| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| vtkContourFilter * | NewInstance () const |
| vtkMTimeType | GetMTime () |
| void | CreateDefaultLocator () |
| void | SetValue (int i, double value) |
| double | GetValue (int i) |
| double * | GetValues () |
| void | GetValues (double *contourValues) |
| void | SetNumberOfContours (int number) |
| int | GetNumberOfContours () |
| void | GenerateValues (int numContours, double range[2]) |
| void | GenerateValues (int numContours, double rangeStart, double rangeEnd) |
| virtual void | SetComputeNormals (int) |
| virtual int | GetComputeNormals () |
| virtual void | ComputeNormalsOn () |
| virtual void | ComputeNormalsOff () |
| virtual void | SetComputeGradients (int) |
| virtual int | GetComputeGradients () |
| virtual void | ComputeGradientsOn () |
| virtual void | ComputeGradientsOff () |
| virtual void | SetComputeScalars (int) |
| virtual int | GetComputeScalars () |
| virtual void | ComputeScalarsOn () |
| virtual void | ComputeScalarsOff () |
| virtual void | SetUseScalarTree (int) |
| virtual int | GetUseScalarTree () |
| virtual void | UseScalarTreeOn () |
| virtual void | UseScalarTreeOff () |
| virtual void | SetScalarTree (vtkScalarTree *) |
| virtual vtkScalarTree * | GetScalarTree () |
| void | SetLocator (vtkIncrementalPointLocator *locator) |
| virtual vtkIncrementalPointLocator * | GetLocator () |
| void | SetArrayComponent (int) |
| int | GetArrayComponent () |
| virtual void | SetGenerateTriangles (int) |
| virtual int | GetGenerateTriangles () |
| virtual void | GenerateTrianglesOn () |
| virtual void | GenerateTrianglesOff () |
| void | SetOutputPointsPrecision (int precision) |
| int | GetOutputPointsPrecision () const |
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVContourFilter () |
| | ~vtkPVContourFilter () override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | ContourUsingSuperclass (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| | Class superclass request data. More...
| void | CleanOutputScalars (vtkDataArray *outScalars) |
| | When ComputeScalars is true, the filter computes scalars for the contours. More...
| | vtkContourFilter () |
| | ~vtkContourFilter () |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
generate isosurfaces/isolines from scalar values
vtkPVContourFilter is an extension to vtkContourFilter. It adds the ability to generate isosurfaces / isolines for AMR dataset.
vtkPVContourFilter also handles cleaning up interpolation error in the output scalars array when ComputeScalars is set to true. For each requested contour value, the output scalar array may have an error introduced due to interpolation along an edge. This filter fixes that error so that for all points generated from a particular contour value, the scalar array will have exactly the same value.
For certain inputs, this filter delegates operation to vtkContour3DLinearGrid. The input must meet the following conditions for this filter to be used:
- all cells in the input are linear (i.e., not higher order)
- the contour array is one of the types supported by the vtkContour3DLinearGrid
- the ComputeScalars option is off
- Warning
- Certain flags in vtkAMRDualContour are assumed to be ON.
- See also
- vtkContourFilter vtkAMRDualContour
Definition at line 49 of file vtkPVContourFilter.h.
