| void | PrintSelf (ostream &os, vtkIndent indent) |
| int | GetNumberOfPointArrays () |
| | Returns the number of arrays in the file, i.e., the number of columns. More...
| const char * | GetPointArrayName (int i) |
| | Returns the name of the ith array. More...
| int | GetPointArrayStatus (const char *name) |
| | Returns the status of the array corresponding to the given name. More...
| void | SetPointArrayStatus (const char *name, int status) |
| | Sets the status of the array named. More...
| vtkIdType | GetRequestedHaloId (vtkIdType i) |
| | Gets the ith requested halo id. More...
| vtkIdType | GetNumberOfRequestedHaloIds () |
| | Gets the number of requested halo ids. More...
| void | SetNumberOfRequestedHaloIds (vtkIdType numIds) |
| | Sets the number of requested halo ids. More...
| void | AddRequestedHaloId (vtkIdType haloId) |
| | Adds the given halo id to the list of halo ids to request. More...
| void | ClearRequestedHaloIds () |
| | Clears the list of requested halo ids. More...
| void | SetRequestedHaloId (vtkIdType i, vtkIdType haloId) |
| | Sets the ith requested halo id to the given haloId. More...
| virtual void | SetFileName (const char *) |
| | Specify the name of the cosmology particle binary file to read. More...
| virtual char * | GetFileName () |
| virtual void | SetXAxisVariableName (const char *) |
| | Set/Get the variable name to be used as the x-axis for plotting particles. More...
| virtual char * | GetXAxisVariableName () |
| virtual void | SetYAxisVariableName (const char *) |
| virtual char * | GetYAxisVariableName () |
| virtual void | SetZAxisVariableName (const char *) |
| virtual char * | GetZAxisVariableName () |
| virtual void | SetGenericIOType (int) |
| | Set/Get the underlying IO method the reader will employ, i.e., MPI or POSIX. More...
| virtual int | GetGenericIOType () |
| virtual void | SetBlockAssignment (int) |
| | Set/Get the underlying block-assignment strategy to use, i.e., ROUND_ROBIN, or RCB. More...
| virtual int | GetBlockAssignment () |
| virtual void | SetRankInQuery (int) |
| | Set/Get the RankInQuery. More...
| virtual int | GetRankInQuery () |
| virtual void | SetQueryRankNeighbors (int) |
| | Set/Get whether the reader should read/render only the data of the user-supplied rank, via SetRankInQuery(),. More...
| virtual int | GetQueryRankNeighbors () |
| virtual void | SetAppendBlockCoordinates (bool) |
| | Set/Get whether the reader should append the coordinates of the block each point was read from as a point data array. More...
| virtual void | AppendBlockCoordinatesOn () |
| virtual void | AppendBlockCoordinatesOff () |
| virtual bool | GetAppendBlockCoordinates () |
| virtual vtkStringArray * | GetArrayList () |
| | Returns the list of arrays used to select the variables to be used for the x,y and z axis. More...
| virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| | Get the data array selection tables used to configure which data arrays are loaded by the reader. More...
| virtual void | SetController (vtkMultiProcessController *) |
| | Set/Get a multiprocess-controller for reading in parallel. More...
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetHaloIdVariableName (const char *) |
| | Gets/Sets the variable name for the halo id of the particle. More...
| virtual char * | GetHaloIdVariableName () |
| vtkUnstructuredGridAlgorithm * | NewInstance () const |
| vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
| vtkUnstructuredGrid * | GetOutput () |
| vtkUnstructuredGrid * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPGenericIOReader () |
| virtual | ~vtkPGenericIOReader () |
| virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| void | LoadMetaData () |
| | Loads the GenericIO metadata from the file. More...
| bool | ReaderParametersChanged () |
| | This method checks if the internal reader parameters have changed. More...
| gio::GenericIOReader * | GetInternalReader () |
| | Returns the internal reader instance according to IOType. More...
| void | GetPointFromRawData (int xType, void *xBuffer, int yType, void *yBuffer, int zType, void *zBuffer, vtkIdType idx, double pnt[3]) |
| | Return the point from the raw data. More...
| void | LoadRawVariableData (std::string varName) |
| | Loads the variable with the given name. More...
| void | LoadRawData () |
| | Loads the Raw data. More...
| void | LoadCoordinates (vtkUnstructuredGrid *grid, std::set< vtkIdType > &pointsInSelectedHalos) |
| | Loads the particle coordinates. More...
| void | LoadData (vtkUnstructuredGrid *grid, const std::set< vtkIdType > &pointsInSelectedHalos) |
| | Loads the particle data arrays. More...
| void | FindRankNeighbors () |
| | Finds the neighbors of the user-supplied rank. More...
| | vtkUnstructuredGridAlgorithm () |
| | ~vtkUnstructuredGridAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
