| void | CopyFromObject (vtkObject *) override |
| | Transfer information about a single object into this object. More...
| void | AddInformation (vtkPVInformation *) override |
| | Merge another information object. More...
| virtual int | GetNumberOfOutputs () |
| | Get number of outputs for a particular source. More...
| virtual int | GetNumberOfRequiredInputs () |
| | Get the number of required inputs for a particular algorithm. More...
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
Holds number of outputs.
This information object collects the number of outputs from the sources. This is separate from vtkPVDataInformation because the number of outputs can be determined before Update is called.
Definition at line 30 of file vtkPVAlgorithmPortsInformation.h.
