This filter takes the output of the HACC halo finder and runs the subhalo finder on a user-specified list of halos.
| void | PrintSelf (ostream &os, vtkIndent indent) |
| vtkIdType | GetHaloToProcess (vtkIdType idx) |
| | Gets the halo to process at the given index This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
| void | AddHaloToProcess (vtkIdType haloId) |
| | Adds a halo to the list of halos that will have the subhalo finder run on them This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
| void | SetHaloToProcess (vtkIdType idx, vtkIdType haloId) |
| | Sets the halo id to process at the given index in the list This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
| void | SetNumberOfHalosToProcess (vtkIdType num) |
| | Sets the number of halos to process This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
| vtkIdType | GetNumberOfHalosToProcess () |
| | Gets the number of halos to process This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
| void | ClearHalosToProcess () |
| | Clears the list of halos that will have the subhalo finder run on them This list is used when the filter is in ONLY_SELECTED_HALOS mode. More...
| virtual void | SetMode (int) |
| | Sets/Gets the mode of the subhalo finding filter. More...
| virtual int | GetMode () |
| virtual void | SetSizeThreshold (vtkIdType) |
| | Sets/Gets the size threshold which is the minimum number of particles in the halos that will have the subhalo finder run on them in HALOS_LARGER_THAN_THRESHOLD mode. More...
| virtual vtkIdType | GetSizeThreshold () |
| virtual void | SetRL (double) |
| | Gets/Sets RL, the physical coordinate box size Default: 256.0. More...
| virtual double | GetRL () |
| virtual void | SetDeadSize (double) |
| | Gets/Sets the size of the ghost particle region around each process's particles to exchange when creating ghost particles. More...
| virtual double | GetDeadSize () |
| virtual void | SetParticleMass (float) |
| | Gets/Sets the particle mass. More...
| virtual float | GetParticleMass () |
| virtual void | SetBB (double) |
| | Gets/Sets distance threshold for particles to be considered in the same halo. More...
| virtual double | GetBB () |
| virtual void | SetAlphaFactor (double) |
| | Gets/Sets alpha factor. More...
| virtual double | GetAlphaFactor () |
| virtual void | SetBetaFactor (double) |
| | Gets/Sets beta factor. More...
| virtual double | GetBetaFactor () |
| virtual void | SetMinCandidateSize (int) |
| | Gets/Sets the minimum size of a subhalo candidate Default: 200. More...
| virtual int | GetMinCandidateSize () |
| virtual void | SetNumSPHNeighbors (int) |
| | Gets/Sets NumSPHNeighbors Default: 64. More...
| virtual int | GetNumSPHNeighbors () |
| virtual void | SetNumNeighbors (int) |
| | Gets/Sets the number of neighbors that are examined by the subhalo finder to determine local clumps near the each particle Default: 20. More...
| virtual int | GetNumNeighbors () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPANLSubhaloFinder () |
| virtual | ~vtkPANLSubhaloFinder () |
| int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
The input should be a vtkUnstructuredGrid with the data arrays vx, vy, vz, id and fof_halo_tag. AddHaloToProcess should be used to select which halos to find subhalos of.
The first output is a vtkUnstructuredGrid similar to the input but with the data array subhalo_tag appended to indicate which subhalo a point lies in. The value will be -1 for points in no halo.
The second output is a vtkUnstructuredGrid with one point per subhalo and data arrays for summary information such as average velocity, mass, and center of mass.
Definition at line 45 of file vtkPANLSubhaloFinder.h.
