| void | CopyFromObject (vtkObject *) override |
| | Transfer information about a single object into this object. More...
| void | AddInformation (vtkPVInformation *) override |
| | Merge another information object. More...
| virtual void | Initialize () |
| | Clears all internal data structures. More...
| unsigned int | GetNumberOfChildren () |
| | Returns the number of children. More...
| vtkPVDataInformation * | GetDataInformation (unsigned int idx) |
| | Returns the information for the data object at the given index. More...
| const char * | GetName (unsigned int idx) |
| | Return the name of the child node at the given index, if any. More...
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual int | GetDataIsMultiPiece () |
| | Get/Set if the data is multipiece. More...
| virtual int | GetDataIsComposite () |
| | Returns if the dataset is a composite dataset. More...
| virtual unsigned int | GetNumberOfAMRLevels () |
| | Returns the number of levels in the AMR dataset. More...
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
Light object for holding composite data information.
vtkPVCompositeDataInformation is used to copy the meta information of a composite dataset from server to client. It holds a vtkPVDataInformation for each block of the composite dataset.
- See also
- vtkHierarchicalBoxDataSet vtkPVDataInformation
Definition at line 37 of file vtkPVCompositeDataInformation.h.
