vtkPConvertSelection Class Reference
parallel aware vtkConvertSelection subclass. More...
#include <vtkPConvertSelection.h>
Inheritance diagram for vtkPConvertSelection:
Collaboration diagram for vtkPConvertSelection:
typedef vtkConvertSelection Superclass
- Public Types inherited from vtkConvertSelection
typedef vtkSelectionAlgorithm Superclass
- Public Types inherited from vtkSelectionAlgorithm
enum  DesiredOutputPrecision
void SetController (vtkMultiProcessController *)
 Get/Set the parallel controller. More...
virtual vtkMultiProcessControllerGetController ()
- Public Member Functions inherited from vtkConvertSelection
vtkConvertSelectionNewInstance () const
void SetDataObjectConnection (vtkAlgorithmOutput *in)
virtual void SetInputFieldType (int)
virtual int GetInputFieldType ()
virtual void SetOutputType (int)
virtual int GetOutputType ()
virtual void SetArrayName (const char *)
virtual const char * GetArrayName ()
virtual void SetArrayNames (vtkStringArray *)
virtual vtkStringArrayGetArrayNames ()
void AddArrayName (const char *)
void ClearArrayNames ()
virtual void SetMatchAnyValues (bool)
virtual bool GetMatchAnyValues ()
virtual void MatchAnyValuesOn ()
virtual void MatchAnyValuesOff ()
virtual void SetSelectionExtractor (vtkExtractSelection *)
virtual vtkExtractSelectionGetSelectionExtractor ()
- Public Member Functions inherited from vtkSelectionAlgorithm
vtkSelectionAlgorithmNewInstance () const
vtkSelectionGetOutput ()
vtkSelectionGetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPConvertSelectionNew ()
static vtkPConvertSelectionSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkConvertSelection
static vtkConvertSelectionNew ()
static vtkConvertSelectionSafeDownCast (vtkObjectBase *o)
static vtkSelectionToIndexSelection (vtkSelection *input, vtkDataObject *data)
static vtkSelectionToGlobalIdSelection (vtkSelection *input, vtkDataObject *data)
static vtkSelectionToPedigreeIdSelection (vtkSelection *input, vtkDataObject *data)
static vtkSelectionToValueSelection (vtkSelection *input, vtkDataObject *data, const char *arrayName)
static vtkSelectionToValueSelection (vtkSelection *input, vtkDataObject *data, vtkStringArray *arrayNames)
static void GetSelectedItems (vtkSelection *input, vtkDataObject *data, int fieldType, vtkIdTypeArray *indices)
static void GetSelectedVertices (vtkSelection *input, vtkGraph *data, vtkIdTypeArray *indices)
static void GetSelectedEdges (vtkSelection *input, vtkGraph *data, vtkIdTypeArray *indices)
static void GetSelectedPoints (vtkSelection *input, vtkDataSet *data, vtkIdTypeArray *indices)
static void GetSelectedCells (vtkSelection *input, vtkDataSet *data, vtkIdTypeArray *indices)
static void GetSelectedRows (vtkSelection *input, vtkTable *data, vtkIdTypeArray *indices)
static vtkSelectionToSelectionType (vtkSelection *input, vtkDataObject *data, int type, vtkStringArray *arrayNames=0, int inputFieldType=-1)
- Static Public Member Functions inherited from vtkSelectionAlgorithm
static vtkSelectionAlgorithmNew ()
static vtkSelectionAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPConvertSelection ()
 ~vtkPConvertSelection () override
- Protected Member Functions inherited from vtkConvertSelection
 vtkConvertSelection ()
 ~vtkConvertSelection ()
int Convert (vtkSelection *input, vtkDataObject *data, vtkSelection *output)
int ConvertCompositeDataSet (vtkSelection *input, vtkCompositeDataSet *data, vtkSelection *output)
int ConvertToIndexSelection (vtkSelectionNode *input, vtkDataSet *data, vtkSelectionNode *output)
int SelectTableFromTable (vtkTable *selTable, vtkTable *dataTable, vtkIdTypeArray *indices)
int ConvertToBlockSelection (vtkSelection *input, vtkCompositeDataSet *data, vtkSelection *output)
- Protected Member Functions inherited from vtkSelectionAlgorithm
 vtkSelectionAlgorithm ()
 ~vtkSelectionAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkMultiProcessControllerController
- Protected Attributes inherited from vtkConvertSelection
int OutputType
int InputFieldType
vtkStringArrayArrayNames
bool MatchAnyValues
vtkExtractSelectionSelectionExtractor
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkPConvertSelection is a parallel aware vtkConvertSelection subclass.
Definition at line 30 of file vtkPConvertSelection.h.
Definition at line 34 of file vtkPConvertSelection.h.
◆ vtkPConvertSelection()
vtkPConvertSelection::vtkPConvertSelection ( )
◆ ~vtkPConvertSelection()
vtkPConvertSelection::~vtkPConvertSelection ( )
static vtkPConvertSelection* vtkPConvertSelection::New ( )
virtual const char* vtkPConvertSelection::GetClassName ( )
static int vtkPConvertSelection::IsTypeOf ( const char *  type)
virtual int vtkPConvertSelection::IsA ( const char *  type)
Reimplemented from vtkConvertSelection.
static vtkPConvertSelection* vtkPConvertSelection::SafeDownCast ( vtkObject o)
void vtkPConvertSelection::PrintSelf ( ostream &  os,
◆ SetController()
void vtkPConvertSelection::SetController ( vtkMultiProcessController )
◆ GetController()
virtual vtkMultiProcessController* vtkPConvertSelection::GetController ( )
◆ RequestData()
int vtkPConvertSelection::RequestData ( vtkInformation ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ Controller
vtkMultiProcessController* vtkPConvertSelection::Controller
Definition at line 51 of file vtkPConvertSelection.h.
