| bool | MakeDirectory () |
| | Create a directory named Path. More...
| bool | DeleteDirectory () |
| | Delete a directory named Path. More...
| bool | OpenDirectory () |
| | Open a directory named Path. More...
| bool | RenameDirectory () |
| | Rename a directory named Path to SecondaryPath. More...
| bool | IsDirectory () |
| | Check is directory named Path exists. More...
| bool | GetActiveFileIsReadable () |
| | Returns if this->Path is a readable file. More...
| virtual void | SetPath (const char *) |
| | Get/Set the path that will be used by the helper. More...
| virtual char * | GetPath () |
| virtual void | SetSecondaryPath (const char *) |
| | Get/Set the secondary path that will potentially be used by the helper. More...
| virtual char * | GetSecondaryPath () |
| virtual int | GetActiveGlobalId () |
| | Get/Set the globalId of the vtkDirectory present of the server that we will use to manipulate directories. More...
| virtual void | SetActiveGlobalId (int) |
server side object used to check if manipulate a directory
Server side object to list, create and remove directory the main reason for this helper to exist is to convert the file path from utf8 to locale encoding
Definition at line 30 of file vtkPVFilePathEncodingHelper.h.
