| void | SetController (vtkMultiProcessController *) |
| | Get/Set the vtkMultiProcessController to use for parallel processing. More...
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetGlyphMode (int) |
| | Set/Get the mode at which glyphs will be generated. More...
| virtual int | GetGlyphMode () |
| virtual void | SetStride (int) |
| | Set/Get the stride at which to glyph the dataset. More...
| virtual int | GetStride () |
| virtual void | SetSeed (int) |
| | Set/Get Seed used for generating a spatially uniform distribution. More...
| virtual int | GetSeed () |
| virtual void | SetMaximumNumberOfSamplePoints (int) |
| | Set/Get maximum number of sample points to use to sample the space when GlyphMode is set to SPATIALLY_UNIFORM_DISTRIBUTION. More...
| virtual int | GetMaximumNumberOfSamplePoints () |
| vtkGlyph3D * | NewInstance () const |
| void | SetSourceData (vtkPolyData *pd) |
| void | SetSourceData (int id, vtkPolyData *pd) |
| vtkPolyData * | GetSource (int id=0) |
| void | SetSourceConnection (int id, vtkAlgorithmOutput *algOutput) |
| void | SetSourceConnection (vtkAlgorithmOutput *algOutput) |
| virtual void | SetScaling (int) |
| virtual void | ScalingOn () |
| virtual void | ScalingOff () |
| virtual int | GetScaling () |
| virtual void | SetScaleMode (int) |
| virtual int | GetScaleMode () |
| void | SetScaleModeToScaleByScalar () |
| void | SetScaleModeToScaleByVector () |
| void | SetScaleModeToScaleByVectorComponents () |
| void | SetScaleModeToDataScalingOff () |
| const char * | GetScaleModeAsString () |
| virtual void | SetColorMode (int) |
| virtual int | GetColorMode () |
| void | SetColorModeToColorByScale () |
| void | SetColorModeToColorByScalar () |
| void | SetColorModeToColorByVector () |
| const char * | GetColorModeAsString () |
| virtual void | SetScaleFactor (double) |
| virtual double | GetScaleFactor () |
| virtual void | SetRange (double, double) |
| void | SetRange (double[2]) |
| virtual double * | GetRange () |
| virtual void | GetRange (double data[2]) |
| virtual void | SetOrient (int) |
| virtual void | OrientOn () |
| virtual void | OrientOff () |
| virtual int | GetOrient () |
| virtual void | SetClamping (int) |
| virtual void | ClampingOn () |
| virtual void | ClampingOff () |
| virtual int | GetClamping () |
| virtual void | SetVectorMode (int) |
| virtual int | GetVectorMode () |
| void | SetVectorModeToUseVector () |
| void | SetVectorModeToUseNormal () |
| void | SetVectorModeToVectorRotationOff () |
| const char * | GetVectorModeAsString () |
| virtual void | SetIndexMode (int) |
| virtual int | GetIndexMode () |
| void | SetIndexModeToScalar () |
| void | SetIndexModeToVector () |
| void | SetIndexModeToOff () |
| const char * | GetIndexModeAsString () |
| virtual void | SetGeneratePointIds (int) |
| virtual int | GetGeneratePointIds () |
| virtual void | GeneratePointIdsOn () |
| virtual void | GeneratePointIdsOff () |
| virtual void | SetPointIdsName (const char *) |
| virtual char * | GetPointIdsName () |
| virtual void | SetFillCellData (int) |
| virtual int | GetFillCellData () |
| virtual void | FillCellDataOn () |
| virtual void | FillCellDataOff () |
| void | SetSourceTransform (vtkTransform *) |
| virtual vtkTransform * | GetSourceTransform () |
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| int | FillInputPortInformation (int, vtkInformation *) override |
| int | FillOutputPortInformation (int, vtkInformation *) override |
| int | IsPointVisible (vtkDataSet *ds, vtkIdType ptId) override |
| | Returns 1 if point is to be glyphed, otherwise returns 0. More...
| bool | IsInputArrayToProcessValid (vtkDataSet *input) |
| | Returns true if input Scalars and Vectors are compatible, otherwise returns 0. More...
| bool | UseCellCenters (vtkDataSet *input) |
| | Returns true if input Scalars and Vectors are cell attributes, otherwise returns 0. More...
| bool | NeedsScalars () |
| | Returns true if input scalars are used for glyphing. More...
| bool | NeedsVectors () |
| | Returns true if input vectors are used for glyphing. More...
| virtual bool | ExecuteWithCellCenters (vtkDataSet *input, vtkInformationVector *sourceVector, vtkPolyData *output) |
| | Method called in RequestData() to do the actual data processing. More...
| | vtkGlyph3D () |
| | ~vtkGlyph3D () |
| vtkPolyData * | GetSource (int idx, vtkInformationVector *sourceInfo) |
| virtual bool | Execute (vtkDataSet *input, vtkInformationVector *sourceVector, vtkPolyData *output) |
| virtual bool | Execute (vtkDataSet *input, vtkInformationVector *sourceVector, vtkPolyData *output, vtkDataArray *inSScalars, vtkDataArray *inVectors) |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
extended API for vtkGlyph3D for better control over glyph placement.
vtkPVGlyphFilterLegacy extends vtkGlyph3D for adding control over which points are glyphed using GlyphMode. Three modes are now provided:
- ALL_POINTS: all points in the input dataset are glyphed. This same as using vtkGlyph3D directly.
- EVERY_NTH_POINT: every n-th point in the input dataset when iterated through the input points sequentially is glyphed. For composite datasets, the counter resets every on block. In parallel, independent counter is used on each rank. Use
Stride to control now may points to skip.
- SPATIALLY_UNIFORM_DISTRIBUTION: points close to a randomly sampled spatial distribution of points are glyphed.
Seed controls the seed point for the random number generator (vtkMinimalStandardRandomSequence). MaximumNumberOfSamplePoints can be used to limit the number of sample points used for random sampling. This doesn't not equal the number of points actually glyphed, since that depends on several factors. In parallel, this filter ensures that spatial bounds are collected across all ranks for generating identical sample points.
Definition at line 48 of file vtkPVGlyphFilterLegacy.h.
