| void | PrintSelf (ostream &os, vtkIndent indent) |
| virtual void | SetFileName (const char *) |
| | Specify the name of the cosmology particle binary file to read. More...
| virtual char * | GetFileName () |
| virtual void | SetRL (float) |
| | Specify the physical box dimensions size (rL) (default 100.0) More...
| virtual float | GetRL () |
| virtual void | SetOverlap (float) |
| | Specify the ghost cell spacing in Mpc (in rL units) (edge boundary of processor box) (default 5) More...
| virtual float | GetOverlap () |
| virtual void | SetReadMode (int) |
| | Set the read mode (0 = one-to-one, 1 = default, round-robin) More...
| virtual int | GetReadMode () |
| virtual void | SetCosmoFormat (int) |
| | Set whether to byte-swap or not the data. More...
| virtual int | GetCosmoFormat () |
| virtual vtkMultiProcessController * | GetController () |
| | Set the communicator object for interprocess communication. More...
| virtual void | SetController (vtkMultiProcessController *) |
| vtkUnstructuredGridAlgorithm * | NewInstance () const |
| vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
| vtkUnstructuredGrid * | GetOutput () |
| vtkUnstructuredGrid * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPCosmoReader () |
| | ~vtkPCosmoReader () |
| virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkUnstructuredGridAlgorithm () |
| | ~vtkUnstructuredGridAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Read a binary cosmology data file.
vtkPCosmoReader creates a vtkUnstructuredGrid from a binary cosmology file.
A cosmo file is a record format file with no header. One record per particle.
Each record is 32 bytes, with fields (in order) for: x_position (float), x_velocity (float), y_position (float), y_velocity (float), z-position (float), z_velocity (float) mass (float) identification tag (int64_t)
Total particle data can be split into per processor files, with each file name ending in the processor number.
Definition at line 94 of file vtkPCosmoReader.h.
