Used to load ParaView plugins. More...
#include <vtkPVPluginLoader.h>
| bool | LoadPluginByName (const char *name) |
| Tries to the load the plugin by name using tracked plugins. More... | |
| bool | LoadPlugin (const char *filename) |
| Tries to the load the plugin given the path to the plugin file. More... | |
| bool | LoadPluginSilently (const char *filename) |
| void | LoadPluginConfigurationXMLFromString (const char *xmlcontents) |
| Simply forwards the call to vtkPVPluginLoader::LoadPluginConfigurationXMLFromString to load configuration xml. More... | |
| void | LoadPluginsFromPluginSearchPath () |
| Loads all plugins under the directories mentioned in the SearchPaths. More... | |
| void | LoadPluginsFromPluginConfigFile () |
| Use PV_PLUGIN_CONFILE_FILE xml file to load specified plugins It can contain path to multiples xml pluginc config files sperated by env separator. More... | |
| void | LoadPluginsFromPath (const char *path) |
| Loads all plugin libraries at a path. More... | |
| virtual char * | GetFileName () |
| Returns the full filename for the plugin attempted to load most recently using LoadPlugin(). More... | |
| virtual char * | GetPluginName () |
| Get the plugin name. More... | |
| virtual char * | GetPluginVersion () |
| Get the plugin version string. More... | |
| virtual char * | GetErrorString () |
| Get the error string if the plugin failed to load. More... | |
| virtual char * | GetSearchPaths () |
| Get a string of standard search paths (path1;path2;path3) search paths are based on PV_PLUGIN_PATH, plugin dir relative to executable. More... | |
| virtual bool | GetLoaded () |
| Returns the status of most recent LoadPlugin call. More... | |
| static vtkPVPluginLoader * | New () |
| static vtkPVPluginLoader * | SafeDownCast (vtkObject *o) |
| static void | PluginLibraryUnloaded (const char *pluginname) |
| Internal method used in pqParaViewPlugin.cxx.in to tell the vtkPVPluginLoader that a library was unloaded so it doesn't try to unload it again. More... | |
| vtkPVPluginLoader () | |
| ~vtkPVPluginLoader () override | |
| bool | LoadPluginInternal (const char *filename, bool no_errors) |
| bool | LoadPluginInternal (vtkPVPlugin *plugin) |
| Called by LoadPluginInternal() to do the final steps in loading of a plugin. More... | |
| virtual void | SetErrorString (const char *) |
| virtual void | SetPluginName (const char *) |
| virtual void | SetPluginVersion (const char *) |
| virtual void | SetFileName (const char *) |
| virtual void | SetSearchPaths (const char *) |
Protected Attributes | |
| char * | ErrorString |
| char * | PluginName |
| char * | PluginVersion |
| char * | FileName |
| char * | SearchPaths |
| bool | Loaded |
| using | PluginLoaderCallback = std::function< bool(const char *)> |
| static int | RegisterLoadPluginCallback (PluginLoaderCallback callback) |
| static void | UnregisterLoadPluginCallback (int id) |
vtkPVPluginLoader can be used to load plugins for ParaView. vtkPVPluginLoader loads the plugin on the local process.
vtkPVPluginLoader logs plugin related messages using at PARAVIEW_LOG_PLUGIN_VERBOSITY level. See vtkPVLogger::SetPluginVerbosity for information on using environment variables to override or elevate the verbosity level.
This class only needed when loading plugins from shared libraries dynamically. For statically importing plugins, one directly uses PV_PLUGIN_IMPORT() macro defined in vtkPVPlugin.h.
Definition at line 42 of file vtkPVPluginLoader.h.
Definition at line 46 of file vtkPVPluginLoader.h.
| using vtkPVPluginLoader::PluginLoaderCallback = std::function<bool(const char*)> |
Definition at line 145 of file vtkPVPluginLoader.h.
| bool vtkPVPluginLoader::LoadPluginByName | ( | const char * | name | ) |
Definition at line 57 of file vtkPVPluginLoader.h.
Definition at line 58 of file vtkPVPluginLoader.h.
| void vtkPVPluginLoader::LoadPluginConfigurationXMLFromString | ( | const char * | xmlcontents | ) |
| void vtkPVPluginLoader::LoadPluginsFromPluginSearchPath | ( | ) |
| void vtkPVPluginLoader::LoadPluginsFromPluginConfigFile | ( | ) |
It allow user to fine pick which plugins to load, instead of using PV_PLUGIN_PATH the format a xml plugin file should be the following :
| void vtkPVPluginLoader::LoadPluginsFromPath | ( | const char * | path | ) |
This returns a valid name only after the plugin has been loaded.
This returns a valid version string only after the plugin has been loaded.
Returns NULL if the plugin was loaded successfully.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Definition at line 173 of file vtkPVPluginLoader.h.
Definition at line 176 of file vtkPVPluginLoader.h.
Definition at line 177 of file vtkPVPluginLoader.h.
Definition at line 178 of file vtkPVPluginLoader.h.
Definition at line 179 of file vtkPVPluginLoader.h.
Definition at line 180 of file vtkPVPluginLoader.h.
