| void | ResetActiveAnnotatedValues () |
| void | SetActiveAnnotatedValue (std::string value) |
| void | SetNumberOfIndexedColorsInFullSet (int n) |
| int | GetNumberOfIndexedColorsInFullSet () |
| void | SetIndexedColorInFullSet (unsigned int index, double r, double g, double b) |
| void | GetIndexedColorInFullSet (unsigned int index, double rgb[3]) |
| void | SetNumberOfIndexedOpacitiesInFullSet (int n) |
| int | GetNumberOfIndexedOpacitiesInFullSet () |
| void | SetIndexedOpacityInFullSet (unsigned int index, double alpha) |
| void | GetIndexedOpacityInFullSet (unsigned int index, double *alpha) |
| void | Build () override |
| | Override to set only the active annotations. More...
| virtual void | SetAnnotationsInFullSet (vtkAbstractArray *values, vtkStringArray *annotations) |
| | Parallel API to API for annotated values to set/get the full list of annotations. More...
| virtual vtkAbstractArray * | GetAnnotatedValuesInFullSet () |
| virtual vtkStringArray * | GetAnnotationsInFullSet () |
| virtual vtkIdType | SetAnnotationInFullSet (vtkVariant value, std::string annotation) |
| virtual vtkIdType | SetAnnotationInFullSet (std::string value, std::string annotation) |
| virtual void | ResetAnnotationsInFullSet () |
| virtual void | SetUseActiveValues (bool) |
| | Set whether to use restrict annotations to only the values designated as active. More...
| virtual bool | GetUseActiveValues () |
| virtual void | UseActiveValuesOn () |
| virtual void | UseActiveValuesOff () |
| vtkDiscretizableColorTransferFunction * | NewInstance () const |
| int | IsOpaque () |
| virtual void | GetIndexedColor (vtkIdType i, double rgba[4]) |
| virtual unsigned char * | MapValue (double v) |
| virtual void | GetColor (double v, double rgb[3]) |
| virtual double | GetOpacity (double v) |
| double * | GetRGBPoints () |
| virtual void | SetAlpha (double alpha) |
| virtual vtkIdType | GetNumberOfAvailableColors () |
| void | SetIndexedColor (unsigned int index, const double rgb[3]) |
| void | SetIndexedColor (unsigned int index, double r, double g, double b) |
| void | SetNumberOfIndexedColors (unsigned int count) |
| unsigned int | GetNumberOfIndexedColors () |
| virtual void | SetDiscretize (int) |
| virtual int | GetDiscretize () |
| virtual void | DiscretizeOn () |
| virtual void | DiscretizeOff () |
| virtual void | SetUseLogScale (int useLogScale) |
| virtual int | GetUseLogScale () |
| virtual void | SetNumberOfValues (vtkIdType) |
| virtual vtkIdType | GetNumberOfValues () |
| virtual vtkUnsignedCharArray * | MapScalars (vtkDataArray *scalars, int colorMode, int component) |
| virtual vtkUnsignedCharArray * | MapScalars (vtkAbstractArray *scalars, int colorMode, int component) |
| virtual void | SetNanColor (double r, double g, double b) |
| virtual void | SetNanColor (double rgb[3]) |
| virtual int | UsingLogScale () |
| virtual void | SetScalarOpacityFunction (vtkPiecewiseFunction *function) |
| virtual vtkPiecewiseFunction * | GetScalarOpacityFunction () const |
| virtual void | SetEnableOpacityMapping (bool) |
| virtual bool | GetEnableOpacityMapping () |
| virtual void | EnableOpacityMappingOn () |
| virtual void | EnableOpacityMappingOff () |
| vtkColorTransferFunction * | NewInstance () const |
| void | DeepCopy (vtkScalarsToColors *f) |
| void | ShallowCopy (vtkColorTransferFunction *f) |
| int | GetSize () |
| void | RemoveAllPoints () |
| int | AdjustRange (double range[2]) |
| void | BuildFunctionFromTable (double x1, double x2, int size, double *table) |
| double * | GetDataPointer () |
| void | FillFromDataPointer (int n, double *ptr) |
| int | AddRGBPoint (double x, double r, double g, double b) |
| int | AddRGBPoint (double x, double r, double g, double b, double midpoint, double sharpness) |
| int | AddHSVPoint (double x, double h, double s, double v) |
| int | AddHSVPoint (double x, double h, double s, double v, double midpoint, double sharpness) |
| int | RemovePoint (double x) |
| void | AddRGBSegment (double x1, double r1, double g1, double b1, double x2, double r2, double g2, double b2) |
| void | AddHSVSegment (double x1, double h1, double s1, double v1, double x2, double h2, double s2, double v2) |
| double * | GetColor (double x) |
| double | GetRedValue (double x) |
| double | GetGreenValue (double x) |
| double | GetBlueValue (double x) |
| int | GetNodeValue (int index, double val[6]) |
| int | SetNodeValue (int index, double val[6]) |
| virtual double * | GetRange () |
| virtual void | GetRange (double &, double &) |
| virtual void | GetRange (double[2]) |
| void | GetTable (double x1, double x2, int n, double *table) |
| void | GetTable (double x1, double x2, int n, float *table) |
| const unsigned char * | GetTable (double x1, double x2, int n) |
| virtual void | SetClamping (int) |
| virtual int | GetClamping () |
| virtual void | ClampingOn () |
| virtual void | ClampingOff () |
| virtual void | SetColorSpace (int) |
| void | SetColorSpaceToRGB () |
| void | SetColorSpaceToHSV () |
| void | SetColorSpaceToLab () |
| void | SetColorSpaceToDiverging () |
| virtual int | GetColorSpace () |
| virtual void | SetHSVWrap (int) |
| virtual int | GetHSVWrap () |
| virtual void | HSVWrapOn () |
| virtual void | HSVWrapOff () |
| virtual void | SetScale (int) |
| void | SetScaleToLinear () |
| void | SetScaleToLog10 () |
| virtual int | GetScale () |
| virtual double * | GetNanColor () |
| virtual void | GetNanColor (double &, double &, double &) |
| virtual void | GetNanColor (double[3]) |
| virtual void | SetBelowRangeColor (double, double, double) |
| virtual void | SetBelowRangeColor (double[3]) |
| virtual double * | GetBelowRangeColor () |
| virtual void | GetBelowRangeColor (double &, double &, double &) |
| virtual void | GetBelowRangeColor (double[3]) |
| virtual void | SetUseBelowRangeColor (int) |
| virtual int | GetUseBelowRangeColor () |
| virtual void | UseBelowRangeColorOn () |
| virtual void | UseBelowRangeColorOff () |
| virtual void | SetAboveRangeColor (double, double, double) |
| virtual void | SetAboveRangeColor (double[3]) |
| virtual double * | GetAboveRangeColor () |
| virtual void | GetAboveRangeColor (double &, double &, double &) |
| virtual void | GetAboveRangeColor (double[3]) |
| virtual void | SetUseAboveRangeColor (int) |
| virtual int | GetUseAboveRangeColor () |
| virtual void | UseAboveRangeColorOn () |
| virtual void | UseAboveRangeColorOff () |
| virtual void | MapScalarsThroughTable2 (void *input, unsigned char *output, int inputDataType, int numberOfValues, int inputIncrement, int outputIncrement) |
| virtual void | SetAllowDuplicateScalars (int) |
| virtual int | GetAllowDuplicateScalars () |
| virtual void | AllowDuplicateScalarsOn () |
| virtual void | AllowDuplicateScalarsOff () |
| vtkScalarsToColors * | NewInstance () const |
| virtual vtkIdType | SetAnnotation (vtkVariant value, vtkStdString annotation) |
| virtual vtkIdType | SetAnnotation (vtkStdString value, vtkStdString annotation) |
| vtkIdType | GetNumberOfAnnotatedValues () |
| vtkVariant | GetAnnotatedValue (vtkIdType idx) |
| vtkStdString | GetAnnotation (vtkIdType idx) |
| virtual void | GetAnnotationColor (const vtkVariant &val, double rgba[4]) |
| vtkIdType | GetAnnotatedValueIndex (vtkVariant val) |
| vtkIdType | GetAnnotatedValueIndexInternal (vtkVariant &val) |
| virtual bool | RemoveAnnotation (vtkVariant value) |
| virtual void | ResetAnnotations () |
| void | SetRange (double rng[2]) |
| double * | GetColor (double v) |
| double | GetLuminance (double x) |
| virtual double | GetAlpha () |
| virtual void | SetVectorMode (int) |
| virtual int | GetVectorMode () |
| void | SetVectorModeToMagnitude () |
| void | SetVectorModeToComponent () |
| void | SetVectorModeToRGBColors () |
| virtual void | SetVectorComponent (int) |
| virtual int | GetVectorComponent () |
| virtual void | SetVectorSize (int) |
| virtual int | GetVectorSize () |
| void | MapVectorsThroughTable (void *input, unsigned char *output, int inputDataType, int numberOfValues, int inputIncrement, int outputFormat, int vectorComponent, int vectorSize) |
| void | MapVectorsThroughTable (void *input, unsigned char *output, int inputDataType, int numberOfValues, int inputIncrement, int outputFormat) |
| void | MapScalarsThroughTable (vtkDataArray *scalars, unsigned char *output, int outputFormat) |
| void | MapScalarsThroughTable (vtkDataArray *scalars, unsigned char *output) |
| void | MapScalarsThroughTable (void *input, unsigned char *output, int inputDataType, int numberOfValues, int inputIncrement, int outputFormat) |
| virtual void | SetAnnotations (vtkAbstractArray *values, vtkStringArray *annotations) |
| virtual vtkAbstractArray * | GetAnnotatedValues () |
| virtual vtkStringArray * | GetAnnotations () |
| virtual void | SetIndexedLookup (int) |
| virtual int | GetIndexedLookup () |
| virtual void | IndexedLookupOn () |
| virtual void | IndexedLookupOff () |
| unsigned char | ColorToUChar (double t) |
| unsigned char | ColorToUChar (float t) |
