Derive contingency tables and use them to assess the likelihood of associations.
| int | GetNumberOfAttributeArrays () |
| | Return the number of columns available for the current value of AttributeMode. More...
| const char * | GetAttributeArrayName (int n) |
| | Get the name of the n-th array ffor the current value of AttributeMode. More...
| int | GetAttributeArrayStatus (const char *arrName) |
| | Get the status of the specified array (i.e., whether or not it is a column of interest). More...
| vtkInformationIntegerKey * | MULTIPLE_MODELS () |
| | A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
| virtual int | GetAttributeMode () |
| | Set/get the type of field attribute (cell, point, field) More...
| virtual void | SetAttributeMode (int) |
| void | EnableAttributeArray (const char *arrName) |
| | An alternate interface for preparing a selection of arrays in ParaView. More...
| void | ClearAttributeArrays () |
| virtual void | SetTrainingFraction (double) |
| | Set/get the amount of data to be used for training. More...
| virtual double | GetTrainingFraction () |
| virtual void | SetTask (int) |
| | Set/get whether this filter should create a model of the input or assess the input or both. More...
| virtual int | GetTask () |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPSciVizContingencyStats () |
| | ~vtkPSciVizContingencyStats () override |
| int | LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData) override |
| | Method subclasses must override to calculate a full model from the given input data. More...
| int | AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model) override |
| | Method subclasses must override to assess an input table given a model of the proper type. More...
| | vtkSciVizStatistics () |
| | ~vtkSciVizStatistics () override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
| virtual int | RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) |
| int | RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
| virtual int | RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel) |
| virtual int | RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn) |
| virtual int | PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn) |
| virtual int | PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations) |
| virtual vtkIdType | GetNumberOfObservationsForTraining (vtkTable *observations) |
| | Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
| void | ShallowCopy (vtkDataObject *out, vtkDataObject *in) |
| | A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
This filter either computes a statistical model of a dataset or takes such a model as its second input. Then, the model (however it is obtained) may optionally be used to assess the input dataset.
This filter computes contingency tables between pairs of attributes. This result is a tabular bivariate probability distribution which serves as a Bayesian-style prior model. Data is assessed by computing
the probability of observing both variables simultaneously;
the probability of each variable conditioned on the other (the two values need not be identical); and
the pointwise mutual information (PMI).
Finally, the summary statistics include the information entropy of the observations.
Definition at line 44 of file vtkPSciVizContingencyStats.h.
