| vtkMTimeType | GetMTime () override |
| virtual vtkDataArraySelection * | GetChannelSelection () |
| | Choose the channels to combine in this calculator. More...
| void | SetChannel1LUT (vtkScalarsToColors *stc) |
| | Set the transfer functions to use to map scalars to colors. More...
| void | SetChannel2LUT (vtkScalarsToColors *stc) |
| void | SetChannel3LUT (vtkScalarsToColors *stc) |
| void | SetChannel4LUT (vtkScalarsToColors *stc) |
| void | SetChannel5LUT (vtkScalarsToColors *stc) |
| void | SetChannel6LUT (vtkScalarsToColors *stc) |
| void | SetChannel7LUT (vtkScalarsToColors *stc) |
| void | SetChannel8LUT (vtkScalarsToColors *stc) |
| void | SetChannel9LUT (vtkScalarsToColors *stc) |
| void | SetChannel10LUT (vtkScalarsToColors *stc) |
| void | SetLUT (const char *channelName, vtkScalarsToColors *) |
| void | SetChannel1Weight (double wght) |
| | Set weights for each of the channels. More...
| void | SetChannel2Weight (double wght) |
| void | SetChannel3Weight (double wght) |
| void | SetChannel4Weight (double wght) |
| void | SetChannel5Weight (double wght) |
| void | SetChannel6Weight (double wght) |
| void | SetChannel7Weight (double wght) |
| void | SetChannel8Weight (double wght) |
| void | SetChannel9Weight (double wght) |
| void | SetChannel10Weight (double wght) |
| void | SetWeight (const char *channelName, double weight) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkOMETIFFChannelCalculator () |
| | ~vtkOMETIFFChannelCalculator () override |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
filter to combine multiple channels into colors
vtkOMETIFFChannelCalculator is designed to combine multiple channels, typically from an OME-TIFF file, to generate RGBA colors. Up to 10 channels are supported. One must specify a vtkScalarsToColors object to use to map the channel scalars to colors for each enabled channel.
Definition at line 36 of file vtkOMETIFFChannelCalculator.h.
