| void | PrintSelf (std::ostream &os, vtkIndent indent) override |
| void | SetImageResolution (int img_width, int img_height) |
| | Communicates the next expected image resolution. More...
| virtual void | SetQuality (unsigned int) |
| | Set the quality measure. More...
| virtual unsigned int | GetQuality () |
| virtual int | Compress () |
| | Call this method to compress the input and generate the compressed data. More...
| virtual int | Decompress () |
| | Decompresses and geenartes the decompressed data as output. More...
| virtual void | SaveConfiguration (vtkMultiProcessStream *stream) |
| | Description: Serialize/Restore compressor configuration (but not the data) into the stream. More...
| virtual bool | RestoreConfiguration (vtkMultiProcessStream *stream) |
| virtual const char * | SaveConfiguration () |
| virtual const char * | RestoreConfiguration (const char *stream) |
| void | SetInput (vtkUnsignedCharArray *input) |
| | Get/Set the input to this compressor. More...
| virtual vtkUnsignedCharArray * | GetInput () |
| virtual vtkUnsignedCharArray * | GetOutput () |
| | Get/Set the output of the compressor. More...
| void | SetOutput (vtkUnsignedCharArray *) |
| virtual void | SetLossLessMode (int) |
| | When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More...
| virtual int | GetLossLessMode () |
Definition at line 32 of file vtkNvPipeCompressor.h.
