| virtual void | SetAxisAligned (bool) |
| | Accessors for AxisAligned, which locks normal to plane to be aligned with x, y, or z axis. More...
| virtual bool | GetAxisAligned () |
| void | SetTransform (vtkAbstractTransform *) override |
| | Set/Get a transformation to apply to input points before executing the implicit function. More...
| void | SetTransform (const double elements[16]) override |
| void | EvaluateFunction (vtkDataArray *input, vtkDataArray *output) override |
| double | EvaluateFunction (double x[3]) override |
| void | EvaluateGradient (double x[3], double g[3]) override |
| | Evaluate function gradient at position x-y-z and pass back vector. More...
| virtual void | SetOffset (double) |
| | The origin is shifted in the direction of the normal by the offset. More...
| virtual double | GetOffset () |
| void | SetNormal (double x, double y, double z) override |
| | If AxisAligned is true, sets axis to the nearest canonical axis. More...
| void | SetNormal (const double *x) override |
| vtkPlane * | NewInstance () const |
| void | Push (double distance) |
| double | EvaluateFunction (double x, double y, double z) |
| virtual void | SetNormal (double[3]) |
| virtual double * | GetNormal () |
| virtual void | GetNormal (double data[3]) |
| virtual void | SetOrigin (double, double, double) |
| virtual void | SetOrigin (double[3]) |
| virtual double * | GetOrigin () |
| virtual void | GetOrigin (double data[3]) |
| void | ProjectPoint (double x[3], double xproj[3]) |
| void | ProjectVector (double v[3], double vproj[3]) |
| void | GeneralizedProjectPoint (double x[3], double xproj[3]) |
| double | DistanceToPlane (double x[3]) |
| int | IntersectWithLine (double p1[3], double p2[3], double &t, double x[3]) |
| vtkImplicitFunction * | NewInstance () const |
| vtkMTimeType | GetMTime () |
| double | FunctionValue (const double x[3]) |
| double | FunctionValue (double x, double y, double z) |
| void | FunctionGradient (const double x[3], double g[3]) |
| double * | FunctionGradient (const double x[3]) |
| double * | FunctionGradient (double x, double y, double z) |
| virtual vtkAbstractTransform * | GetTransform () |
extends vtkPlane to add Offset parameter.
vtkPVPlane adds an offset setting to vtkPlane. This offset is used together with normal and origin when setting parameters on the represented object.
Definition at line 30 of file vtkPVPlane.h.
