This reader handles multiple GenericIO files that are different resolutions of the same dataset.
| void | PrintSelf (ostream &os, vtkIndent indent) |
| virtual bool | CanReadFile (const char *fileName) |
| void | SetXAxisVariableName (const char *arg) |
| virtual char * | GetXAxisVariableName () |
| void | SetYAxisVariableName (const char *arg) |
| virtual char * | GetYAxisVariableName () |
| void | SetZAxisVariableName (const char *arg) |
| virtual char * | GetZAxisVariableName () |
| vtkStringArray * | GetArrayList () |
| bool | InsertLevel (const char *fileName, int level) |
| | This function inserts the given file as a resolution level on this reader. More...
| int | GetNumberOfLevels () const |
| | Gets the number of resolution levels known by this reader. More...
| const char * | GetFileNameForLevel (int level) const |
| | Gets the filename for the given resolution level. More...
| void | RemoveAllLevels () |
| | Clears all resolution levels. More...
| int | GetNumberOfPointArrays () |
| | Returns the number of arrays in the file. More...
| const char * | GetPointArrayName (int i) |
| | Returns the name of the ith array. More...
| int | GetPointArrayStatus (const char *name) |
| | Returns the status of the array corresponding to the given name. More...
| void | SetPointArrayStatus (const char *name, int status) |
| | Sets the status of the array corresponding to the given name. More...
| void | SetFileName (const char *fname) |
| | Sets/Gets the filename to be read by this reader. More...
| virtual char * | GetFileName () |
| virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| | Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
| vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
| vtkMultiBlockDataSet * | GetOutput () |
| vtkMultiBlockDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPMultiResolutionGenericIOReader () |
| | ~vtkPMultiResolutionGenericIOReader () |
| int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkMultiBlockDataSetAlgorithm () |
| | ~vtkMultiBlockDataSetAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
This reader aggregates these and allows streaming different resolutions on different parts of the dataset. It has the concept of a resolution level with 0 being the lowest resolution and the resolution increases as the level number increases.
Definition at line 35 of file vtkPMultiResolutionGenericIOReader.h.
