| void | PrintSelf (ostream &os, vtkIndent indent) |
| virtual void | SetRunSubHaloFinder (bool) |
| | Turns on/off the subhalo finder part of the algorithm Default: Off. More...
| virtual bool | GetRunSubHaloFinder () |
| virtual void | RunSubHaloFinderOn () |
| virtual void | RunSubHaloFinderOff () |
| virtual void | SetRL (double) |
| | Gets/Sets RL, the physical coordinate box size Default: 256.0. More...
| virtual double | GetRL () |
| virtual void | SetDistanceConvertFactor (double) |
| | Gets/Sets the distance conversion factor. More...
| virtual double | GetDistanceConvertFactor () |
| virtual void | SetMassConvertFactor (double) |
| | Gets/Sets the mass conversion factor. More...
| virtual double | GetMassConvertFactor () |
| virtual void | SetDeadSize (double) |
| | Gets/Sets the size of the ghost particle region around each process's particles to exchange when creating ghost particles. More...
| virtual double | GetDeadSize () |
| virtual void | SetParticleMass (float) |
| | Gets/Sets the particle mass. More...
| virtual float | GetParticleMass () |
| virtual void | SetBB (double) |
| | Gets/Sets distance threshold for particles to be considered in the same halo. More...
| virtual double | GetBB () |
| virtual void | SetAlphaFactor (double) |
| | Gets/Sets alpha factor. More...
| virtual double | GetAlphaFactor () |
| virtual void | SetBetaFactor (double) |
| | Gets/Sets beta factor. More...
| virtual double | GetBetaFactor () |
| virtual void | SetNP (int) |
| | Gets/Sets NP Default: 1024. More...
| virtual int | GetNP () |
| virtual void | SetNMin (int) |
| | Gets/Sets the minimum number of close neighbors for a halo candidate to include a particle. More...
| virtual int | GetNMin () |
| virtual void | SetPMin (int) |
| | Gets/Sets the minimum number of particles required for a halo candidate to be considered a halo and output Default: 10000. More...
| virtual int | GetPMin () |
| virtual void | SetMinFOFSubhaloSize (long) |
| | Gets/Sets the minimum halo size to run the subhalo finder on. More...
| virtual long | GetMinFOFSubhaloSize () |
| virtual void | SetMinCandidateSize (int) |
| | Gets/Sets the minimum size of a subhalo candidate Default: 200. More...
| virtual int | GetMinCandidateSize () |
| virtual void | SetNumSPHNeighbors (int) |
| | Gets/Sets NumSPHNeighbors Default: 64. More...
| virtual int | GetNumSPHNeighbors () |
| virtual void | SetNumNeighbors (int) |
| | Gets/Sets the number of neighbors that are examined by the subhalo finder to determine local clumps near the each particle Default: 20. More...
| virtual int | GetNumNeighbors () |
| virtual void | SetCenterFindingMode (int) |
| | Gets/Sets the center finding method used by the halo finder once halos are identified. More...
| virtual int | GetCenterFindingMode () |
| virtual void | SetSmoothingLength (double) |
| | Gets/Sets the smoothing length used by the center finders Default: 0.0. More...
| virtual double | GetSmoothingLength () |
| virtual void | SetOmegaDM (double) |
| | Gets/Sets the OmegaDM parameter of the simulation. More...
| virtual double | GetOmegaDM () |
| virtual void | SetOmegaNU (double) |
| | Gets/Sets the OmegaNU parameter of the simulation. More...
| virtual double | GetOmegaNU () |
| virtual void | SetDeut (double) |
| | Gets/Sets the Deut parameter of the simulation. More...
| virtual double | GetDeut () |
| virtual void | SetHubble (double) |
| | Gets/Sets the Hubble parameter of the simulation. More...
| virtual double | GetHubble () |
| virtual void | SetRedShift (double) |
| | Gets/Sets the current redshift. More...
| virtual double | GetRedShift () |
| vtkUnstructuredGridAlgorithm * | NewInstance () const |
| vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
| vtkUnstructuredGrid * | GetOutput () |
| vtkUnstructuredGrid * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPANLHaloFinder () |
| virtual | ~vtkPANLHaloFinder () |
| virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkUnstructuredGridAlgorithm () |
| | ~vtkUnstructuredGridAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Given an input a vtkUnstructuredGrid of points with arrays vx, vy, vz, and id, finds clumps of points (halos) using the cosmotools halo finder.
The first output is a vtkUnstructuredGrid similar to the input but with the data array fof_halo_tag appended to indicate which halo a point lies in. The value will be -1 for points in no halo. Optionally, subhalo finding can be turned on which will find subhalos of all halos over a certain size. The subhalo id a point is in will be appended as the data array subhalo_tag.
The second output is a summary of halo properties such as mass, center of mass, center (computed via one of several algorithms), and net velocity. This vtkUnstructuredGrid has one point per halo.
The third output is empty unless subhalo finding is turned on. If subhalo finding is on, this output is similar to the second output except with data for each subhalo rather than each halo. It contains one point per subhalo.
Definition at line 44 of file vtkPANLHaloFinder.h.
