Meta class for slice filter that will allow the user to switch between a regular cutter filter or an extract cell by region filter.
| void | PreserveInputCells (int keepCellAsIs) |
| | Enable or disable the Extract Cells By Regions. More...
| vtkAlgorithm * | SetActiveFilter (int index) override |
| | Override it so we can change the output type of the filter. More...
| void | SetImplicitFunction (vtkImplicitFunction *func) |
| void | SetDataSetCutFunction (vtkImplicitFunction *func) |
| | Sets the cut function for vtkDataSet inputs. More...
| void | SetHyperTreeGridCutFunction (vtkImplicitFunction *func) |
| | Sets the cut function for vtkHyperTreeGrid inputs. More...
| void | SetCutFunction (vtkImplicitFunction *func) |
| | Expose method from vtkPVCutter. More...
| void | SetNumberOfContours (int nbContours) |
| void | SetValue (int index, double value) |
| void | SetGenerateTriangles (int status) |
| void | SetMergePoints (bool status) |
| void | SetDual (bool dual) |
| | Method used for vtkHyperTreeGridPlaneCutter. More...
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| int | RegisterFilter (vtkAlgorithm *filter) |
| | Register a new filter that can be used underneath in the requestData call. More...
| void | UnRegisterFilter (int index) |
| | UnRegister an existing filter that was previously registered. More...
| void | ClearFilters () |
| | Remove all the registered filters. More...
| int | GetNumberOfFilters () |
| | Return the current number of registered filters. More...
| vtkAlgorithm * | GetFilter (int index) |
| | Return the filter that lies at the given index of the filters registration queue. More...
| vtkAlgorithm * | GetActiveFilter () |
| | Return the current active filter if any otherwise return NULL. More...
| vtkMTimeType | GetMTime () override |
| | Override GetMTime because we delegate to other filters to do the real work. More...
| int | ProcessRequest (vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override |
| | Forward those methods to the underneath filters. More...
| virtual int | ProcessRequest (vtkInformation *request, vtkCollection *inInfo, vtkInformationVector *outInfo) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVMetaSliceDataSet () |
| | ~vtkPVMetaSliceDataSet () override |
| | vtkPVDataSetAlgorithmSelectorFilter () |
| | ~vtkPVDataSetAlgorithmSelectorFilter () override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| virtual int | GetOutputType () |
| virtual void | SetOutputType (int) |
| void | InternalProgressCallback (vtkAlgorithm *algorithm) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Definition at line 33 of file vtkPVMetaSliceDataSet.h.
