| virtual void | SetSignedDeviations (int) |
| virtual int | GetSignedDeviations () |
| int | GetNumberOfAttributeArrays () |
| | Return the number of columns available for the current value of AttributeMode. More...
| const char * | GetAttributeArrayName (int n) |
| | Get the name of the n-th array ffor the current value of AttributeMode. More...
| int | GetAttributeArrayStatus (const char *arrName) |
| | Get the status of the specified array (i.e., whether or not it is a column of interest). More...
| vtkInformationIntegerKey * | MULTIPLE_MODELS () |
| | A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
| virtual int | GetAttributeMode () |
| | Set/get the type of field attribute (cell, point, field) More...
| virtual void | SetAttributeMode (int) |
| void | EnableAttributeArray (const char *arrName) |
| | An alternate interface for preparing a selection of arrays in ParaView. More...
| void | ClearAttributeArrays () |
| virtual void | SetTrainingFraction (double) |
| | Set/get the amount of data to be used for training. More...
| virtual double | GetTrainingFraction () |
| virtual void | SetTask (int) |
| | Set/get whether this filter should create a model of the input or assess the input or both. More...
| virtual int | GetTask () |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPSciVizDescriptiveStats () |
| | ~vtkPSciVizDescriptiveStats () override |
| int | LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData) override |
| | Method subclasses must override to calculate a full model from the given input data. More...
| int | AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model) override |
| | Method subclasses must override to assess an input table given a model of the proper type. More...
| | vtkSciVizStatistics () |
| | ~vtkSciVizStatistics () override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
| virtual int | RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) |
| int | RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
| virtual int | RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel) |
| virtual int | RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn) |
| virtual int | PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn) |
| virtual int | PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations) |
| virtual vtkIdType | GetNumberOfObservationsForTraining (vtkTable *observations) |
| | Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
| void | ShallowCopy (vtkDataObject *out, vtkDataObject *in) |
| | A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Provide access to VTK descriptive statistics.
This filter provides access to the features of vtkDescriptiveStatistics. See VTK documentation for details
- Thanks to David Thompson and Philippe Pebay from Sandia National Laboratories for implementing this class.
Definition at line 38 of file vtkPSciVizDescriptiveStats.h.
