_TIME () |
| static vtkInformationRequestKey * | REQUEST_TIME_DEPENDENT_INFORMATION () |
| static vtkInformationIntegerKey * | CONTINUE_EXECUTING () |
| static vtkInformationIntegerKey * | UPDATE_EXTENT_INITIALIZED () |
| static vtkInformationIntegerVectorKey * | UPDATE_EXTENT () |
| static vtkInformationIntegerKey * | UPDATE_PIECE_NUMBER () |
| static vtkInformationIntegerKey * | UPDATE_NUMBER_OF_PIECES () |
| static vtkInformationIntegerKey * | UPDATE_NUMBER_OF_GHOST_LEVELS () |
| static vtkInformationIntegerVectorKey * | COMBINED_UPDATE_EXTENT () |
| static vtkInformationIntegerVectorKey * | WHOLE_EXTENT () |
| static vtkInformationIntegerKey * | UNRESTRICTED_UPDATE_EXTENT () |
| static vtkInformationIntegerKey * | EXACT_EXTENT () |
| static vtkInformationDoubleVectorKey * | TIME_STEPS () |
| static vtkInformationDoubleVectorKey * | TIME_RANGE () |
| static vtkInformationDoubleKey * | UPDATE_TIME_STEP () |
| static vtkInformationIntegerKey * | TIME_DEPENDENT_INFORMATION () |
| static vtkInformationDoubleVectorKey * | BOUNDS () |
| static int | SetWholeExtent (vtkInformation *, int extent[6]) |
| static void | GetWholeExtent (vtkInformation *, int extent[6]) |
| static int * | GetWholeExtent (vtkInformation *) |
| static int | SetUpdateExtentToWholeExtent (vtkInformation *) |
| static int | SetUpdateExtent (vtkInformation *, int extent[6]) |
| static void | GetUpdateExtent (vtkInformation *, int extent[6]) |
| static int * | GetUpdateExtent (vtkInformation *) |
| static int | SetUpdateExtent (vtkInformation *, int piece, int numPieces, int ghostLevel) |
| static int | SetUpdatePiece (vtkInformation *, int piece) |
| static int | GetUpdatePiece (vtkInformation *) |
| static int | SetUpdateNumberOfPieces (vtkInformation *, int n) |
| static int | GetUpdateNumberOfPieces (vtkInformation *) |
| static int | SetUpdateGhostLevel (vtkInformation *, int n) |
| static int | GetUpdateGhostLevel (vtkInformation *) |
| static int | SetUpdateTimeStep (vtkInformation *, double time) |
Static Public Member Functions inherited from vtkDemandDrivenPipeline |
| static vtkDemandDrivenPipeline * | New () |
| static vtkDemandDrivenPipeline * | SafeDownCast (vtkObjectBase *o) |
| static vtkInformationRequestKey * | REQUEST_DATA_OBJECT () |
| static vtkInformationRequestKey * | REQUEST_INFORMATION () |
| static vtkInformationRequestKey * | REQUEST_DATA () |
| static vtkInformationRequestKey * | REQUEST_DATA_NOT_GENERATED () |
| static vtkInformationIntegerKey * | RELEASE_DATA () |
| static vtkInformationIntegerKey * | DATA_NOT_GENERATED () |
| static vtkDataObject * | NewDataObject (const char *type) |
| static vtkExecutive * | SafeDownCast (vtkObjectBase *o) |
| static vtkInformationExecutivePortKey * | PRODUCER () |
| static vtkInformationExecutivePortVectorKey * | CONSUMERS () |
| static vtkInformationIntegerKey * | FROM_OUTPUT_PORT () |
| static vtkInformationIntegerKey * | ALGORITHM_BEFORE_FORWARD () |
| static vtkInformationIntegerKey * | ALGORITHM_AFTER_FORWARD () |
| static vtkInformationIntegerKey * | ALGORITHM_DIRECTION () |
| static vtkInformationIntegerKey * | FORWARD_DIRECTION () |
| static vtkInformationKeyVectorKey * | KEYS_TO_COPY () |
| | vtkPVPostFilterExecutive () |
| | ~vtkPVPostFilterExecutive () override |
| int | NeedToExecuteData (int outputPort, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) override |
| bool | MatchingPropertyInformation (vtkInformation *inputArrayInfo, vtkInformation *postArrayInfo) |
| | vtkPVCompositeDataPipeline () |
| | ~vtkPVCompositeDataPipeline () override |
| void | CopyDefaultInformation (vtkInformation *request, int direction, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) override |
| void | ResetPipelineInformation (int port, vtkInformation *) override |
| | vtkCompositeDataPipeline () |
| | ~vtkCompositeDataPipeline () |
| virtual int | ForwardUpstream (vtkInformation *request) |
| virtual int | ForwardUpstream (int i, int j, vtkInformation *request) |
| virtual void | PushInformation (vtkInformation *) |
| virtual void | PopInformation (vtkInformation *) |
| virtual int | ExecuteDataObject (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) |
| virtual int | ExecuteData (vtkInformation *request, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) |
| virtual void | ExecuteDataStart (vtkInformation *request, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) |
| virtual int | CheckCompositeData (vtkInformation *request, int port, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) |
| virtual void | ExecuteSimpleAlgorithm (vtkInformation *request, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec, int compositePort) |
| virtual void | ExecuteEach (vtkCompositeDataIterator *iter, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec, int compositePort, int connection, vtkInformation *request, vtkCompositeDataSet *compositeOutput) |
| vtkDataObject * | ExecuteSimpleAlgorithmForBlock (vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec, vtkInformation *inInfo, vtkInformation *outInfo, vtkInformation *request, vtkDataObject *dobj) |
| bool | ShouldIterateOverInput (vtkInformationVector **inInfoVec, int &compositePort) |
| virtual int | InputTypeIsValid (int port, int index, vtkInformationVector **inInfoVec) |
| virtual void | MarkOutputsGenerated (vtkInformation *request, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) |
| int | NeedToExecuteBasedOnCompositeIndices (vtkInformation *outInfo) |
| vtkCompositeDataSet * | CreateOutputCompositeDataSet (vtkCompositeDataSet *input, int compositePort) |
Protected Member Functions inherited from vtkStreamingDemandDrivenPipeline |
| | vtkStreamingDemandDrivenPipeline () |
| | ~vtkStreamingDemandDrivenPipeline () |
| virtual int | NeedToExecuteBasedOnTime (vtkInformation *outInfo, vtkDataObject *dataObject) |
| virtual int | ExecuteInformation (vtkInformation *request, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) |
| virtual int | VerifyOutputInformation (int outputPort, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) |
| virtual void | ExecuteDataEnd (vtkInformation *request, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) |
Protected Member Functions inherited from vtkDemandDrivenPipeline |
| | vtkDemandDrivenPipeline () |
| | ~vtkDemandDrivenPipeline () |
| virtual int | CheckDataObject (int port, vtkInformationVector *outInfo) |
| int | InputCountIsValid (vtkInformationVector **) |
| int | InputCountIsValid (int port, vtkInformationVector **) |
| int | InputTypeIsValid (vtkInformationVector **) |
| int | InputTypeIsValid (int port, vtkInformationVector **) |
| int | InputFieldsAreValid (vtkInformationVector **) |
| int | InputFieldsAreValid (int port, vtkInformationVector **) |
| virtual int | InputFieldsAreValid (int port, int index, vtkInformationVector **) |
| int | DataSetAttributeExists (vtkDataSetAttributes *dsa, vtkInformation *field) |
| int | FieldArrayExists (vtkFieldData *data, vtkInformation *field) |
| int | ArrayIsValid (vtkAbstractArray *array, vtkInformation *field) |
| int | InputIsOptional (int port) |
| int | InputIsRepeatable (int port) |
| | vtkExecutive () |
| | ~vtkExecutive () |
| int | InputPortIndexInRange (int port, const char *action) |
| int | OutputPortIndexInRange (int port, const char *action) |
| int | CheckAlgorithm (const char *method, vtkInformation *request) |
| virtual int | ForwardDownstream (vtkInformation *request) |
| virtual void | SetAlgorithm (vtkAlgorithm *algorithm) |
| | vtkObject () |
| | vtkObjectBase () |
Executive supporting post filters.
vtkPVPostFilterExecutive is an executive that supports the creation of post filters for the following uses cases: Provide the ability to automatically use a vector component as a scalar input property.
Interpolate cell centered data to point data, and the inverse if needed by the filter.
Definition at line 38 of file vtkPVPostFilterExecutive.h.
